メインコンテンツにスキップ
目次
Laptop Does Not Power Up
Drained/Dead Battery
The first thing to check for is a dead battery. Plug the unit in with it's AC charger and let it charge for at least 15 minutes and try turning it on again. Make sure the outlet the AC charger is plugged into works properly. To do so use an alternate electrical device to check and make sure the outlet is not faulty. In addition make sure the AC charger cable is fully plugged in.
Laptop is Overheating
Cooling Fan not Working
Put your ear next to the ventilation holes to make sure the fan is running. You will hear a soft whirring sound.
Cooling Fan is Covered
Check to make sure that the cooling fan is not being covered or blocked.
Will Not Read Disks
Scratched Disk
Remove your CD from the laptop to make sure it is not badly scratched. If so, it may need to be replaced. Try cleaning it with soap and water and a microfiber cloth.
Broken Disk Drive
For a guide to replace the disk drive look here.
Laptop Running Slowly
Too Many Applications Open
Running a lot of applications at one time will use a lot of memory and slow down your computer. Close some of those programs.
Insufficient RAM
Sometimes you need more memory than what comes with a computer. For a guide to replace the RAM look here.
Sticky Keys and Malfunctioning Keyboard
Keys are not Responding
The keyboard needs to be replaced if is all response has been terminated.
Keys are Stuck in Place
If the keys are stuck remove the keyboard and make sure nothing underneath is hindering keys from being pressed down. If any liquids have been spilled on the keys remove keyboard and clean key slot thoroughly.
作成者
1人の作成者と共同作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
440,041 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,623のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 9
今までの合計 935
