メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Pro 13" Front Camera Assembly Replacement
必要な工具と部品
    1. iPad Pro 13" Front Camera Assembly Replacement, Prepare the iPad for disassembly: 手順 1、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Prepare the iPad for disassembly: 手順 1、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Prepare the iPad for disassembly: 手順 1、 3の画像 3
      • For your safety, fully discharge the battery before disassembling the device. This reduces the risk of fire if the battery is accidentally damaged during the repair.
      • Disconnect all cables and accessories from the iPad.
      • Place masking tape over the following areas of the display:
      • The TrueDepth camera near the middle of the top edge
      • The ambient light sensor near the middle of the left edge
      • The bottom edge, where there are delicate ribbon cables under the display
      • Note that directions in this guide are given for the iPad in landscape orientation. The USB-C port is on the right edge of the iPad.
      • If your screen is badly cracked, cover it with a layer of packing tape to help the suction cup stick and prevent shards of glass from coming off.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 13" Front Camera Assembly Replacement, Mark your opening picks: 手順 2、 1の画像 1
      • While removing the display, don't insert picks more than 3.5 mm.
      • Mark your opening picks at 3.5 mm.
      FixBotに聞いてみる
      コメントを追加
    2. iPad Pro 13" Front Camera Assembly Replacement, Heat the top-right corner: 手順 3、 1の画像 1
      • Apply a heated iOpener to the top-right corner of the screen for two minutes to soften the adhesive.
      • You can also use a hair dryer or heat gun to soften the adhesive, but be careful not to overheat the iPad as the screen and battery can be damaged by heat.
      • Use this same procedure for all future steps where heat is needed to soften adhesive, unless otherwise noted.
      FixBotに聞いてみる
      コメントを追加
    3. iPad Pro 13" Front Camera Assembly Replacement, Anti-Clamp instructions: 手順 4、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Anti-Clamp instructions: 手順 4、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Anti-Clamp instructions: 手順 4、 3の画像 3
      • The next three steps show how to use the Anti-Clamp. For complete Anti-Clamp instructions, including how to work with a broken screen, check out this guide.
      • If you don't have an Anti-Clamp, read these steps for important tips, then follow the alternate method using a suction handle, which comes after these steps.
      • Unlock the Anti-Clamp by pulling the blue handle backwards, away from the suction cups.
      • Place something under the bottom-left corner of the iPad to hold it level, then place the Anti-Clamp on your work surface and insert the top-right corner of the iPad between the Anti-Clamp's suction cups.
      • Hold the bottom of the Anti-Clamp and press down on the top arm to engage the suction cups.
      • Make sure the top and bottom suction cups are aligned, and remain aligned for this entire procedure.
      FixBotに聞いてみる
      コメントを追加
    4. iPad Pro 13" Front Camera Assembly Replacement: 手順 5、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 5、 2の画像 2
      • Pull the blue handle forward, towards the suction cups, to engage the twist mechanism.
      • Turn the blue handle clockwise one full rotation or until the suction cups start to stretch.
      • If a suction cup pops off, reapply it. If needed, apply some suction tape for a grippier surface.
      FixBotに聞いてみる
      コメントを追加
    5. iPad Pro 13" Front Camera Assembly Replacement: 手順 6、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 6、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 6、 3の画像 3
      • Wait at least one minute for the Anti-Clamp to pull the screen up until there's a small gap between the screen and the frame.
      • Rely on heat and time to lift the screen. Don't try to force it open.
      • If the screen isn't lifting after two minutes:
      • Make sure there's tension on the suction cups. Crank the handle just until you feel resistance, but don't crank too much or the suction cups will release.
      • Apply more heat while the Anti-Clamp is engaged. You can thread a heated iOpener through the Anti-Clamp or use a hair dryer or heat gun.
      • If the screen is still not releasing, crank the handle a half-turn and wait another minute while applying more heat periodically, still being careful not to overheat the iPad. Repeat as needed.
      • Once the screen lifts, insert a marked opening pick into the gap, no more than 3.5 mm deep.
      • Slide the opening pick around the corner and leave it inserted.
      FixBotに聞いてみる
      コメントを追加
    6. iPad Pro 13" Front Camera Assembly Replacement, Suction handle instructions: 手順 7、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Suction handle instructions: 手順 7、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Suction handle instructions: 手順 7、 3の画像 3
      • If you don't have an Anti‑Clamp, use a single suction handle instead.
      • If the screen is badly cracked, make a handle out of very strong tape instead of a suction cup. If nothing else works, you can use strong glue to stick the suction cup to the broken screen.
      • Apply the suction handle near the top‑right corner with the open part of the handle facing away from the edge.
      • Hold the iPad down with one hand, away from the suction cup, and pull the suction handle up and towards the center of the iPad.
      • As soon as a small gap appears between the screen and the frame, insert a marked opening pick no more than 3.5 mm into the gap and release tension on the suction cup.
      • If you're having trouble lifting the screen, be patient and apply more heat while pulling on the suction handle.
      • Slide the pick gently around the corner and leave it inserted.
      FixBotに聞いてみる
      コメントを追加
    7. iPad Pro 13" Front Camera Assembly Replacement, Heat the top edge: 手順 8、 1の画像 1
      • Use an iOpener, hair dryer, or heat gun to soften the adhesive under the top edge of the screen.
      • This iPad cools very quickly. To get the screen off, work in sections of about 3 inches at a time. So, for this step, start with heating the right side of the top edge.
      FixBotに聞いてみる
      コメントを追加
    8. iPad Pro 13" Front Camera Assembly Replacement, Slice the top edge adhesive: 手順 9、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Slice the top edge adhesive: 手順 9、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Slice the top edge adhesive: 手順 9、 3の画像 3
      • Be patient while slicing the screen adhesive. If you suddenly feel more resistance, stop and apply more heat. If you're using an iOpener, you can apply heat while you're sliding the pick.
      • Insert an additional marked opening pick beside the first pick, on the top edge of the iPad, no more than 3.5 mm.
      • Slice the adhesive by slowly sliding the opening pick under the screen towards the front camera, stopping before you get to the masking tape.
      FixBotに聞いてみる
      コメントを追加
    9. iPad Pro 13" Front Camera Assembly Replacement: 手順 10、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 10、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 10、 3の画像 3
      • Be careful not to damage the sensitive components, like the front camera and microphone, under the screen. Work slowly. If you feel resistance, stop, slide the pick back partially, apply more heat, and continue.
      • Lift the opening pick so it's at a sharp angle pointing into the iPad.
      • Slice the adhesive by sliding the pick under the taped section of the screen.
      FixBotに聞いてみる
      コメントを追加
    10. iPad Pro 13" Front Camera Assembly Replacement: 手順 11、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 11、 2の画像 2
      • Finish slicing the adhesive by sliding the opening pick to the top-left corner.
      • Leave the opening pick inserted.
      FixBotに聞いてみる
      コメントを追加
    11. iPad Pro 13" Front Camera Assembly Replacement, Slice the right edge adhesive: 手順 12、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Slice the right edge adhesive: 手順 12、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Slice the right edge adhesive: 手順 12、 3の画像 3
      • Heat the right edge of the iPad.
      • Insert an opening pick beside the first opening pick you inserted, on the right edge.
      • Working in small sections, slice the adhesive, applying more heat as needed.
      FixBotに聞いてみる
      コメントを追加
    12. iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom-right corner adhesive: 手順 13、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom-right corner adhesive: 手順 13、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom-right corner adhesive: 手順 13、 3の画像 3
      • Heat the bottom-right corner of the iPad.
      • Carefully slide the opening pick from the previous step around the bottom-right corner.
      • Leave the pick inserted.
      FixBotに聞いてみる
      コメントを追加
    13. iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom edge adhesive: 手順 14、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom edge adhesive: 手順 14、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom edge adhesive: 手順 14、 3の画像 3
      • Heat the bottom edge of the iPad, focusing on the right end.
      • Insert an opening pick beside the pick in the corner, on the bottom edge, no more than 3.5 mm deep.
      • Lift the pick so it enters the iPad at a sharp angle.
      • Carefully slide the pick under the screen across the bottom edge of the iPad.
      • Work slowly to avoid damaging the delicate ribbon cables under the screen in this section. If you feel any resistance, stop, slide your pick back partially, apply more heat, and try again.
      FixBotに聞いてみる
      コメントを追加
    14. iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom-left corner adhesive: 手順 15、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom-left corner adhesive: 手順 15、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Slice the bottom-left corner adhesive: 手順 15、 3の画像 3
      • Heat the bottom-left corner of the iPad.
      • Carefully slide the opening pick around the bottom-left corner.
      FixBotに聞いてみる
      コメントを追加
    15. iPad Pro 13" Front Camera Assembly Replacement, Slice the left edge adhesive: 手順 16、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Slice the left edge adhesive: 手順 16、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Slice the left edge adhesive: 手順 16、 3の画像 3
      • Heat the left edge of the iPad, focusing on the bottom end.
      • Insert an opening pick above the pick already inserted near the bottom-left corner.
      • Carefully slide the pick to the beginning of the masking tape.
      FixBotに聞いてみる
      コメントを追加
    16. iPad Pro 13" Front Camera Assembly Replacement: 手順 17、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 17、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 17、 3の画像 3
      • Slide the opening pick to the top-left corner.
      • Work slowly to avoid damaging the ambient light sensor near the middle of the screen. If you feel resistance, stop, pull the pick back slightly, apply more heat, and try again.
      • Don't try to remove the iPad screen yet. You should be able to lift the iPad screen about a half–inch out of the frame all the way around the edge.
      • If the screen is still adhered anywhere, use heat and an opening pick to slice the adhesive. Use opening picks to keep the screen lifted while you work.
      FixBotに聞いてみる
      コメントを追加
    17. iPad Pro 13" Front Camera Assembly Replacement, Reposition the screen: 手順 18、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Reposition the screen: 手順 18、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Reposition the screen: 手順 18、 3の画像 3
      • Once the screen is completely free of the adhesive, lift it about a half-inch and rotate it slightly counterclockwise so the screw next to the front camera is visible.
      FixBotに聞いてみる
      コメントを追加
    18. iPad Pro 13" Front Camera Assembly Replacement, Remove the microphone connector cover: 手順 19、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the microphone connector cover: 手順 19、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Remove the microphone connector cover: 手順 19、 3の画像 3
      • Use a JCIS or JIS 00 screwdriver to remove the 1.3 mm‑long screw securing the microphone connector cover.
      • Small iFixit Phillips bits are designed to work with JIS screws, so you can use an iFixit PH 00 driver. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
      • Use tweezers or your fingers to remove the microphone connector cover. Be careful not to damage the foam on the back.
      FixBotに聞いてみる
      コメントを追加
    19. iPad Pro 13" Front Camera Assembly Replacement, Disconnect the microphone: 手順 20、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Disconnect the microphone: 手順 20、 2の画像 2
      FixBotに聞いてみる
      コメントを追加
    20. iPad Pro 13" Front Camera Assembly Replacement, Open the iPad: 手順 21、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Open the iPad: 手順 21、 2の画像 2
      • Open the iPad like a book from the top edge.
      • Hold the screen above the iPad body and place a soft cloth on top of the iPad to protect both the screen and the iPad body.
      • Place the screen face-down on the cloth, being careful not to strain the cables still attached to the iPad body.
      FixBotに聞いてみる
      コメントを追加
    21. iPad Pro 13" Front Camera Assembly Replacement, Remove the display connectors cover: 手順 22、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the display connectors cover: 手順 22、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Remove the display connectors cover: 手順 22、 3の画像 3
      • Place cloths over the batteries to protect them while you work.
      • Use a JCIS or JIS 00 screwdriver to remove the screws securing the display connectors cover:
      • Four 2.1 mm‑long screws towards the center of the iPad
      • Two 1.6 mm‑long screws near the edge of the iPad
      • Use tweezers or your fingers to remove the display connectors cover.
      FixBotに聞いてみる
      コメントを追加
    22. iPad Pro 13" Front Camera Assembly Replacement, Disconnect the screen: 手順 23、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Disconnect the screen: 手順 23、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Disconnect the screen: 手順 23、 3の画像 3
      • Use the tip of a spudger to pry up and disconnect the wide display cable press connector.
      • Then, use the tip of a spudger to pry up and disconnect the Multi‑Touch cable press connector.
      FixBotに聞いてみる
      コメントを追加
    23. iPad Pro 13" Front Camera Assembly Replacement: 手順 24、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 24、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 24、 3の画像 3
      • Use the tip of a spudger to pry up and disconnect both of the display power cable press connectors.
      FixBotに聞いてみる
      コメントを追加
    24. iPad Pro 13" Front Camera Assembly Replacement, Remove the screen: 手順 25、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the screen: 手順 25、 2の画像 2
      • Remove the screen.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera bracket cover: 手順 26、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera bracket cover: 手順 26、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera bracket cover: 手順 26、 3の画像 3
      • Use a heated iOpener, hair dryer, or heat gun to soften the adhesive securing the long, black rubber cover below the front camera assembly.
      • Use tweezers or your fingers to pry up and remove the cover from the right side. Work slowly to avoid tearing it—it'll be reused later.
      • Leave the smaller rubber cover to the left of the front camera assembly in place.
      FixBotに聞いてみる
      コメントを追加
    2. iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera bracket: 手順 27、 1の画像 1
      • Use a JCIS or JIS 00 screwdriver to remove the four screws securing the front camera bracket:
      • Two 2.0 mm‑long screws on either edge.
      • The left edge screw is hidden by the smaller black rubber cover. Peel up only the loose portion on its left edge to access the screw.
      • Two 1.3 mm‑long screws in the center of the bracket.
      FixBotに聞いてみる
      コメントを追加
    3. iPad Pro 13" Front Camera Assembly Replacement: 手順 28、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 28、 2の画像 2
      • Use tweezers or your fingers to lift and remove the front camera bracket.
      FixBotに聞いてみる
      コメントを追加
    4. iPad Pro 13" Front Camera Assembly Replacement, Disconnect the front camera module: 手順 29、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Disconnect the front camera module: 手順 29、 2の画像 2
      • Use the point of a spudger to pry up and disconnect the front camera module's leftmost press connector.
      FixBotに聞いてみる
      コメントを追加
    5. iPad Pro 13" Front Camera Assembly Replacement: 手順 30、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 30、 2の画像 2
      • Be careful not to damage the sockets on the board in this step. The connectors are glued together and more difficult to disconnect.
      • Use the flat end of a spudger to pry up and disconnect the front camera module's two central press connectors. Insert the spudger underneath the top edge of each connector.
      FixBotに聞いてみる
      コメントを追加
    6. iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera screws: 手順 31、 1の画像 1
      • Use a Torx Plus 3IP screwdriver to remove the two 2.0 mm‑long screws securing the front camera assembly.
      • Standard Torx also works. Use T3 or T4 and apply constant, downward force to prevent stripping.
      FixBotに聞いてみる
      コメントを追加
    7. iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera: 手順 32、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera: 手順 32、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Remove the front camera: 手順 32、 3の画像 3
      • The front camera module has thermal compound underneath its left side. Leave it in place for reassembly.
      • Use your fingers or a spudger to pry up and remove the front camera assembly from its right edge.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 13" Front Camera Assembly Replacement, Disassembly complete: 手順 33、 1の画像 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble the iPad.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 13" Front Camera Assembly Replacement, Remove residue: 手順 34、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove residue: 手順 34、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Remove residue: 手順 34、 3の画像 3
      • Be careful not to damage the press connector sockets when cleaning around them.
      • Use the point of a spudger to lift any residual adhesive from between and around the front camera press connector sockets.
      • Use tweezers to remove the residual adhesive.
      FixBotに聞いてみる
      コメントを追加
    2. iPad Pro 13" Front Camera Assembly Replacement, Install the front camera module: 手順 35、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the front camera module: 手順 35、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Install the front camera module: 手順 35、 3の画像 3
      • Be careful not to touch the camera lenses—they're extremely difficult to clean.
      • If the replacement part includes protective covers over the camera lenses, leave them in place until this step.
      • Set the front camera module into its recess in the frame.
      FixBotに聞いてみる
      コメントを追加
    3. iPad Pro 13" Front Camera Assembly Replacement: 手順 36、 1の画像 1
      • Use a JCIS or JIS 00 screwdriver to install the two 2.0 mm‑long screws securing the front camera module.
      FixBotに聞いてみる
      コメントを追加
    4. iPad Pro 13" Front Camera Assembly Replacement, Connect the front camera module: 手順 37、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Connect the front camera module: 手順 37、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Connect the front camera module: 手順 37、 3の画像 3
      • Use the flat end of a spudger or your finger to connect the front camera module's two central press connectors.
      FixBotに聞いてみる
      コメントを追加
    5. iPad Pro 13" Front Camera Assembly Replacement: 手順 38、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 38、 2の画像 2
      • Repeat the previous step to connect the front camera module's leftmost press connector.
      FixBotに聞いてみる
      コメントを追加
    6. iPad Pro 13" Front Camera Assembly Replacement, Install the front camera bracket: 手順 39、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the front camera bracket: 手順 39、 2の画像 2
      • Align the front camera module bracket with its screw holes and set it into place.
      FixBotに聞いてみる
      コメントを追加
    7. iPad Pro 13" Front Camera Assembly Replacement: 手順 40、 1の画像 1
      • Use a JCIS or JIS 00 screwdriver to install the four screws securing the front camera bracket:
      • The left edge screw hole is hidden by the black rubber cover. Peel up only the loose portion on its left edge to install it.
      FixBotに聞いてみる
      コメントを追加
    8. iPad Pro 13" Front Camera Assembly Replacement, Install the bracket cover: 手順 41、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the bracket cover: 手順 41、 2の画像 2
      • Align the black rubber cover over the front camera module's bracket.
      • Press the cover onto the front camera module's bracket. Be careful not to touch the camera lenses.
      • Use an heated iOpener, hair dryer, or heat gun to soften the adhesive securing cover and help it bond.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 13" Front Camera Assembly Replacement, Clean frame adhesive: 手順 42、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Clean frame adhesive: 手順 42、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Clean frame adhesive: 手順 42、 3の画像 3
      • Don't touch the ambient light sensor near the middle of the left edge or TrueDepth camera near the middle of the top edge while cleaning the frame.
      • Use the tip of a spudger to lift a section of adhesive. Look for an edge or overhang where you can get underneath the adhesive strip.
      FixBotに聞いてみる
      コメントを追加
    2. iPad Pro 13" Front Camera Assembly Replacement: 手順 43、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 43、 2の画像 2
      • Use tweezers or your fingers to lift and remove the old screen adhesive. Apply a little heat to make the removal easier.
      FixBotに聞いてみる
      コメントを追加
    3. iPad Pro 13" Front Camera Assembly Replacement: 手順 44、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 44、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 44、 3の画像 3
      この手順で使用する道具:
      Adhesive Cleanup Kit (Set of 12)
      $7.99
      • Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
      • Alternatively, use our adhesive cleanup kit.
      FixBotに聞いてみる
      コメントを追加
    4. iPad Pro 13" Front Camera Assembly Replacement, Clean screen adhesive: 手順 45、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Clean screen adhesive: 手順 45、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Clean screen adhesive: 手順 45、 3の画像 3
      • Skip this step if you're installing a new screen.
      • Repeat this process to clean the adhesive off the screen bezel.
      • Don't scrape with a metal tool, or you will scratch the display assembly's black paint.
      • Only apply solvents (like isopropyl alcohol) to the black bezel. Don't let any get under the front sensor assembly or display itself. Solvents will also dissolve the foam gaskets, especially around the front camera cutouts.
      FixBotに聞いてみる
      コメントを追加
    5. iPad Pro 13" Front Camera Assembly Replacement, Align new adhesive: 手順 46、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Align new adhesive: 手順 46、 2の画像 2
      • If your replacement screen comes with adhesive pre‑installed, skip the next twelve steps.
      • Be careful not to crease or stretch the adhesive during installation. It can't be used if damaged.
      • Align the adhesive with the frame of the iPad. It's easiest to align it above the USB‑C port.
      FixBotに聞いてみる
      コメントを追加
    6. iPad Pro 13" Front Camera Assembly Replacement, Flip the adhesive over: 手順 47、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Flip the adhesive over: 手順 47、 2の画像 2
      • Flip the adhesive over so it's aligned with the back of the screen.
      FixBotに聞いてみる
      コメントを追加
    7. iPad Pro 13" Front Camera Assembly Replacement, Set the adhesive aside: 手順 48、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Set the adhesive aside: 手順 48、 2の画像 2
      • Lift the adhesive off the back of the screen and set it to the side. Keep it in the same orientation as the screen.
      FixBotに聞いてみる
      コメントを追加
    8. iPad Pro 13" Front Camera Assembly Replacement: 手順 49、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 49、 2の画像 2
      • Don't remove any of the plastic adhesive liners yet—they keep the adhesive in shape.
      • Use scissors to cut the adhesive vertically in half. Be careful not to crease or pull the adhesive itself.
      FixBotに聞いてみる
      コメントを追加
    9. iPad Pro 13" Front Camera Assembly Replacement, Left adhesive: 手順 50、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Left adhesive: 手順 50、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Left adhesive: 手順 50、 3の画像 3
      • The adhesive is encased in four layers of plastic—three on top and one on the bottom.
      • Peel and remove the topmost plastic cling layer from the left adhesive strip.
      FixBotに聞いてみる
      コメントを追加
    10. iPad Pro 13" Front Camera Assembly Replacement: 手順 51、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 51、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 51、 3の画像 3
      • Flip the left adhesive over.
      • Peel the clear liner with the blue line off the back of the left adhesive. The adhesive is now exposed.
      FixBotに聞いてみる
      コメントを追加
    11. iPad Pro 13" Front Camera Assembly Replacement, Install the left adhesive: 手順 52、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the left adhesive: 手順 52、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Install the left adhesive: 手順 52、 3の画像 3
      • Work slowly when installing the adhesive—once it sticks, it can't be repositioned.
      • Flip the left adhesive and align it to the left edge of the display assembly.
      • Set the left adhesive in place aligned with the left edge of the screen.
      • Press the top and bottom sections of the left adhesive onto the back of the screen.
      FixBotに聞いてみる
      コメントを追加
    12. iPad Pro 13" Front Camera Assembly Replacement: 手順 53、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 53、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 53、 3の画像 3
      • Remove the clear liner on the left adhesive. Leave the final blue liner in place.
      FixBotに聞いてみる
      コメントを追加
    13. iPad Pro 13" Front Camera Assembly Replacement, Prepare the right adhesive: 手順 54、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Prepare the right adhesive: 手順 54、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Prepare the right adhesive: 手順 54、 3の画像 3
      • Repeat the preparation process with the right adhesive strip.
      • Peel and remove the topmost (clear) cling layer from the strip.
      • Peel and remove the bottom liner layer (clear with a blue line) from the strip.
      FixBotに聞いてみる
      コメントを追加
    14. iPad Pro 13" Front Camera Assembly Replacement: 手順 55、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 55、 2の画像 2
      • Flip the right adhesive and peel off the clear liner with a blue line.
      FixBotに聞いてみる
      コメントを追加
    15. iPad Pro 13" Front Camera Assembly Replacement, Install the right adhesive: 手順 56、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the right adhesive: 手順 56、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Install the right adhesive: 手順 56、 3の画像 3
      • Flip the right adhesive and set it in place, aligned with the right edge of the screen.
      • Press the top and bottom sections of the right adhesive onto the back of the screen.
      FixBotに聞いてみる
      コメントを追加
    16. iPad Pro 13" Front Camera Assembly Replacement, Remove the clear liner: 手順 57、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the clear liner: 手順 57、 2の画像 2
      • Remove the clear liner off the right adhesive. Leave the final blue liner in place.
      FixBotに聞いてみる
      コメントを追加
    17. iPad Pro 13" Front Camera Assembly Replacement, Press the adhesive: 手順 58、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Press the adhesive: 手順 58、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Press the adhesive: 手順 58、 3の画像 3
      • Use the flat end of a spudger to gently press all the adhesive into place around the entire perimeter of the iPad. Be careful not to press on the delicate ribbon cables across the bottom of the screen.
      FixBotに聞いてみる
      コメントを追加
    18. iPad Pro 13" Front Camera Assembly Replacement, Set the screen on the iPad: 手順 59、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Set the screen on the iPad: 手順 59、 2の画像 2
      • Place a clean cloth over the left battery cell in the iPad.
      • Set the screen on the iPad, so the screen cable connectors can reach their respective sockets in the iPad.
      FixBotに聞いてみる
      コメントを追加
    19. iPad Pro 13" Front Camera Assembly Replacement, Connect the display power cables: 手順 60、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Connect the display power cables: 手順 60、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Connect the display power cables: 手順 60、 3の画像 3
      • Align one of the display power cable press connectors over its socket on the logic board.
      • Press down with the flat end of a spudger or your fingertip—first on one of the short sides, then the other—until it clicks into place.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Repeat this process to connect the second display power cable press connector.
      FixBotに聞いてみる
      コメントを追加
    20. iPad Pro 13" Front Camera Assembly Replacement, Connect the display cables: 手順 61、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Connect the display cables: 手順 61、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Connect the display cables: 手順 61、 3の画像 3
      • Repeat the same procedure to connect the two remaining display cables.
      FixBotに聞いてみる
      コメントを追加
    21. iPad Pro 13" Front Camera Assembly Replacement, Install the display connectors cover: 手順 62、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the display connectors cover: 手順 62、 2の画像 2
      • Set the display connectors cover onto the logic board so it's aligned with its screw holes.
      FixBotに聞いてみる
      コメントを追加
    22. iPad Pro 13" Front Camera Assembly Replacement, Install the display connectors cover screws: 手順 63、 1の画像 1
      • Use a JCIS or JIS 00 screwdriver to install the six screws securing the display connectors cover:
      FixBotに聞いてみる
      コメントを追加
    23. iPad Pro 13" Front Camera Assembly Replacement, Remove the final adhesive liners: 手順 64、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the final adhesive liners: 手順 64、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Remove the final adhesive liners: 手順 64、 3の画像 3
      • Use tweezers or your fingers to remove the final, blue liners off the iPad screen adhesive.
      FixBotに聞いてみる
      コメントを追加
    24. iPad Pro 13" Front Camera Assembly Replacement: 手順 65、 1の画像 1
      • Verify all the adhesive liners are removed. The adhesive is now exposed.
      FixBotに聞いてみる
      コメントを追加
    25. iPad Pro 13" Front Camera Assembly Replacement, Remove the cloth: 手順 66、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Remove the cloth: 手順 66、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Remove the cloth: 手順 66、 3の画像 3
      • Without touching the adhesive, slightly lift the iPad screen and remove the cloth between it and the iPad.
      FixBotに聞いてみる
      コメントを追加
    26. iPad Pro 13" Front Camera Assembly Replacement, Set the screen down at an angle: 手順 67、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Set the screen down at an angle: 手順 67、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Set the screen down at an angle: 手順 67、 3の画像 3
      • Don't align the iPad screen with the frame yet—the front sensor assembly still needs to be connected.
      • Flip the iPad screen over and set it down at a slight angle on top of the iPad frame.
      FixBotに聞いてみる
      コメントを追加
    27. iPad Pro 13" Front Camera Assembly Replacement, Connect the front sensor assembly: 手順 68、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Connect the front sensor assembly: 手順 68、 2の画像 2
      • Be careful not to strain the microphone cable while connecting it. If it doesn't reach, lower the screen until it does.
      • Hover the top of the screen over the microphone connector's socket on the board.
      • Use the flat end of a spudger or your finger to connect the microphone press connector to its socket on the board (located next to the front camera assembly).
      FixBotに聞いてみる
      コメントを追加
    28. iPad Pro 13" Front Camera Assembly Replacement, Install the microphone connector cover: 手順 69、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the microphone connector cover: 手順 69、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Install the microphone connector cover: 手順 69、 3の画像 3
      • Use tweezers to install the microphone connector cover into its slot beneath the front camera assembly bracket.
      • Set the cover down so it's aligned with its screw hole.
      • The cover may try to stick to the magnets next to it. Keep it in place for the next step.
      FixBotに聞いてみる
      コメントを追加
    29. iPad Pro 13" Front Camera Assembly Replacement: 手順 70、 1の画像 1
      • Use a JCIS or JIS 00 screwdriver to install the 1.3 mm‑long screw securing the microphone connector cover.
      FixBotに聞いてみる
      コメントを追加
    30. iPad Pro 13" Front Camera Assembly Replacement, Install the screen: 手順 71、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Install the screen: 手順 71、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement, Install the screen: 手順 71、 3の画像 3
      • Carefully align the bottom edge of the screen with the bottom edge of the iPad.
      • Position the screen so it sits into the lip on the edge of the iPad.
      • Before closing up the display, check to make sure that no cables are trapped beneath the screen. If they are, lift the top edge slightly (without straining the microphone cable), reposition the screen, and try again.
      FixBotに聞いてみる
      コメントを追加
    31. iPad Pro 13" Front Camera Assembly Replacement: 手順 72、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 72、 2の画像 2
      • Lower the screen into place, ensuring the screen's bottom edge stays flush with the bottom edge of the iPad.
      FixBotに聞いてみる
      コメントを追加
    32. iPad Pro 13" Front Camera Assembly Replacement: 手順 73、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 73、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 73、 3の画像 3
      • Press down across the bottom edge, then across the entire perimeter of the screen so it sits flush.
      FixBotに聞いてみる
      コメントを追加
    33. iPad Pro 13" Front Camera Assembly Replacement, Heat the screen: 手順 74、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Heat the screen: 手順 74、 2の画像 2
      • To help the adhesive bond, apply heat to all four edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      FixBotに聞いてみる
      コメントを追加
    34. iPad Pro 13" Front Camera Assembly Replacement, Press the screen adhesive: 手順 75、 2の画像 1 iPad Pro 13" Front Camera Assembly Replacement, Press the screen adhesive: 手順 75、 2の画像 2
      • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of the iPad. You can compensate for the camera bump by laying the iPad face-down and placing coins around its perimeter.
      • Alternatively, you can use screen vise clamps around the perimeter of your device to set the new adhesive.
      • Place the iPad screen-side-down on a soft, flat surface.
      • Apply tape to the back to protect its finish.
      FixBotに聞いてみる
      コメントを追加
    35. iPad Pro 13" Front Camera Assembly Replacement: 手順 76、 3の画像 1 iPad Pro 13" Front Camera Assembly Replacement: 手順 76、 3の画像 2 iPad Pro 13" Front Camera Assembly Replacement: 手順 76、 3の画像 3
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Stack them to a consistent height taller than the camera bump.
      FixBotに聞いてみる
      コメントを追加
    36. iPad Pro 13" Front Camera Assembly Replacement: 手順 77、 1の画像 1
      • Stack multiple books or other heavy objects on the iPad.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      FixBotに聞いてみる
      コメントを追加
終わりに
Calibrate the replacement front camera assembly using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 13" Answers Community for help.
キャンセル: このガイドを終了できませんでした。
Nick Schultz
メンバー登録日: 03/24/24
59,558 ポイント
318のガイドは作成済み
1件のガイドコメント
can you replace the front camera with any part without loosing Face ID? Or do you need to pair it with software or programmer…
paulplijnaar - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 44
今までの合計 279
