メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad 9 LTE Button Control Cable Replacement
必要な工具と部品
    1. iPad 9  LTE Button Control Cable Replacement, Heat the left edge: 手順 1、 1の画像 1
      • Power down your iPad before beginning the repair.
      • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
      FixBotに聞いてみる
      コメントを追加
    2. iPad 9  LTE Button Control Cable Replacement, Screen removal information: 手順 2、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Screen removal information: 手順 2、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Screen removal information: 手順 2、 3の画像 3
      • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
      • Front camera
      • Ambient light sensors
      • Antennas
      • Display cables
      FixBotに聞いてみる
      コメントを追加
    3. iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: 手順 3、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: 手順 3、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: 手順 3、 3の画像 3
      この手順で使用する道具:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      FixBotに聞いてみる
      コメントを追加
    4. iPad 9  LTE Button Control Cable Replacement: 手順 4、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 4、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 4、 3の画像 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      FixBotに聞いてみる
      コメントを追加
    5. iPad 9  LTE Button Control Cable Replacement: 手順 5、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 5、 2の画像 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      FixBotに聞いてみる
      コメントを追加
    6. iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: 手順 6、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: 手順 6、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: 手順 6、 3の画像 3
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
      • Insert an opening pick into the gap between the digitizer and the frame.
      FixBotに聞いてみる
      コメントを追加
    7. iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: 手順 7、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: 手順 7、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: 手順 7、 3の画像 3
      • Insert a second opening pick into the gap you just created.
      • Slide the pick toward the bottom-left corner of the iPad to separate the adhesive.
      • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
      • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
      FixBotに聞いてみる
      コメントを追加
    8. iPad 9  LTE Button Control Cable Replacement: 手順 8、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 8、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 8、 3の画像 3
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
      FixBotに聞いてみる
      コメントを追加
    9. iPad 9  LTE Button Control Cable Replacement: 手順 9、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 9、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 9、 3の画像 3
      • Slide the first opening pick towards to top-left corner of the iPad to separate the adhesive.
      • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
      FixBotに聞いてみる
      コメントを追加
    10. iPad 9  LTE Button Control Cable Replacement, Heat the top edge: 手順 10、 1の画像 1
      • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
      FixBotに聞いてみる
      コメントを追加
    11. iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: 手順 11、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: 手順 11、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: 手順 11、 3の画像 3
      • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
      • Only insert the pick up to 7 mm to avoid damaging the ambient light sensor.
      FixBotに聞いてみる
      コメントを追加
    12. iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: 手順 12、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: 手順 12、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: 手順 12、 3の画像 3
      • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
      • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
      FixBotに聞いてみる
      コメントを追加
    13. iPad 9  LTE Button Control Cable Replacement: 手順 13、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 13、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 13、 3の画像 3
      • Pull the pick out until only the tip is between the digitizer and the frame.
      • Slide the pick above the front camera to separate the adhesive.
      • Leave the pick near the right side of the front camera before continuing.
      FixBotに聞いてみる
      コメントを追加
    14. iPad 9  LTE Button Control Cable Replacement: 手順 14、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 14、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 14、 3の画像 3
      • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
      • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
      FixBotに聞いてみる
      コメントを追加
    15. iPad 9  LTE Button Control Cable Replacement, Heat the right edge: 手順 15、 1の画像 1
      • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
      FixBotに聞いてみる
      コメントを追加
    16. iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: 手順 16、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: 手順 16、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: 手順 16、 3の画像 3
      • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
      • Only insert the pick up to 4 mm to avoid damaging the ambient light sensor.
      FixBotに聞いてみる
      コメントを追加
    17. iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: 手順 17、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: 手順 17、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: 手順 17、 3の画像 3
      • Insert a new opening pick and slide it to the middle of the iPad's right edge.
      • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
      FixBotに聞いてみる
      コメントを追加
    18. iPad 9  LTE Button Control Cable Replacement, Heat the bottom edge: 手順 18、 1の画像 1
      • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
      FixBotに聞いてみる
      コメントを追加
    19. iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: 手順 19、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: 手順 19、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: 手順 19、 3の画像 3
      • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
      • Don't fully rotate the pick around the corner, as you may damage the antenna.
      • The third image shows the bottom-left antenna underneath the digitizer.
      • Leave the pick in the corner before moving to the next step.
      FixBotに聞いてみる
      コメントを追加
    20. iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: 手順 20、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: 手順 20、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: 手順 20、 3の画像 3
      • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
      • Slide the pick over the antenna, stopping just before the home button.
      • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
      • Leave the pick to the left of the home button before continuing.
      FixBotに聞いてみる
      コメントを追加
    21. iPad 9  LTE Button Control Cable Replacement: 手順 21、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 21、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 21、 3の画像 3
      • Insert an opening pick into the gap you just created.
      • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
      FixBotに聞いてみる
      コメントを追加
    22. iPad 9  LTE Button Control Cable Replacement: 手順 22、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 22、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 22、 3の画像 3
      • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
      • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
      • Leave the pick to the right of the home button before continuing.
      FixBotに聞いてみる
      コメントを追加
    23. iPad 9  LTE Button Control Cable Replacement, Heat the right edge: 手順 23、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    24. iPad 9  LTE Button Control Cable Replacement: 手順 24、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 24、 2の画像 2
      • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
      • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
      • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
      FixBotに聞いてみる
      コメントを追加
    25. iPad 9  LTE Button Control Cable Replacement: 手順 25、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 25、 2の画像 2
      • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
      FixBotに聞いてみる
      コメントを追加
    26. iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: 手順 26、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: 手順 26、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: 手順 26、 3の画像 3
      FixBotに聞いてみる
      コメントを追加
    27. iPad 9  LTE Button Control Cable Replacement: 手順 27、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 27、 2の画像 2
      • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
      • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
      • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
      FixBotに聞いてみる
      コメントを追加
    1. iPad 9  LTE Button Control Cable Replacement, Remove the LCD: 手順 28、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: 手順 28、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: 手順 28、 3の画像 3
      この手順で使用する道具:
      • Use tweezers, or your fingers, to remove any tape covering the LCD screws.
      FixBotに聞いてみる
      コメントを追加
    2. iPad 9  LTE Button Control Cable Replacement, Unfasten the LCD screen: 手順 29、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Unfasten the LCD screen: 手順 29、 2の画像 2
      • Use a Phillips #00 screwdriver to remove the four 4.2 mm screws securing the LCD screen.
      FixBotに聞いてみる
      コメントを追加
    3. iPad 9  LTE Button Control Cable Replacement, Separate the LCD's adhesive: 手順 30、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Separate the LCD's adhesive: 手順 30、 2の画像 2
      • The LCD is lightly adhered to the frame.
      • Insert a spudger between the frame and the top-right portion of the LCD.
      • Pry slowly with the spudger to separate the adhesive.
      FixBotに聞いてみる
      コメントを追加
    4. iPad 9  LTE Button Control Cable Replacement: 手順 31、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 31、 2の画像 2
      • Repeat the previous step for the top-left portion of the LCD.
      FixBotに聞いてみる
      コメントを追加
    5. iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: 手順 32、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: 手順 32、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: 手順 32、 3の画像 3
      • Don't attempt to fully remove the LCD during this step, as it's still connected by a flex cable.
      • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
      • Flip the LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
      • Lay the LCD on a clean, soft, lint-free surface to allow access to the display cables.
      FixBotに聞いてみる
      コメントを追加
    6. iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: 手順 33、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: 手順 33、 2の画像 2
      • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
      FixBotに聞いてみる
      コメントを追加
    7. iPad 9  LTE Button Control Cable Replacement, Battery connector information: 手順 34、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Battery connector information: 手順 34、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Battery connector information: 手順 34、 3の画像 3
      • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
      • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
      FixBotに聞いてみる
      コメントを追加
    8. iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: 手順 35、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: 手順 35、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: 手順 35、 3の画像 3
      • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
      • Ensure that the iFixit logo on the battery blocker is facing up.
      • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
      • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
      • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
      • Leave the battery blocker in place as you work.
      FixBotに聞いてみる
      コメントを追加
    9. iPad 9  LTE Button Control Cable Replacement, Unfasten the display cable bracket: 手順 36、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Unfasten the display cable bracket: 手順 36、 2の画像 2
      • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
      FixBotに聞いてみる
      コメントを追加
    10. iPad 9  LTE Button Control Cable Replacement, Remove the display cable bracket: 手順 37、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the display cable bracket: 手順 37、 2の画像 2
      • Remove the display cable bracket.
      FixBotに聞いてみる
      コメントを追加
    11. iPad 9  LTE Button Control Cable Replacement, Disconnect the LCD: 手順 38、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the LCD: 手順 38、 2の画像 2
      • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      FixBotに聞いてみる
      コメントを追加
    12. iPad 9  LTE Button Control Cable Replacement, Remove the LCD: 手順 39、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: 手順 39、 2の画像 2
      • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
      FixBotに聞いてみる
      コメントを追加
    1. iPad 9  LTE Button Control Cable Replacement, Disconnect the home button: 手順 40、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the home button: 手順 40、 2の画像 2
      この手順で使用する道具:
      • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
      FixBotに聞いてみる
      コメントを追加
    2. iPad 9  LTE Button Control Cable Replacement: 手順 41、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 41、 2の画像 2
      • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
      FixBotに聞いてみる
      コメントを追加
    3. iPad 9  LTE Button Control Cable Replacement: 手順 42、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 42、 2の画像 2
      • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
      FixBotに聞いてみる
      コメントを追加
    4. iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: 手順 43、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: 手順 43、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: 手順 43、 3の画像 3
      • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
      • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
      FixBotに聞いてみる
      コメントを追加
    5. iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: 手順 44、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: 手順 44、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: 手順 44、 3の画像 3
      • Use the flat end of a spudger to pry up the buffer block near the bottom-right corner of the iPad.
      • Take care not to puncture or tear the home button ribbon cable.
      • Remove the buffer block.
      FixBotに聞いてみる
      コメントを追加
    6. iPad 9  LTE Button Control Cable Replacement: 手順 45、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 45、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 45、 3の画像 3
      • The home button cable is secured with some light adhesive.
      • Use a pair of tweezers to peel the home button cable away from the frame.
      FixBotに聞いてみる
      コメントを追加
    7. iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: 手順 46、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: 手順 46、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: 手順 46、 3の画像 3
      この手順で使用する道具:
      Polyimide Tape
      $9.95
      • Remove the front panel assembly.
      • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
      • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
      • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
      • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
      • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
      • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
      FixBotに聞いてみる
      コメントを追加
    1. iPad 9  LTE Button Control Cable Replacement, Remove the upper bracket tape: 手順 47、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the upper bracket tape: 手順 47、 2の画像 2
      • Carefully peel the LCD buffer tape from the upper component bracket.
      FixBotに聞いてみる
      コメントを追加
    2. iPad 9  LTE Button Control Cable Replacement, Unfasten the upper component bracket: 手順 48、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Unfasten the upper component bracket: 手順 48、 2の画像 2
      • Use a Phillips #00 screwdriver to remove the five screws securing the the upper component bracket:
      • Three 1.4 mm-long screws
      • Two 1.9 mm-long screws
      FixBotに聞いてみる
      コメントを追加
    3. iPad 9  LTE Button Control Cable Replacement, Remove the upper component bracket: 手順 49、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the upper component bracket: 手順 49、 2の画像 2
      • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
      FixBotに聞いてみる
      コメントを追加
    4. iPad 9  LTE Button Control Cable Replacement: 手順 50、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 50、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 50、 3の画像 3
      • Use your fingers to peel the upper component bracket away from the tape.
      • Remove the upper component bracket.
      FixBotに聞いてみる
      コメントを追加
    1. iPad 9  LTE Button Control Cable Replacement, Disconnect the rear camera: 手順 51、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the rear camera: 手順 51、 2の画像 2
      • Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
      FixBotに聞いてみる
      コメントを追加
    2. iPad 9  LTE Button Control Cable Replacement, Heat the rear camera: 手順 52、 1の画像 1
      • Heat an iOpener and apply it to the rear camera for thirty seconds.
      FixBotに聞いてみる
      コメントを追加
    3. iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: 手順 53、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: 手順 53、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: 手順 53、 3の画像 3
      この手順で使用する道具:
      • Use a spudger to pry the rear camera out of the frame.
      • Use tweezers, or your fingers, to remove the rear camera.
      FixBotに聞いてみる
      コメントを追加
    1. iPad 9  LTE Button Control Cable Replacement, Disconnect the right ambient light sensor: 手順 54、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the right ambient light sensor: 手順 54、 2の画像 2
      この手順で使用する道具:
      • The right ambient light sensor is lightly adhered to the frame.
      • Use tweezers, or your fingers, to remove the sensor.
      FixBotに聞いてみる
      コメントを追加
    2. iPad 9  LTE Button Control Cable Replacement, Reposition the right ambient light sensor: 手順 55、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Reposition the right ambient light sensor: 手順 55、 2の画像 2
      • Peel the right ambient light sensor towards the right edge of the device, enough to access the screw behind it.
      FixBotに聞いてみる
      コメントを追加
    3. iPad 9  LTE Button Control Cable Replacement, Unfasten the power button bracket: 手順 56、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Unfasten the power button bracket: 手順 56、 2の画像 2
      • Use a Phillips screwdriver to remove the two 2.3 mm-long screws securing the lock button bracket.
      FixBotに聞いてみる
      コメントを追加
    4. iPad 9  LTE Button Control Cable Replacement, Reposition the button control cable: 手順 57、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Reposition the button control cable: 手順 57、 2の画像 2
      • Use your fingers to pull the power button bracket out of its recess.
      FixBotに聞いてみる
      コメントを追加
    5. iPad 9  LTE Button Control Cable Replacement: 手順 58、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 58、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 58、 3の画像 3
      • The button control cable is lightly adhered to the side of the volume button bracket.
      • Peel the button control cable away from the volume button bracket.
      FixBotに聞いてみる
      コメントを追加
    6. iPad 9  LTE Button Control Cable Replacement, Unfasten the volume button bracket: 手順 59、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Unfasten the volume button bracket: 手順 59、 2の画像 2
      • Use a Phillips screwdriver to remove the two 2.2 mm-long screws securing the volume button bracket to the rear case.
      FixBotに聞いてみる
      コメントを追加
    7. iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: 手順 60、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: 手順 60、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: 手順 60、 3の画像 3
      • Use tweezers, or your fingers, to pull the volume button bracket away from the device's edge.
      • Remove the volume button bracket.
      FixBotに聞いてみる
      コメントを追加
    8. iPad 9  LTE Button Control Cable Replacement, Disconnect the button control cable: 手順 61、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Disconnect the button control cable: 手順 61、 2の画像 2
      • Peel off any tape covering the button control cable ZIF connector.
      FixBotに聞いてみる
      コメントを追加
    9. iPad 9  LTE Button Control Cable Replacement: 手順 62、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 62、 2の画像 2
      • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable's ZIF connector.
      FixBotに聞いてみる
      コメントを追加
    10. iPad 9  LTE Button Control Cable Replacement: 手順 63、 2の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 63、 2の画像 2
      • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
      FixBotに聞いてみる
      コメントを追加
    11. iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: 手順 64、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: 手順 64、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: 手順 64、 3の画像 3
      • Use the flat end of a spudger to push the volume buttons out of their slots in the rear case.
      FixBotに聞いてみる
      コメントを追加
    12. iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: 手順 65、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: 手順 65、 2の画像 2
      • Remove the button control cable.
      • The lock button will become loose once the button control cable is removed.
      • Upon reassembly, remember to set the power button back into the its slot.
      FixBotに聞いてみる
      コメントを追加
    13. iPad 9  LTE Button Control Cable Replacement, Loosen the adhesive: 手順 66、 2の画像 1 iPad 9  LTE Button Control Cable Replacement, Loosen the adhesive: 手順 66、 2の画像 2
      • Heat an iOpener and apply it to the button control cable for thirty seconds.
      FixBotに聞いてみる
      コメントを追加
    14. iPad 9  LTE Button Control Cable Replacement, Remove the buttons: 手順 67、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the buttons: 手順 67、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the buttons: 手順 67、 3の画像 3
      • Use a pair of tweezers to grip the upper volume button.
      • Insert an opening pick between the volume control cable and the upper volume button.
      • Peel the volume control cable off of the upper volume button.
      FixBotに聞いてみる
      コメントを追加
    15. iPad 9  LTE Button Control Cable Replacement: 手順 68、 3の画像 1 iPad 9  LTE Button Control Cable Replacement: 手順 68、 3の画像 2 iPad 9  LTE Button Control Cable Replacement: 手順 68、 3の画像 3
      • Repeat the same process to peel the volume control cable off of the lower volume button.
      FixBotに聞いてみる
      コメントを追加
    16. iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: 手順 69、 3の画像 1 iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: 手順 69、 3の画像 2 iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: 手順 69、 3の画像 3
      この手順で使用する道具:
      Tesa 61395 Tape
      $8.95
      • Use a pair of tweezers to grip the power button bracket.
      • Insert a halberd spudger or opening pick between the power button bracket and the button control cable.
      • Peel the button control cable up and off of the pegs on the power button bracket.
      • Upon reassembly, apply Tesa tape to reattach the volume buttons and lock button bracket to the button control cable.
      FixBotに聞いてみる
      コメントを追加
    17. iPad 9  LTE Button Control Cable Replacement: 手順 70、 1の画像 1
      • Only the button control cable remains.
      FixBotに聞いてみる
      コメントを追加
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 9 Answers community for help.
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
247,177 ポイント
1,203のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
65,748のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 45
今までの合計 1,059
