MagSafe ポート
3件の回答 8 スコア |
How do I remove keycaps? |
5件の回答 1 スコア |
Which MacBook screen repairs require Apple System Configuration tool? |
2件の回答 0 スコア |
Scratch on body - repairable? |
2件の回答 2 スコア |
Spilled water on my M1 pro Mac |
ドキュメント
パーツ
- MacBook Pro 16" (2021 A2485) Battery
- MacBook Pro and MacBook Air (A2442, A2485, A2681, A2779, A2780, A2941, A2991, A2918, A2992, A3112, A3113, A3114, A3185, A3186, A3401, A3403) Key Caps
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) Keyboard
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) USB-C Board
- MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) MagSafe 3 DC-In Board
- MacBook Pro 14" (A2442, A2779, A2918) and 16" (A2485, A2780) Battery Daughter Board Cable
- MacBook Pro and MacBook Air USB-C to MagSafe 3 Cable
- MacBook Pro 16" (A2485, A2780, A2991) Lower Case Screw Set
ツール
- iFixit Precision 4 mm Screwdriver Bit
- Spudger
- Tweezers
- iFixit Opening Picks (Set of 6)
- Suction Handle
- iFixit Precision Bit Driver, Aluminum
- iFixit Thermal Paste
- TR8 Torx Security Screwdriver
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- T5 Torx Screwdriver
- P2 Pentalobe Screwdriver iPhone
- T3 Torx Screwdriver
- Lint-Free Clean Room Wipes
- T6 Torx Screwdriver
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
モデル
A2485 (EMC 3651 MacBookPro18,1 2021) M1 Pro 10-Core/16-Core, A2485 (EMC 3651 MacBookPro18,2 2021) M1 Max 10-Core/24-Core, A2485 (EMC 3651 MacBookPro18,2 2021) M1 Max 10-Core/32-Core
ニュース
Teardown Teaser: Is the 2021 MacBook Pro Repairable?
製品情報
Apple completely redesigned the MacBook Pro line for late 2021. Introduced alongside new, advanced versions of their own custom silicon M1 chip, the new M1 Pro and M1 Max SoCs feature 10-core CPUs and up to 16-core and 32-core GPUs respectively. Both the new 16” MacBook Pro and its smaller 14” MacBook Pro sibling feature the return of more ports, ProMotion HDR mini-LED displays, 1080p webcams with display notch, full-size function keys, and a distinctive blacked-out keyboard well.
Starting at $2499, 2021’s 16” MacBook Pro is available in either Silver or Space Gray.
モデル番号 A2485 / EMC 3651.
技術仕様
ディスプレイ
- True Toneテクノロジー搭載 16.2インチ Liquid Retina XDR mini-LED ディスプレイ ; 3456 x 2234ピクセル解像度 (254 ppi); ProMotionテクノロジーによる最大120Hzのアダプティブリフレッシュレート; HDR(Extreme Dynamic Range), 広色域(P3); 最大1,000ニトの持続輝度(フルスクリーン)、1,600ニトのピーク輝度
プロセッサ
- Apple M1 Pro 3.23 GHz 10コア CPU, 16コア Neural Engine
- (以下に変更可能) Apple M1 Max 10コアCPU, 16コア Neural Engine
グラフィックス
- 16コア GPU搭載Apple M1 Pro
- (次に変更可能) 24コア GPU搭載Apple M1 Max
- (次に変更可能) 32コア GPU搭載Apple M1 Max
ストレージ
- 512 GB PCIe-based SSD, configurable to 1 TB, 2 TB, 4 TB, or 8 TB.
メモリ
- 16GBユニファイドメモリ、32 GB に変更可能(M1 Pro or M1 Max) もしくは 64 GB (M1 Max)
ワイヤレス
- 802.11ax Wi-Fi 6 ワイヤレスネットワーク; IEEE 802.11a/b/g/n/ac 互換性
- Bluetooth 5.0ワイヤレステクノロジー
バッテリー
- 100Whリチウムイオンバッテリー内蔵
- インターネットブラウジング最大14時間、Apple TVアプリのビデオ再生で最大21時間
サイズ
- 高さ: 0.66 in (1.68 cm)
- 幅: 14.01 in (35.57 cm)
- 奥行: 9.77 in (24.81 cm)
- 重量: M1 Pro: 4.7 lbs (2.1 kg), M1 Max: 4.8 lbs (2.2 kg)
ポート
- MagSafe 3 充電ポート
- 3× Thunderbolt USB-C ポート (Thunderbolt 4 / USB 4 / DisplayPort / charging)
- HDMI 2.0ポート
- SDXCカードスロット
- 1× 3.5 mm ヘッドホンジャック
追加情報
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
