メインコンテンツにスキップ
iPhone 7 Plusのイヤピーススピーカーの交換
必要な工具と部品
  1. iPhone 7 Plusのイヤピーススピーカーの交換, ペンタローブネジ: 手順 1、 1の画像 1
    • 作業を始める前に、iPhoneのバッテリーを25%以下まで消費してください。充電されたリチウムイオンのバッテリーは発火の原因となったり、穴が開いてしまった際は爆発する危険性があります。
    • 解体作業を始める前に必ずiPhoneの電源を切ってください。
    • iPhoneの底面から3.4 mmペンタローブネジを2本外します。
    • iPhoneのディスプレイを開口することにより、ディスプレイの耐水シールが破損します。このステップを進める前に交換用のシールを用意しておくか、耐水シールの交換をしないで再組み立てする場合は液体の浸水に注意してください。
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - 返信
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    iHelpU.Tech - 返信
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - 返信
    How do you turn off if the screen isn’t responding to touch?
    adam - 返信
    The replacement battery came with the seal—but how do you put it on???
    lkollar - 返信
    Instructions for replacing the seal are here: iPhoneディスプレイ用接着剤の交換
    bester - 返信
    I just found the instructions on how to install the seals AFTER I was completed and had to figure it out. Maybe, just maybe you should link this somewhere on the guild instead of buried in a comment. Just a thought.
    Charles Meitin - 返信
    Step 1 is: Read through all the steps and comments or the method prior to starting on this Step 1. There's a lot of much needed information and experience that you can learn from which will reduce the chance of struggling, wasting time or even breaking your device.
    My favourites are:
    Use a hot water bottle.
    Label all screws you remove with their size and location on a piece of paper with double sided sticky tape.
    Test the lightning assembly at step 13
    There is a Standoff driver bit in the box, don't use a screwdriver.
    etc...
    Neil Eriksen - 返信
    A tip for looking out for all those little screws. I used an ice block tray, for all the little screws etc. I numbered each with the step number, as in the instructions, but not all steps have bits to look out for. Where two different size screws are used I had a tray for each size and marked step a and step b. For this I coloured each tray sticker with the colour of the screw as shown in the instructions. All this worked a treat with no confusion or using the wrong part.
    Herb
    Herb Adler - 返信
    The screw size for those with a screw set is P2.
    Gareth Flandro - 返信
  2. iPhone 7 Plusのイヤピーススピーカーの交換, ひび割れた部分にテープを貼る: 手順 2、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換, ひび割れた部分にテープを貼る: 手順 2、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換, ひび割れた部分にテープを貼る: 手順 2、 3の画像 3
    • iPhoneの画面が割れてしまった場合、ガラスの表面上にテープを貼っておくと、それ以上広がることがなく、作業中の怪我を防ぐことができます。
    • iPhoneの画面の上に、透明な梱包用テープを重ね合わせます。
    • 修理の際に飛び散るガラスから目を保護するため、安全メガネを着用してください。
    • 次の手順で吸盤がうまく装着しない場合は、強力なテープ(ガムテープなど)を持ち手に折って、代わりにそれでスクリーンを持ち上げてみてください。
    • それでもうまくいかない場合は、吸盤カップに強力接着剤をつけて、画面に装着してください。
  3. iPhone 7 Plusのイヤピーススピーカーの交換, リバースクランプの使用方法: 手順 3、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換, リバースクランプの使用方法: 手順 3、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換, リバースクランプの使用方法: 手順 3、 3の画像 3
    • 次の3つの手順では、デバイスの開講作業を簡単にするために開発されたツール、リバースクランプの使い方を紹介します。リバースクランプを使用しない場合は、この3つの手順をスキップして別の方法をご覧ください。
    • リバースクランプの詳細な使用方法については、 こちらのガイドをご覧ください。
    • 青いハンドルをヒンジ側に引くと、リバースクランのアームを解除します。
    • iPhoneの左/右側の端に向けてアームをスライドします。
    • 吸盤カップをiPhoneの下端付近に装着します。前面と背面に1つずつ取り付けます。
    • 吸盤カップ両側をギュッと締め合わせると、標的の場所にしっかりと装着させることができます。
    • 作業中のデバイス表面が滑りやすく、吸盤がうまく装着できない場合は、梱包用テープを表面に貼ると、よりグリップ力を強めることができます。
  4. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 4、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 4、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 4、 3の画像 3
    • 青いハンドルを手前に引くと、アームがロックされます。
    • ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
    • 吸盤カップの位置が合っていることを確認してください。装着位置がずれ始めてきたら、吸盤を少し緩めてアームを装着し直してください。
  5. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 5、 2の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 5、 2の画像 2
    • Heat an iOpenerを温めて、リバースクランプのアームの間にこれを通してください。
    • ヘアドライヤーヒートガンもしくはホットプレートでも対応できますが、過剰な熱はディスプレイや内蔵バッテリーを破損する恐れがあります。取り扱いにはご注意ください。
    • iOpenerを折り曲げて、iPhoneの下側端に当たるようにします。
    • 1分ほど待機すると、接着剤が剥がれ始め、デバイスの間に隙間ができます。
    • プラスチックベゼルとスクリーンの間の隙間にオープニングピックを差し込みます。スクリーン自体には差し込まないでください。
    • クランプで十分な隙間が作れない場合は、さらに接着面に熱を当てて、クランプを1/4程度時計回りに回してください。
    • 一回ごとの作業で1/4以上回さないでください。クランプをまわしたら1分間待ってください。リバースクランプの効果を待ってから、作業を続けてください。
    • 次の3つの手順はスキップしてください。
    it looks like a....
    Gergely Soki - 返信
  6. iPhone 7 Plusのイヤピーススピーカーの交換, ディスプレイを温めます。: 手順 6、 1の画像 1
    • 次の3つの手順では、吸盤カップを使ってスクリーンを乖離させる方法が学べます。
    • iPhoneの下端を加熱すると、ディスプレイを固定している接着剤が柔らかくなり、開きやすくなります。
    • ヘアドライヤーを使用するか、iOpenerを準備し、ディスプレイ裏側の接着剤を柔らかくするために、iPhone下部端に約90秒間あてます。
    No hair dryer so GENTLY heated over stove burner
    John Toth - 返信
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - 返信
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - 返信
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - 返信
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - 返信
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - 返信
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - 返信
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - 返信
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - 返信
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - 返信
    Hairdryer works fine for this step. No issues.
    tripmusic - 返信
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - 返信
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - 返信
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    John Noble - 返信
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    John Noble - 返信
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    John Noble - 返信
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - 返信
  7. iPhone 7 Plusのイヤピーススピーカーの交換, ディスプレイを外します。: 手順 7、 2の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換, ディスプレイを外します。: 手順 7、 2の画像 2
    • ホームボタンのすぐ上にあるフロントパネルの下半分に吸盤を取り付けます。
    • 吸盤カップをホームボタン上に装着しないでください。吸盤カップをしっかりとフロントガラスに固定するためです。
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - 返信
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Johnny Emrica - 返信
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - 返信
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - 返信
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - 返信
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - 返信
  8. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 8、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 8、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 8、 3の画像 3
    • 一定の力で吸盤カップを引き上げて、スクリーンとフレームの間にわずかな隙間を作ります。
    • 隙間に開口ピックを挿入します。
    • スクリーンを所定位置に固定する防水性接着剤は非常に強く、 最初の隙間を作るにはかなりの力を要します。なかなか隙間ができない場合、さらに熱を加えたり、ピックを挿入できるだけの十分な隙間を作るために画面を上下にゆっくり揺り動かして接着剤を弱めます。
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - 返信
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - 返信
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - 返信
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - 返信
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Johnny Emrica - 返信
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - 返信
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - 返信
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - 返信
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - 返信
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - 返信
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - 返信
    Suction cup pliers. Dead easy
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    dantegd - 返信
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - 返信
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - 返信
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - 返信
  9. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 9、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 9、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 9、 3の画像 3
    • 開口ピックを左下からiPhoneの音量コントロールボタンとサイレントスイッチの方向にスライドさせて、ディスプレイを固定している接着剤を剥がします。
    • ディスプレイの左上隅付近で停止します。
    • ディスプレイの上端から後部ケースを引き剥がそうとしないでください。固定しているプラスチック製のクリップが破損することがあります。
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - 返信
  10. iPhone 7 Plusのイヤピーススピーカーの交換, スクリーンの情報: 手順 10、 1の画像 1
    • iPhoneの右側に端に沿って、デリケートなケーブルが装着されています。この部分にピックを差し込まないでください。ケーブルを破損する恐れがあります。
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - 返信
  11. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 11、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 11、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 11、 3の画像 3
    • iPhoneの右下隅に開口ピックを再度差し込み、角を回ってiPhoneの右上にスライドさせて接着剤を剥がします。
    • ディスプレイケーブルを傷つける恐れがあるので、ピックを3mm以上差し込まないでください。
    No pick in the kit you sent me.
    Ted Cooper - 返信
  12. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 12、 2の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 12、 2の画像 2
    • ディスプレイの下端を押さえながら、吸盤カップをゆっくりと引き上げます。
    • ディスプレイを15°以上持ち上げないでください。ディスプレイが接続されたリボンケーブルを傷つけたり、破損する恐れがあります。
    • 吸盤カップの小さな持ち手(ノブ)を緩めて、フロントパネルから取り外します。
  13. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 13、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 13、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 13、 3の画像 3
    • ディスプレイ下の開口ピックを左上の角からiPhoneの上端に沿ってスライドさせて、残りの接着剤を剥がします。
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - 返信
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    Adam Yavner - 返信
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - 返信
  14. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 14、 2の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 14、 2の画像 2
    • ディスプレイアセンブリをわずかに下に(iPhoneの上端から離して)スライドさせて、リアケースに固定しているクリップを外します。
  15. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 15、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 15、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 15、 3の画像 3
    • 本のページをめくるように、ディスプレイの左側を持ち上げてiPhoneを開きます。
    • いくつかの壊れやすいリボンケーブルがまだiPhoneのロジックボードに接続しているので、ディスプレイを完全に外そうとしないでください。
    • 作業がしやすいように、iPhoneを開口をしたままディスプレイの後ろに衝立を置き、立てかけてください。
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - 返信
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - 返信
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - 返信
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Jim Glenys - 返信
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - 返信
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
    Raziocinjo - 返信
  16. iPhone 7 Plusのイヤピーススピーカーの交換, バッテリーの接続の外し方: 手順 16、 1の画像 1
    • ロジックボードに留められたディスプレイケーブルブラケットの下部から次の4本のトライウイングY000ネジを取り外します。
    • 1.2 mmネジー3本
    • 2.6 mmネジー1本
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - 返信
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    You could stick the suction cup back on, near the right side of the phone, with the blue hook oriented in such a way that it becomes a stand for the screen. That way it won’t open much more than 90 degrees, and leaves both your hands free.
    Mark -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - 返信
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - 返信
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - 返信
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
    my screwdriver will only remove the 2.6mm screw and not the others, what shall i do?
    AubreyG1 - 返信
    A tip to remember which screw is which as the differences are pretty tiny: I used different colored sharpie fine-points and made a mark on the top of the screws before removing. I thought about having strips of tape that I stuck similar sizes to, but the coloring seemed to work more easily. I only did this for step 11 and it saved me down the road when trying to differentiate the 1.2 and the 1.3mm screws!
    Trey Smith - 返信
    STOP! Before you remove Any screws, be sure to create several bins to hold the various sizes in… or mark them like Trey suggested. I failed to pay attention because I thought they were all the same… they are not. It is very hard to figure out the sizes if you remove them all and store them in a single location.
    John Grant - 返信
    i had a piece of paper with the steps numbered that involved screws. I had double sided tape on the paper and the number of screws and thier position marked. This was so helpful in removing and then finding and installing the tiniest screws on earth. And i have TINY hands. I can’t imagine someone with large paws being able to accomplish any of this.
    Tina Matthews - 返信
    there is one screw thats 1.2 mm but its bigger than the others and will fit in no hole of the entire phone. i got it out bot now i have no idea where it has to go i tried every hole. can somebody help me?
    Lars Göbel - 返信
    what do i do if one of the screws dont want to come off
    Neylley Reynoso - 返信
  17. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 17、 2の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 17、 2の画像 2
    • ディスプレイケーブルブラケットの下部を外します。
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - 返信
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - 返信
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - 返信
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
    lkollar - 返信
  18. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 18、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 18、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 18、 3の画像 3
    • スパッジャーの先端を使って、ロジックボード上のソケットからバッテリーコネクターを引き上げます。
    • 引き上げた後、コネクターケーブルをわずかにソケットから反対側に曲げて固定します。ソケットに接触して電話本体に電源が入ることがないように防止することができます。
    You could cover the battery socket with a small piece of tape to make sure that it doesn’t accidentally re-connect. It’s not likely to, but I liked the peace of mind.
    Mark - 返信
    on reassembly, make sure that the connector cable is back in place, along side the battery, and not up, or on top in any way.
    Sarr Sheffer - 返信
    I slipped a small piece of paper under the flap.
    MajorCouillon - 返信
    After this step it is worth jumping to step 36 and disconnecting the lighting connector assembly (indicated with the orange rectangle) and connecting the new cable to test it out. After attaching the new lightning connector assembly, reattach the battery, and try plugging it in to see if the new assembly works correctly. If it does, then power down the phone, disconnect the battery, and disconnect the new lightning connector assembly. Then continue. If it doesn’t work, this check will save you a couple of hours of work.
    Evan O - 返信
  19. iPhone 7 Plusのイヤピーススピーカーの交換, ディスプレイアセンブリ: 手順 19、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換, ディスプレイアセンブリ: 手順 19、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換, ディスプレイアセンブリ: 手順 19、 3の画像 3
    • この手順で、ケーブルの接続を外す、もしくは接続する前に、バッテリーの接続を外しているか必ず確認してください。
    • スパッジャーの平面側先端や指の先を使って、ロジックボード上のソケットから2つのディスプレイコネクタをまっすぐ引き上げて接続を外します。
    • コネクタを再装着する際は、コネクタを1つずつ差し込み、カチッと音がしてしっかり装着されてから、もう一方のコネクタを取り付けてください。コネクタの中央を押さえないでください。コネクターが僅かでもずれてしまうと永久的なダメージになります。
    • デバイスを再組み立てした後に、真っ白なスクリーンやディスプレイ上に白い線がある時、または部分的もしくは全体のタッチ応答がない場合は、両方のケーブルの接続を抜いてから、慎重に再接続してください。ケーブルがしっかりと固定されていることを確認してください。
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - 返信
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - 返信
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - 返信
    When I removed the lower display cable bracket in step 12, the top connector stuck to the bracket and became disconnected.
    Grant Crawford - 返信
    My replacement screen wouldn't sit in the display connector properly, (wouldn't clip in both sides at same time) so I made sure it sat on one and it was lined up and got a thin piece of dense sponge and placed that over the connector, then proceeded to install the connector shield and screen works perfectly fine without a hitch. Very good tutorial just earnt me £25 lol
    Joshua Driscoll - 返信
    have the same issue, sometimes it doesn’t sit on the left side, other time not on the other, the difference is iphone not starting at all or looping with apple logo reboot…
    ibisiki -
    Bent the pins on the connector out of place, worked them very carefully back with fine nose tweezers. This was by far the crux of the repair for me.
    nicO - 返信
  20. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 20、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 20、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 20、 3の画像 3
    • フロントパネルセンサーアセンブリのコネクターに取り付けられているブラケットからトライポイント Y000ネジを計3本外します。
    • 1.3 mm ネジー1本
    • 1.0 mm ネジー2本
    • ブラケットを取り出します。
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    chris west - 返信
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - 返信
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - 返信
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - 返信
    I called the y tip a triangle tip until I read these comments. Thanks for the correction
    Kayla Tobin -
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - 返信
    Care should be taken while removing the last 1.0mm screw, on the far right in the picture. This screw is screwed into another screw (or standoff) beneath the bracket. This standoff may come unscrewed and upon removing the bracket you may find the screw and standoff are still attached to the bracket. Do not lose this part if you decide to separate them , the standoff is not a normal phillips, and may require a special driver to reinstall. I used the phillips to start it back in, and relied on the screw to tighten it upon reassembly.
    Benji - 返信
    I know this is late bit a trick I use to put the standoffs in (had to do 2 cause someone lost the screws I was replacing) is to take the screw that goes in it srew them together loosely to give it a fake phillips head then gently screw both into the spot the standoff goes in. you can then take the phillips out (may need to put a spudger between the screw and standoff to keep the standoff down then use a tiny flathead to gently tighten the standoff down. its a few steps but makes life easier if you need to replace it quickly.
    Stephen Patterson -
    I was able to remove the first 1.0 mm three tri-point Y000 screw from the bracket but I cannot for the life of me get the other 1.0 mm screw undone or the one 1.3 mm screw undone. Any tips?
    I tried pressing down a bit harder and I even put the first screw back in to see if it helped me loosen the other two but it did not work.
    My screwdriver was doing the job up until this point, and I’m worried I’ll strip the screw if I keep trying.
    Would appreciate any advice!
    jrosegoep - 返信
    Dear IFixit: First, I want You to know I love your repair guides. I consider You to be the absolute best repair manuals available. But, hopefully as your friend I am going to point out once the bracked is removed a 2.0 mm Standoff screw should appear. It’s 1 of 2 screws holding the Antena Flex Cable in place. Rob
    Robert Schmidt - 返信
  21. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 21、 2の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 21、 2の画像 2
    • フロントパネルセンサーアセンブリのコネクターをロジックボード上のソケットから接続を外します。
    • このプレスコネクターは再装着の際、変形のダメージを防ぐため1回の取り付けで再接続してください。
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - 返信
    Thanks Kevin. I would be stuck if I hadn't read your comment!?! Great input.
    Lukas Watts -
    That's save my life!thanks god!
    neg -
    I also made this mistake! Thank goodness it didn’t break anything.
    That Guy - 返信
  22. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 22、 1の画像 1
    When removing the old adhesive from the edges, duct tape can be useful. Simply use small strips of duct tape and your spudger to press the tape’s adhesive side carefully into the edges of the phone’s display and slowly peel the duct tape away from the display. The duct tape should pick up the remaining adhesive and carry it away from the edges. use the tip of the spudger to gently scrape away any remaining dirt or film from the crease around the edge and repeat the action with a new strip of tape to pick up any dirt, adhesive or grime from the surface. This should save considerable time.
    Benji - 返信
    Thank you for including a link to the iPhone Display Adhesive Replacement guide, this was very helpful!
    Robert O'Brien - 返信
    is it really necessary to remove the display? the screen connectors are delicate and I fear re-assembly errors. I changed the battery and did not remove any screen connectors. no problems.
    jacobra - 返信
    Due to the fact that THIS is the repair guide for replacing the DISPLAY it IS necessary to remove the display connectors. There is another guide for changing the battery -- you might want to follow that one.
    Hannes -
    I did not remove the display and ended up ripping one of the lower display cable ribbons when I turned the phone to remove one of the connectors. Be careful. I had to get a new display and move the Touch ID button.
    Shawn Hime - 返信
    I think that moving the replacement of the seal lower in the chain of events would be more beneficial. I'm replacing the battery, and stretching the adhesive tabs that held the battery in at a low angle kept sticking themselves to the newly-installed adhesive seal.
    In the end, I wound up having to just remove the section of the seal along the bottom of the case :-/
    If I'd been looking at the bigger picture, I'd have wanted to put the seal on right before reattaching the screen cables.
    Rob Russell - 返信
    This guide does not show you the removal process for the top camera assembly. My screen looks like the one pictured but my replacement doesn't have the top connector or any of the front facing camera components and since the ribbon for the connectors looks like its coming out from underneath the display I can't see how to swap it over to the new display.
    Jezagee - 返信
  23. iPhone 7 Plusのイヤピーススピーカーの交換, イヤピーススピーカー: 手順 23、 1の画像 1
    • イヤピーススピーカーブラケットに固定された次の5本のプラスネジを外します。
    • 1.8 mmネジー2本
    • 2.3 mmネジー1本
    • 2.4 mmネジー1本
    • 2.8 mmネジー1本
  24. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 24、 1の画像 1
    • イヤピーススピーカーブラケットを取り出します。
  25. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 25、 3の画像 1 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 25、 3の画像 2 iPhone 7 Plusのイヤピーススピーカーの交換: 手順 25、 3の画像 3
    • スパッジャーの平面側先端を使って、筐体から正面向きカメラを持ち上げます。
    • カメラリボンケーブルの下に装着されているイヤピーススピーカーが作業の邪魔にならない位置に、カメラリボンケーブルを横に曲げます。
    How is this bit waterproofed on re-assembly?
    Cool_Breeze - 返信
    The screen/display that I got, already included a camera/speaker. So I didn’t have to remove it.
    I finished my repair and then started to use the phone again. I noticed Facetime was not working anymore (cameras, speakers and microphone was OK). I tried a few solutions I found on the Internet but nothing seemed to work. I open the phone back up and replaced the pre-installed camera with the old one I had on the broken screen/display. Closed the phone again and now Facetime works without any issues. I just wanted to pass that along.
    Federico Montes - 返信
  26. iPhone 7 Plusのイヤピーススピーカーの交換: 手順 26、 1の画像 1
    • イヤピーススピーカーを取り出します。
    • 指でバネコンタクトに接触しないでください。油脂が接続障害を引き起こすことがあります。アクシデントで接触してしまったら、イソプロピルアルコール(90%以上濃度)で慎重にコンタクト部分を拭き取ってください。
    If you’re looking to continue on and replace the speaker mesh, take a look at the camera/cable replacement guide.
    iPhone 7 Plus のフロントカメラとセンサーケーブルの交換
    tgruetzm - 返信
    I almost forgot to clean the spring contacts, thanks for reminding me.
    Maganafixes - 返信
終わりに
オリジナルのパーツと交換用パーツをよく見比べてください。交換用パーツに付いていない残りのコンポーネントや接着シールなどは、インストールする前に新パーツに移植する必要があります。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
e-wasteを処理する場合は、認可済みリサイクルセンターR2を通じて廃棄してください。
修理が上手く進みませんか?まずはベーシックなトラブルシューティングを試してみるか、このモデルのアンサーコミュニティに尋ねてみましょう。
81 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
6人の作成者と共同で作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
428,582 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,243のガイドは作成済み
3 件のコメント
I did that and the earpiece still did not work… Can the problem be the front camera flex cable (the front camera is working)?
Nick K - 返信
nicht vergessen: wenn man das iPhone in umgekehrter reihenfolge wieder zusammenbaut, wie hier beschrieben, ist das iPhone nicht mehr wasserdicht.
Georg - 返信
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 78
過去 30 日: 372
今までの合計 81,833
