メインコンテンツにスキップ
iPhone 6s Plus Battery Replacement
必要な工具と部品
ビデオの概要
  1. iPhone 6s Plus Battery Replacement, Pentalobe Screws: 手順 1、 1の画像 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus Battery Replacement, Opening Procedure: 手順 2、 1の画像 1
    この手順で使用する道具:
    Anti-Clamp
    $24.95
    購入する
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. iPhone 6s Plus Battery Replacement: 手順 3、 1の画像 1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 6s Plus Battery Replacement: 手順 4、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 4、 2の画像 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  5. iPhone 6s Plus Battery Replacement: 手順 5、 3の画像 1 iPhone 6s Plus Battery Replacement: 手順 5、 3の画像 2 iPhone 6s Plus Battery Replacement: 手順 5、 3の画像 3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  6. iPhone 6s Plus Battery Replacement: 手順 6、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 6、 2の画像 2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  7. iPhone 6s Plus Battery Replacement: 手順 7、 3の画像 1 iPhone 6s Plus Battery Replacement: 手順 7、 3の画像 2 iPhone 6s Plus Battery Replacement: 手順 7、 3の画像 3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  8. iPhone 6s Plus Battery Replacement: 手順 8、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 8、 2の画像 2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  9. iPhone 6s Plus Battery Replacement: 手順 9、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 9、 2の画像 2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  10. iPhone 6s Plus Battery Replacement: 手順 10、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 10、 2の画像 2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  11. iPhone 6s Plus Battery Replacement: 手順 11、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 11、 2の画像 2
    • Pull up on the small nub on the suction cup to remove it from the display.
  12. iPhone 6s Plus Battery Replacement: 手順 12、 3の画像 1 iPhone 6s Plus Battery Replacement: 手順 12、 3の画像 2 iPhone 6s Plus Battery Replacement: 手順 12、 3の画像 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  13. iPhone 6s Plus Battery Replacement, Battery Connector: 手順 13、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  14. iPhone 6s Plus Battery Replacement: 手順 14、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 14、 2の画像 2
    • Remove the battery connector bracket.
  15. iPhone 6s Plus Battery Replacement: 手順 15、 3の画像 1 iPhone 6s Plus Battery Replacement: 手順 15、 3の画像 2 iPhone 6s Plus Battery Replacement: 手順 15、 3の画像 3
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  16. iPhone 6s Plus Battery Replacement: 手順 16、 3の画像 1 iPhone 6s Plus Battery Replacement: 手順 16、 3の画像 2 iPhone 6s Plus Battery Replacement: 手順 16、 3の画像 3
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  17. iPhone 6s Plus Battery Replacement, Display Assembly: 手順 17、 1の画像 1
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  18. iPhone 6s Plus Battery Replacement: 手順 18、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 18、 2の画像 2
    • Remove the display cable bracket.
  19. iPhone 6s Plus Battery Replacement: 手順 19、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 19、 2の画像 2
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  20. iPhone 6s Plus Battery Replacement: 手順 20、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 20、 2の画像 2
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  21. iPhone 6s Plus Battery Replacement: 手順 21、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 21、 2の画像 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  22. iPhone 6s Plus Battery Replacement: 手順 22、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 22、 2の画像 2
  23. iPhone 6s Plus Battery Replacement, Battery: 手順 23、 3の画像 1 iPhone 6s Plus Battery Replacement, Battery: 手順 23、 3の画像 2 iPhone 6s Plus Battery Replacement, Battery: 手順 23、 3の画像 3
    • Peel back the tips of the three battery adhesive strips along the bottom edge of the battery.
  24. iPhone 6s Plus Battery Replacement: 手順 24、 1の画像 1
    • Gather the ends of all three adhesive strips in your hand.
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
  25. iPhone 6s Plus Battery Replacement: 手順 25、 3の画像 1 iPhone 6s Plus Battery Replacement: 手順 25、 3の画像 2 iPhone 6s Plus Battery Replacement: 手順 25、 3の画像 3
    • Gently pull the battery adhesive tabs away from the battery, toward the bottom of the iPhone.
    • To avoid tearing the adhesive strip, be careful not to pull against the battery or lower components.
    • Pull steadily, maintaining constant tension on the strips as they slip out from between the battery and the rear case. For best results, pull the strips at a 60º angle or less.
    • The strips will stretch to many times their original length. Continue pulling and re-grab the strips near the battery if necessary.
    • Hold down the battery with one hand as you pull, or the elastic strips may fling the battery from the phone once they're separated from the rear case.
  26. iPhone 6s Plus Battery Replacement: 手順 26、 2の画像 1 iPhone 6s Plus Battery Replacement: 手順 26、 2の画像 2
    • If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
    • Do not pry against the logic board or you may damage the phone.
    • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
    • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
    • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
  27. iPhone 6s Plus Battery Replacement: 手順 27、 1の画像 1
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the the ribbon cable.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
終わりに
568 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Evan Noronha
メンバー登録日: 02/05/15
223,523 ポイント
168のガイドは作成済み
92 件のコメント
Most common on IPhone 6s/6 repair jobs is this battery replacement. Great tutorial!
Raymond Amansec - 返信
so few comments on this one?!
has any/many done this without the adhesive strips.. and was it ok?
sarah - 返信
If you mean the battery adhesive strips, sure—you can put a piece of double-sided tape down the back of the battery, and it probably won't move anywhere. There's not much room for the battery to move anyway. Use the adhesive strips if you want to do it right—but, if you're in a bind and you just need the phone working, you can skip the strips. And you can always open the phone back up and add the adhesive strips later.
If you mean the adhesive gasket around the display, the answer is pretty much the same—It's better to have it, but it doesn't hurt anything to put the phone back together without it.
Jeff Suovanen -
by far the easiest repair I've done. only 3 screws! really dont think the cables need to be disconneted. i just used a shoe lace to gently hold up the screen. sticky strips came out fine. happy. thanks.
sarah - 返信
Where can one buy the adhesive gasket for the case
Sandeep singh - 返信
コメントを追加
統計データ:
過去 24時間: 43
過去 7 日: 340
過去 30 日: 1,548
今までの合計 463,237
