メインコンテンツにスキップ
Google Pixel Daughterboard Replacement
必要な工具と部品
  1. Google Pixel Daughterboard Replacement, Display: 手順 1、 1の画像 1
    • Turn off the device.
    • Prepare an iOpener to heat the edges of the display and soften the adhesive underneath. Alternatively, you may use a heat gun or a hair dryer.
    • The surfaces near the speaker and microphone (top and bottom respectively) have larger adhesive sections. These areas may require slightly longer heat exposure. The display should be heated until it's slightly too hot to touch, for roughly two minutes.
    When reassembling, does the adhesive still hold the phone together when closed or do we need to apply more adhesive?
    Jess Haddow - 返信
    Step 10 addresses this: there should be a plastic sheet that looks like your screen in the repair kit. This is the new adhesive for reassembly.
    Peter Karski -
    Unfortunately also cracked my display on the way in. You have to go pretty deep under the top and bottom of the screen but BARELY in around the sides, especially the corners. If I had to do it over again, I would have either tried a playing card or put some type of depth limit/mark on my pick so I didn’t go more than a few millimeters in.
    Matthew Jastremski - 返信
    Use plenty of heat here and take your time. Start from the top, then the sides. use a gentle prying motion with the picks but don’t go too deep.
    Richard Wood - 返信
    It’s EXTREMELY easy to crack the screen. Just buy a new display module before fixing it. The old screen will be disposable.
    Buyi Yu - 返信
    Don’t even waste your time with the iOpener. I went straight for the hair dryer and opening picks took 30 mins to get the screen off with no issues.
    eric duchene - 返信
    Hair dryer worked for me, thanks!
    David Gault -
    As others have said, the iOpeners didn't work for me at all. I tried microwaving, I tried boiling, but even when the iOpener was too hot to touch the phone didn't get that hot. A hair dryer eventually worked, but took a long time too, and I had to pull quite hard (similar to pulling on a really stuck LEGO brick, I was surprised my screen didn't crack). I also dripped some isopropyl along the edge where I could lift it a teeny bit but not get a pick in, which seemed to get the gap to widen. Once I had an edge up and could start sliding the pick along though everything went much more smoothly. Reading other comments, I bet a heat gun would have been a better tool.
    Mark Fickett -
    If you haven’t purchased this kit yet then stop right here. The difficulty, as stated, is very difficult. This was my first attempted repair. I spent a good hour heating the adhesive and felt good about getting the display off. I even paused to boot the phone to make sure I didn’t damage the screen before flipping it over - it worked fine still! Then I went to pull the display from the top using the picks. Shattered the corner of the screen. $129 for a new screen. At this point, the Pixel 3 is $499. I bought a new phone. Just be prepared to break the screen. Many people mention it in the comments. I felt confident I could do it. I couldn’t.
    Michael Neil - 返信
    do yourself a favor and purchase a replacement screen when you order a battery. it’s impossible to remove the screen without damaging it no matter how careful you are.
    Andrey Gerasenkov - 返信
    100% agree. So glad that I did. My new screen was only £20 from ebay - took ages to arrive as it came from China, but works perfectly.
    Daniel Yeo -
    I managed it - this was my first repair. It’s a lot harder than I was expecting, but totally doable! I recommend just sliding the very edge of the pick around first until you find a corner that starts to peel up. Once you can see under the screen (without bending it, of course!), you can go further in to break the stubborn adhesive globs. It took me just under 30 minutes to remove the screen.
    Peter Karski -
    My tip: Place a hot-water bottle on the screen for 2 minutes. Use the suction handle to lift one edge and insert an opening pick. Use an opening tool to cut through the adhesive at the bottom and place another opening pick in the second corner. Place the hot-water bottle on the phone again and wait 2 minutes. Cut through the sides with the opening tool (if you are focused it's nearly impossible to put this tool in too deep) and do the same on the top of the phone as on the bottom. I was afraid of the high difficulty, but it only took me 15 minutes to remove the screen with no problems. Medium difficulty.
    Dorian - 返信
    I didn’t crack the screen, but somehow the thing wouldn’t power on after. Not sure if it was heat, or if I borked the cable somehow. New screen went in and it works great.
    Chris Jones - 返信
    It IS possible to get the screen off without breaking it, just take your time. I spent about an hour using the included picks along with the iopener.
    That said, the adhesive is a bear to fully remove from the screen without marring it up.
    Kixwooder - 返信
    I didn’t fully remove the old glue; When I put it back together, I melted the old glue (and some new glue) to seal it all closed again.
    David Gault -
    Tip, use a gallon ziplock bag with some hot water (maybe 150 degrees). Place the phone on a towel and fold the towel over and shield the part you aren’t working on, then use the bag for ~30s to apply and re-apply heat as needed. I first heated up the entire phone and ended up separating the screen from the glass (thus breaking the screen). The second time I did it, I just heated up one section at a time and I succeeded in removing the screen without breaking it.
    Daniel Beardsley - 返信
    Couldn’t get it open with anything, including dunking it (wrapped in a ziplock) in freshly boiled water for from 2 to 20 minutes. But then I managed to get it with only minor discolorations along top and bottom edges (which are noticeable when the screen is off or on dark backgrounds).
    What did the trick was setting the heat gun to 100°C and heating it really up close for 2 minutes. 60°C didn’t do squat, but 80-90°C would probably work better, without damaging the screen.
    With that done, the glass required a little bit of force to lift up, force of gravity on the rest of the phone wasn’t enough.
    gelraenua - 返信
    I attempted this with an iOpener and gave up as it didn’t seem to heat it enough to lift the edge of the screen.
    I remembered I had a heat gun at that point (duh, should’ve been what I started with). I had the gun at 350 initially and moved it around relatively quickly. But, discovered that if I lingered a little it discolored the screen (tested and the screen still works where it’s discolored, but it’s slightly off-color at one corner). I ended up using 200 deg (F) instead and moved more slowly. I put slight pressure on with the suction cup while heating the edges and finally got a corner up. Plopped a pick in there and used another pick to slowly cut along that edge while heating where cutting. I kept a pick plopped in each corner as I went. Once I got most of the screen free I grabbed the edges of the screen to keep upward pressure from the glue and heated any places that were still stuck with the heat gun and cut the last strands with another pick.
    TL;DR - The iOpener doesn’t seem sufficient for this job.
    Jonathan Stucklen - 返信
  2. Google Pixel Daughterboard Replacement: 手順 2、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 2、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 2、 3の画像 3
    • In the following steps, you will separate the display panel by slicing though the adhesive bonding the display to the Pixel's chassis.
    • For reference, the back of the display panel is shown at left. Note the narrow clearance between the side of the display unit and the OLED panel. (The bezels indicate this spacing on the front.)
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
    For reference, the iFixit opening tool (the blue prybar) has pry hooks of about 1.5-2mm in length.
    You can measure your tools to 1-2mm and mark them on some, and 9mm on others, so that you have an indicator line for depth.
    You can also use the line from the top/bottom and side bezels as a guide for how deep to “slice” with the pick.
    Mr. Porter - 返信
    The display panel consists of two components. The outer component is a glass panel with a digitizer fused onto it, and the second component is a fragile AMOLED panel with electronic circuitry and a ribbon cable that connects it to the phone internals. The digitizer and AMOLED panel both extend to within 1.5mm of the sides of the glass panel. To avoid destroying the AMOLED panel when removing the display panel, start at the bottom (Steps 3 and 4) and do not insert any opening or cutting tools deeper than 1.5mm at the sides or 9mm at the top or bottom (Steps 4 and 5). [Maybe add this text to Step 2 to help prevent others destroying the AMOLED panel].
    Alan Upson - 返信
    Update on my earlier post: my replacement display panel (pre-owned) appears to be a different construction to my original display panel in that the AMOLED panel, digitizer and glass panel are bonded together in some way, so they appear to be a single component. I guess it is possible that my original display panel could have been like this at first, and that I managed to separate the AMOLED panel from the digitizer as I removed the display panel from the phone, but there is no sign of any adhesive.
    Alan Upson - 返信
  3. Google Pixel Daughterboard Replacement: 手順 3、 2の画像 1 Google Pixel Daughterboard Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Suction Handle
    $2.99
    • Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
    • If your display is cracked, cover it with packing tape to help the suction cup adhere and prevent glass shards from popping loose.
    • You may need to apply more heat if this doesn't come up. Don't be impatient, this will take time. Once you can gently insert a tool in the gap, move on to the next step.
    the glass will have to be extremely hot to do this, i was able to achieve it by setting the phone of the heated bed of a 3d printer and setting it to 110 C .
    alex chargeer - 返信
    I used a hairdryer, moving back and forth over the area I was planning on using the suction cup at first, with my finger near the metal chassis so I could feel if it was getting absurdly hot. I would then suction a little, and not see any change. Heat again, suction again, seeing movement, but not enough space to get a tool in. Repeat this several times until you’re just able to get the tip of a tool in there, then continue to gently pull up with the suction cup while gently “slicing” around the edge until you’ve got a few spots free. (I’ve got another tip in the comments on the next step.)
    Mr. Porter - 返信
    This worked like a charm with lots of patience, stopping and drying every step and cutting the glue when I can see it clearly and move further down.
    Krishna Devarakonda -
    Tip one: ONLY FOCUS ON HALF THE SCREEN AT A TIME. As you get further along, you can start moving back and forth, but start focusing only on the upper or lower half.
    NEXT, as I started the slicing process, I would leave a pick in on each of the sides as I got to them, to kind of save my spot in case my pick slipped out. If you feel like you’re not getting anywhere, apply some light heat across the edges of the entire display, depending on how far in you are.
    When you’re on the last few bits, get a headlamp on and hold the phone so you can see in between the screen and rest of the body. As you gently lift the screen, you can see inside and slice the remaining strands and gunked up areas with less fear of damaging other components, because you’ll be lifting them away.
    Mr. Porter - 返信
  4. Google Pixel Daughterboard Replacement: 手順 4、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 4、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 4、 3の画像 3
    • Insert an opening pick or a playing card into the gap between the chassis and the display assembly.
    • Begin to slide the opening pick around the edge of the display, cutting through the adhesive that secures it.
    • Do not try to lift or pry the screen off with the pick. Simply slide it around to detach the adhesive.
    • The display panel is extremely fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
    I needed a stronger tool than the provided guitar picks to actually get between the glass and the frame. Had to use a metal tool to get in there. Once I could get in, things went fairly smoothly.
    Only mistake after that was not getting a great seal on the glue when reassembling the phone so now the glass toward the bottom of the screen doesn’t completely stay in place. :(
    Steve Johnson - 返信
    Dang! Metal is a scary choice, but I’m glad it worked out for the most part. That’s good to know. You could try re-heating the adhesive around the part of the screen that isn’t staying in place, and then putting the phone under a stack of books for an hour or so! That might get it to seal up completely.
    Taylor Dixon -
    I got the glass free by using plenty of heat, an x-acto knife to start the opening and playing cards under the glass to break the glue. I did not use the suction cup because it kept feeling like it would break the glass.
    Michael Hendricks - 返信
    +1 to Michael Hendricks. I ended up putting mine in my toaster oven (which worked splendidly), and I did have to use an x-acto knife to get it started. After that, it was possible to continue using the picks, but DON’T EXPECT TO BE ABLE TO REUSE THE SAME DISPLAY. New displays are $35 on ebay. Just get a new one before you start the work or you’ll almost certainly be without a phone for a week.
    Kael Shipman - 返信
    I was super careful based on all the comments to not even get close to touching the back of the screen. But when reassembled I get nothing but a vibration when turning the phone on.
    I used the suction cup, lotsa heat, started from the top and pried screen off towards the bottom just barely teasing the edges with a special pick that I had from previous battery replacements (special pick limits penetration). It seemed to come off unscathed. But the results say otherwise.
    GUNTIS CIRCENIS - 返信
    Woof, like others have said, it’s incredibly easy to ruin the screen in this process. Kind of impossible to tell if you’re getting the adhesive or the screen with your tools.
    Definitely have a replacement if you really want to have a working phone after this step.
    Kris - 返信
    I agree with what other have stated. I tried both the iOpener and a hair dryer but was never able to get the suction cup to pull the glass up at all. I saw other instructions that use a “Thin Metal Pry Tool” to get under the glass. I improvised with some very thin metal I found from some parts I have available and that is able to get under even without heating. You don’t use the metal to pry open at all, just to get under the glass enough to get some thin cards under to remove the seal. The picks are too thick for any of these steps it seems. Just sliding the picks under the glass as shown seemed to be enough bending that I saw some hairline cracks in the glass. But I also damaged the OLED in the process. So, as others have reported, I too ended up with a dead screen. Waiting for my new one to arrive soon.
    I think it would be good to show more information about how you expect this step to work as it doesn’t seem to work as shown here. Or, look up some of the other resources online that work better.
    William Buerger - 返信
    I can’t see any way this can be done without screwing up the screen. I bought a replacement screen and then didn’t have to worry.
    Daniel Yeo - 返信
    Would it be possible to use a specially made opening pick that is protruding no more than 1.5mm from a thicker section that could run along the sides and top of the device to help ensure that the pick would not penetrate more than 1.5mm into the device? If suitably designed, it could probably be made of metal. Are any such specially made opening picks available from iFixit or elsewhere?
    Alan Upson - 返信
    Alan, this is an excellent idea! We have had tools like that in the past, but since every device is different it’s hard to make one pick that will work for every device. You might be able to find something like that somewhere else online, I’m not sure. Another thing you can do is measure your pick and mark 1.5 mm with a marker so you have a visual indication of how far your pick should go in!
    Taylor Dixon -
    No surprise the number of comments in this section. My experience here is slightly different. I took extreme care in screen removal and in the end everything works great! HOWEVER!!! I have the blue Pixel 1 with a white screen. DESPITE using ALL PLASTIC tools I scratched the white off from the back of the phone glass. It’s very noticeable along the top and bottom edges but does impact how it functions. In hindsight I think I could be careful and patient enough to avoid this but I had NO CLUE this was something else to look out for. No on mentions this anywhere. I considered before re-assembly of taking a white paint pen or Sharpie to the glass in an attempt to “repair” but decided that might do more harm than good.
    CJ Allebach - 返信
  5. Google Pixel Daughterboard Replacement: 手順 5、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 5、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 5、 3の画像 3
    • Continue carefully separating the adhesive around the rest of the device.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
    there should be two notes here - “while adhesive is still warm, REMOVE ALL OF IT or you would be fcked later.” additionally, “ensure you are not separating the OLED from the glass as this will somehow render the screen completely useless”
    Liz Zelnick - 返信
    Agreed. I just removed the glass from the OLED display…oopss. I’m hosed.
    Joshua Brown - 返信
    Removing the adhesive while it is warm is a great idea!
    Re: removing the glass from the OLED, as long as you aren’t inserting your opening pick deeper than Step 2 recommends, you should be safe from separating the glass and the display panel unless you are using a ton of heat, in which case you might be frying the display anyway!
    Taylor Dixon - 返信
    I didn’t apply enough heat during this process and subsequently separated the digitizer from the glass, instead of the whole assembly from the case. I had 3/4 of the screen free from the case when I became impatient and just tried to muscle my way through the rest of the adhesive. It is important to stop and apply more heat during this process any time it starts feeling difficult to move the pick through the adhesive, otherwise you risk breaking the screen and having to get a whole new one.
    Britton Wickes - 返信
    I got the glass off without cracking anything, but now that it’s back together it doesn’t seem to work. Could it have been damaged from the heat? It flickers green for an instant when plugging in to power or pressing the power button.
    Nicholas Cox - 返信
    Any recommendations on adhesive when reinstalling? I see there is a pre-made adhesive for sale here for $5.99. Don’t know if 3m double-sided tape would work just as well, or what thickness to use. Any tips would be much appreciated.
    Phillip - 返信
    Hey Phillip! I’d go with the pre-made adhesive to save yourself the headache of measurement, cutting, and having a whole roll of 3M tape you might not need. It would definitely work if that’s what you prefer though!
    Here’s a guide for applying the pre-made adhesive that you can follow, or just curb from if you use the 3M tape! Google Pixel Display Adhesive Installation
    Taylor Dixon - 返信
  6. Google Pixel Daughterboard Replacement: 手順 6、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 6、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    iFixit Opening Picks (Set of 6)
    • With the adhesive cut, slowly lift the display up from the top (the side with the speaker-grille cutout), carefully flip it over vertically toward the bottom of the device, and rest it on its face, as shown.
    • Don't forget there's sticky adhesive everywhere, so consider resting an opening pick between the screen and display, to avoid spreading the gunk!
    • Do not attempt to completely remove the display yet, as it is still connected by a fragile ribbon cable. Be careful to not to strain the cable while positioning the display.
    Ruined my Pixel following these instructions. Ribbon cable is at bottom (chin) of phone and not as shown in pictures. My advice take it somewhere and have them replace the battery, that way when they break it it’s their fault.
    John Simpson - 返信
    I’m sorry the instructions weren’t clear, John! I’ve updated the guide to better illustrate where ribbon cable is and how to work around it.
    Taylor Dixon -
    And another note - I used the suction cup to lift the glass. Unfortunately the glass cracked at that point…bummer. I would update this to describe HOW to lift the glass. As in, LIGHTLY lift up with the suction cup while mostly lifting up on the guitar picks to help separate..
    Joshua Brown - 返信
    No, don’t use the guitar picks to lift, those are to “cut”. The suction cup is only to help you get the first pick in, after that, all you’re doing is separating glue so you can lift the screen with your fingers.
    Mr. Porter -
    DO NOT “flip it over vertically toward the bottom of the device, and rest it on its face, as shown. “ unless you want to spend your day getting adhesive off the screen. Instead get the screw driver ready (step 7) before you start this step.
    eric duchene - 返信
    That occurred to me when I reached this step. I used an opening pick (since I already had them on hand) and rested it between the midframe and screen to avoid that very issue. I added it to the guide, now I just hope it gets verified!
    Mr. Porter -
    Gut bewährt hat sich eine Heißluftpistole mit Temperaturvorwahl - möglichst mit optional aufgesteckter Flachdüse. Bei 120-140 Grad Celsius kann man die Wärme zielgerichtet und dosiert auf den zu lösenden Teil des Displays ausrichten. Nach Ansetzen des Saughebers solange erwärmen, bis sich der benötigte Spalt für das Plektrum zeigt, und danach den Displayrand weiter zonenweise vorsichtig erwärmen, bis sich das Display ohne Druck und damit ohne Bruchgefahr abnehmen lässt.
    lovo - 返信
  7. Google Pixel Daughterboard Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the two black 3.5 mm T5 screws securing the display cable connector bracket.
    when removing the screen i have scratched the black square up the top left here. (right of the speaker)
    scratched down to the silver component below.
    i broke the screen while replacing my battery, will this brick my phone? or would a new screen still work?
    anarchy_in_oz - 返信
    Hey anarchy, your phone should still be okay! Most of the midframe assembly (including the stuff you scratched up) is there to reduce signal interference and provide structure for the fragile screen, so you most likely didn’t do any bricking! If your cracked screen still functions, you can plug that back in and make sure everything is okay before you pull the trigger on a new one. Hope this helps!
    Taylor Dixon -
  8. Google Pixel Daughterboard Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Use tweezers to remove the bracket that holds the display connector in place.
    • This is just a piece of metal, and should come up very easily. (The cable is removed in the next step.)
    Using extreme care, another broken screen here. Instead of coming off together, the adhesive separated between the outer glass and the digitizer panel/screen. Both were damaged in the process. Waste of time and money.
    Chris Kahn - 返信
    Yes, me too. I’d like advice as to how to vary the glue heating process for this to not occur. Does the heat need to be applied for longer so the deeper OLED panel releases without pulling from the glass?
    Joshua Brown - 返信
    I spent about an hour and a half working on removing my screen. It took many bursts of heat (from a hair dryer, I lost patience for the iOpener), some suction, more heat, more suction…. etc, until I was able to start moving the pick around. Even then I still applied heat from time to time to help the adhesive move along.
    Mr. Porter -
  9. Google Pixel Daughterboard Replacement: 手順 9、 1の画像 1
    • Use a spudger to pry up the display cable connector, freeing the display.
    • On reassembly, gently snap one side in, then the other.
    • Do not force this type of connector into place, as damage can occur. (You will need to feel a light snap, but force beyond this will permanently damage your connector.)
    (from other ifixit tutorial. Did not know this-and it is important!)
    To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    bgwong2476 - 返信
    Very good to know, thank you!
    Mr. Porter -
  10. Google Pixel Daughterboard Replacement: 手順 10、 1の画像 1
    • Remove the display.
    • Some replacement displays do not come with an earpiece speaker grille. If your replacement screen doesn't have one, be sure to transfer the grille from your old display to the new one.
    • During reassembly, pause here to test the functionality of your new part and replace the display adhesive.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  11. Google Pixel Daughterboard Replacement, Midframe: 手順 11、 1の画像 1
    • Use a T5 Torx driver to remove the nine 3.5 mm screws securing the midframe.
  12. Google Pixel Daughterboard Replacement: 手順 12、 1の画像 1
    • The midframe is held tightly in place by five clips. To release these clips, apply inward pressure with an opening tool as shown in the steps below.
    There’s also a clip at the top center (near the camera/ earpiece).
    When reassembling, snap the top clip in before you snap the sides. If you do the sides first, then you can’t snap the top in and will need to disassemble and try again.
    Mark Clementi - 返信
    +1, thank you for calling out the top clip. As mentioned, it doesn’t really matter during teardown, but build-up requires you snap this side in first.
    Mr. Porter -
    On the reassembly step, make sure that the little black wire on the right hand side of the phone is tucked away really well. It can prevent the clip on the bottom right from snapping into place.
    Casey Thimm - 返信
    To add to Casey’s comment, the black wire needs to be routed along the gap between the battery and the back/left-hand edge of the rear casing.
    Roman Iwanczuk - 返信
    I would keep a flat razor or an exact-o knife on hand when releasing the midframe from the clips. The tool provided by ifixit does not work well. Even the blue picks would work better.
    Ben Eisenberg - 返信
    Yeah, I wasn't able to jam a pick into the corner, it wouldn't catch. I used the end of the tweezers to lever the midframe up a little bit, and then was able to get a pick in and slide it along.
    Mark Fickett -
    I accidentally severed the ribbon cable for the power and volume button setup during this step. It’s located by the top right clip. It might be worth your while to order power button board when you buy the replacement battery — the boards are like, $9 new.
    Lucas Myers - 返信
    The wording was very confusing for me, but you don’t push on the black part on the inside of the frame, you put a pick or a jimmy in the gap between the midframe and outer case and lever it up.
    David Castro - 返信
    I don’t understand how to release the 5 insert . And I don’t want to destroy my pixel …
    ordinatous - 返信
  13. Google Pixel Daughterboard Replacement: 手順 13、 1の画像 1
    • Wedge an opening pick into the notch that is located at the bottom right corner of the phone.
  14. Google Pixel Daughterboard Replacement: 手順 14、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 14、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 14、 3の画像 3
    • Slide the opening pick up both sides of the device in the small space between the midframe and the rear case to release the clips holding it in place.
    • Note that the clips are not released by sliding through them, but rather the inward pressure the opening pick creates as it enters the gap around them.
    • If the clasps fail to come undone, try pushing the edge you're working on inward with your hand, or using a thicker tool like a spudger.
    • Do not attempt to remove the midframe yet! There is still a fragile ribbon cable underneath connecting the earpiece speaker to the motherboard.
    when removing the mid frame i damaged a ribbon cable at the bottom left. will that prevent my phone from turning on?
    Bryce Thoreson - 返信
    I had no luck using the spudger (too blunt) or the opening picks (too weak). I used a straight blade as shown at about 2:35 in this video:
    https://www.youtube.com/watch?time_conti...
    Todd Koenig - 返信
    +1 for this. The video was really useful - I used a craft knife to release the clips. I found that once I’d done the first two at the bottom end, the rest came easily.
    Daniel Yeo -
    +1 — This video was extremely helpful in visualizing the rest of the steps… I consulted it several times. Thanks!
    Mr. Porter -
    +1 for the knife method. Paying close attention to the image showing the 5 locations is important too. Once the first one has realised it is sooooooooo much easier.
    Till Weinhold -
    I succeeded in removing with the opener picks, but you just gotta be really patient and determined with the first one. The next ones come pretty easily after that.
    I recommend watching at least part of that video Todd Koenig shared because it helped me to understand how the press-clips interacted with the chassis. (You’re not releasing them by sliding through where they meet the chassis, but that motion will still do the job anyway.)
    Mr. Porter - 返信
    I found the iFixit opening tool (I think that’s what it’s called) WAY easier for doing this. It’s the blue tool that looks like it has two pry bars. I used the pick to pry the frame up slightly and then put the opening tool in with the pry part facing towards the outer frame. Like you were trying to pry the outer frame out. This puts pressure on the side of the mid-frame which very easily popped the clip free.
    I had more success separating the midframe from the body by prying the midframe and body apart, rather than applying inward pressure.
    David Gault - 返信
  15. Google Pixel Daughterboard Replacement: 手順 15、 2の画像 1 Google Pixel Daughterboard Replacement: 手順 15、 2の画像 2
    • Use a spudger to pry the earpiece speaker cable connector straight up, disconnecting it from the motherboard.
    • Remove the mid-frame from the device.
    • During reassembly, reattach the earpiece speaker cable and insert the top side of the midframe before you snap the clips back into place.
    Rather than remove the midframe, I just propped it up a bit more than 90 degrees from the phone onto a box, just so there’d be one less of these fumbly connectors to redo during reassembly.
    James Ludden - 返信
    Bei einem von mir reparierten Modell (2PW2200) war die beschriebene (per Kabel verbundene) Ohrhörer-Komponente in der Geräterückseite befestigt (und nicht im Mittelrahmen) - das beschriebene Lösen des Flachbandkabels war deshalb nicht nötig.
    lovo - 返信
  16. Google Pixel Daughterboard Replacement, Daughterboard: 手順 16、 2の画像 1 Google Pixel Daughterboard Replacement, Daughterboard: 手順 16、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to lift up the silver strip at the top of the daughterboard, and peel it back to expose the connector underneath.
  17. Google Pixel Daughterboard Replacement: 手順 17、 1の画像 1
    • Use a spudger to disconnect the interconnect ribbon cable from the daughterboard.
  18. Google Pixel Daughterboard Replacement: 手順 18、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 18、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 18、 3の画像 3
    • The vibration motor is connected to the daughterboard with a small socket connector.
    • To disconnect the cable, use tweezers to carefully pull the connector away from the socket by its cables.
    • The connector should come out of the socket easily. If it does not, don't pull on the cables with force. Instead, use an opening tool to gently pry it out.
    Step 16, and the reverse assembly, was the only thing that really threw me off. Especially after watching other videos. An arrow or an additional illustration would have been really helpful. I didn't understand that was a "turtle shell" sort of housing, and that you don't pluck the whole thing off like the other connections. For anyone else confused, you have to separate a microscopically thin wire cap from the rest of that housing, and slide it to the right side of the phone.
    Took me almost three hours of researching to figure out why I couldn't reconnect that piece!
    Aside from that one snafu, this tutorial was really helpful. I can finally recharge my Pixel's battery!
    Robyn Hovey - 返信
    Hey Robyn! You’re right, this step was a little confusing. Sorry about that! I’ve updated the step, hopefully it's a little more clear now. Thank you for the feedback!
    Taylor Dixon -
    I managed to strip the cable with my tweezers and have now broken the cable I think. Lesson learnt, take it easy on the very thin cables.
    Jonathan Bush - 返信
  19. Google Pixel Daughterboard Replacement: 手順 19、 1の画像 1
    • Remove the silver 2.5 mm T5 screw holding the daughterboard in place.
    For me (Pixel XL) there is another screw in the top left!
    Gregory Ho - 返信
  20. Google Pixel Daughterboard Replacement: 手順 20、 1の画像 1
    • Using tweezers, lift the contact pads located to the left of the daughterboard.
  21. Google Pixel Daughterboard Replacement: 手順 21、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 21、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 21、 3の画像 3
    • Optionally, you can pause here to remove the interconnect cable from the motherboard to keep it out of the way during the rest of the daughterboard removal process.
    • To do so, peel back the sticker on the motherboard side and use a spudger to lift the connector straight up.
    • If you choose to remove this interconnect cable, ensure that it is reinstalled in the same orientation. The phone will not power on if the cable is installed upside down.
  22. Google Pixel Daughterboard Replacement: 手順 22、 2の画像 1 Google Pixel Daughterboard Replacement: 手順 22、 2の画像 2
    • Using tweezers, lift the daughterboard up and flip it over onto the battery.
    • Don't try to remove the daughterboard yet! There are still two coaxial cables connected to its underside.
  23. Google Pixel Daughterboard Replacement: 手順 23、 3の画像 1 Google Pixel Daughterboard Replacement: 手順 23、 3の画像 2 Google Pixel Daughterboard Replacement: 手順 23、 3の画像 3
    • Use a spudger to pry up the black and white coaxial cables attached to underside of the daughterboard.
    • Coaxial cable connectors and sockets are fragile. To avoid damaging the connectors, be sure to gently pry them straight off of the board.
    • When reconnecting these cables, lay the daughterboard upside down on the battery and use tweezers to carefully position each connector over its socket on the board, then press it straight down until it snaps into place.
  24. Google Pixel Daughterboard Replacement: 手順 24、 2の画像 1 Google Pixel Daughterboard Replacement: 手順 24、 2の画像 2
    • Use tweezers to carefully pull each coax cable out of its retaining clip.
  25. Google Pixel Daughterboard Replacement: 手順 25、 2の画像 1 Google Pixel Daughterboard Replacement: 手順 25、 2の画像 2
    • Remove the daughterboard from the device.
    • If your replacement part does not come with a plastic barometric vent, use the edge of an opening tool to gently lift the vent off of the old daughterboard and transfer it to the new one.
    • You may need to use some adhesive or double-sided tape in order to attach the vent to the new part. If you do, be sure not to cover the vent hole on the bottom.
終わりに
20 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Camaryn Chambers
メンバー登録日: 04/26/17
457 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S23-G1, Livingston Spring 2017 Cal Poly, Team S23-G1, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G1
4 メンバー
13のガイドは作成済み
6 件のコメント
Hi, I’m looking to fix my google pixel, it has the common microphone problem where I can’t record any audio/ make calls on m device. Where can i purchase a replacement for the daughterboard? I really need to get it fixed. Thanks
timothy james - 返信
That’s a lot of steps. I miss the days where you could just pop the back of the phone case off. :/
Phillip - 返信
where can I look on the daughterboard if everything else seems to work except the speaker? and I don’t mean the earpiece speaker, the main speaker below. The problem appeared after I replaced the battery, so its most likely something I’ve done, I’ve retraced my steps but I don’t see any major issues.
Henry Scharf - 返信
Hey Henry! The daughterboard connects to the speaker with two golden pins that rest on the contact pads that stick out to the right of the speaker. You can see them in this photo. I would recommend cleaning the pins and the pad with some isopropyl alcohol and a q-tip. If that doesn’t fix the problem, check all the pins on both ends of the big interconnect cable and its corresponding sockets on the two boards—you may have accidentally bent one of them! If that’s the case and the bend is obvious, you can try to bend the offending pin back into place, or pick up a replacement cable. Hope this helps!
Taylor Dixon -
@taylord Thank you so much for pointing out those pins! You likely saved my sister’s phone. I’m fairly experienced with hardware repair but foolishly allowed one of the coax cables to run underneath the corner of the daughterboard. After cleaning the contacts and reinstalling the daughterboard the speakers and microphone are working, which is why I was trying to replace the board in the first place.
Thank you!
Adam Lee -
Greetings ifixit.com,
I am after the earpiece speaker cable component for a 1st gen Google pixel 128 g.
I sure hope you can help me out !
Dave Caldwell -5-13-2020
Dave Caldwell - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 110
今までの合計 21,220
