iPhone 13 Pro Max ラウドスピーカーの交換
はじめに
手順 1 に進むiPhone 13 Pro Maxのラウドスピーカーを取り出して交換するための修理ガイドです。
必要な工具と部品
パーツ
ツール
もっと見る
油性ペンでオープニングピックの先端から3mmの位置にマークを入れます。
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
iPhoneの画面全体に、透明な梱包用テープを重ね合わせます。
次の手順でうまく吸盤が装着しない場合は、強力なテープ(ガムテープなど)を持ち手に折って、代わりにスクリーンを持ち上げてみてください。
この手順で使用する道具:Clampy - Anti-Clamp$24.95
青いハンドルをヒンジ側に引くと、リバースクランプのアームを解除します。
iPhoneの左右どちらか側の端に向けてアームをスライドします。
吸盤カップをiPhoneの下端付近に装着します。上部に一つ、下部に1つずつ取り付けます。
吸盤カップ両側をしっかりと締め合わせると、標的の場所にしっかりと装着させることができます。
ガラス部分の一番端を避けながら、デバイス下端に吸盤カップを装着します。
吸盤を一定の力でしっかりと引き上げ、スクリーンとフレームの間にわずかな隙間を作ります。
スクリーンのプラスチックベゼルの下の隙間に開口ピックを挿入します。
オープニングピックをiPhoneの右下あたりでスライドさせ、粘着部分を切り離します。
iPhoneの右端を右上隅に達するまでスライドアップを続けます。
作業を進める前に、右上コーナーにピックを残しておきます。
吸盤ハンドルもしくはiSclackを外していない場合は、ここで取り外します。
iPhoneを回転して、右端が手前に来るように配置します。
iPhoneのディスプレイを右側から(本のページをめくるように)開きます。
作業中、ディスプレイが邪魔にならないよう、ディスプレイを立てかけるための衝立てを準備してください。
この手順で使用する道具:Magnetic Project Mat$19.95
Y000ドライバーを使って、バッテリーコネクターカバーを固定している1.3mmネジを3本外します。
スパッジャーの先端もしくは清潔な指先で、ロジックボード上のソケットからバッテリーコネクタをこじ開けて外します。
コネクタをロジックボードから少し離して曲げてください。修理中に誤ってソケットに接触してしまい、デバイスに電源が供給されるのを防ぎます。
Y000ドライバーを使って、フロントセンサーコネクタカバーから1.1mmネジを2本外します。
プラスドライバーを使って、フロントセンサーコネクタのカバーから、残りの2本のネジを外します。
1.5mmネジー1本
1.8mmネジー1本
を見比べてください。残りのコンポーネントを移植する必要があるか、パーツを取り付ける前に接着剤の裏張りを取る必要があります。
デバイスを再組立する際は、これらのインストラクションを逆の順番に従って作業を進めてください。
e-wasteを処理する場合は、認可済みリサイクルセンターR2を通じて廃棄してください。
修理が上手く進みませんか?トラブルシュートのヘルプには、iPhone 13 Pro Max のアンサーコミュニティを参照してください。
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
your website is really useful. Thanks a million :)
Sam, great detail and clear photos but I wanted to see all sides of the loudspeaker and didn’t see them. Could you add more loudspeaker pictures to your post?
Are waterproof seals part of the replacement kit, if not why?
Jim Langston - 返信
I ordered the screwdriver for the 13 ProMax (Y000) as well as the full kit which has this Y000 head. Neither tip works to remove the screws. Any suggestions?
Barbara Nuckles - 返信
