メインコンテンツにスキップ
Motorola Edge Display Panel Replacement
Jennifer Berg
Jennifer Berg とその他 2 人の作成者
最終更新日: May 15, 2023
1 - 2 時間
難しい
Follow this guide to remove and replace the display assembly on a Motorola Edge.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
You’ll need to remove the battery in order to replace the display. If the battery is deformed, dented, or damaged in any way, do not reinstall it. Reinstalling a damaged battery is a potential safety hazard.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: Some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. If you have that type of screen, follow this guide instead.
必要な工具と部品
パーツ
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Motorola Edge Display Panel Replacement, Find the SIM tray: 手順 1、 1の画像 1
    • Find the SIM tray located at the top of the phone.
  2. Motorola Edge Display Panel Replacement, Eject the SIM tray: 手順 2、 2の画像 1 Motorola Edge Display Panel Replacement, Eject the SIM tray: 手順 2、 2の画像 2
    • Insert a SIM eject tool or SIM eject bit into the small hole in the SIM card tray.
    • If the tool you're using doesn't fit, don't force it. Forcing a tool may cause it to get stuck or break inside the ejection port.
    • Press to eject the tray.
  3. Motorola Edge Display Panel Replacement, Remove the SIM card tray assembly: 手順 3、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the SIM card tray assembly: 手順 3、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the SIM card tray assembly: 手順 3、 3の画像 3
    • Remove the SIM card tray from the phone.
  4. Motorola Edge Display Panel Replacement, Heat the bottom edge: 手順 4、 1の画像 1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  5. Motorola Edge Display Panel Replacement, Separate the bottom adhesive: 手順 5、 3の画像 1 Motorola Edge Display Panel Replacement, Separate the bottom adhesive: 手順 5、 3の画像 2 Motorola Edge Display Panel Replacement, Separate the bottom adhesive: 手順 5、 3の画像 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  6. Motorola Edge Display Panel Replacement, Slice the bottom adhesive: 手順 6、 3の画像 1 Motorola Edge Display Panel Replacement, Slice the bottom adhesive: 手順 6、 3の画像 2 Motorola Edge Display Panel Replacement, Slice the bottom adhesive: 手順 6、 3の画像 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  7. Motorola Edge Display Panel Replacement, Heat the right edge: 手順 7、 1の画像 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Motorola Edge Display Panel Replacement, Separate the corner adhesive: 手順 8、 3の画像 1 Motorola Edge Display Panel Replacement, Separate the corner adhesive: 手順 8、 3の画像 2 Motorola Edge Display Panel Replacement, Separate the corner adhesive: 手順 8、 3の画像 3
    • Rotate the opening pick around the bottom-right corner of the phone.
  9. Motorola Edge Display Panel Replacement, Separate the right adhesive: 手順 9、 3の画像 1 Motorola Edge Display Panel Replacement, Separate the right adhesive: 手順 9、 3の画像 2 Motorola Edge Display Panel Replacement, Separate the right adhesive: 手順 9、 3の画像 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  10. Motorola Edge Display Panel Replacement, Remove the back cover: 手順 10、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the back cover: 手順 10、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the back cover: 手順 10、 3の画像 3
    • Remove the back cover, taking care not to damage the components inside the phone.
  11. Motorola Edge Display Panel Replacement, Remove the motherboard's screws: 手順 11、 1の画像 1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  12. Motorola Edge Display Panel Replacement, Remove the motherboard cover: 手順 12、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the motherboard cover: 手順 12、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the motherboard cover: 手順 12、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  13. Motorola Edge Display Panel Replacement, Disconnect the battery cable's press connector: 手順 13、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the battery cable's press connector: 手順 13、 2の画像 2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. Motorola Edge Display Panel Replacement, Remove the daughterboard's t5 screws: 手順 14、 2の画像 1 Motorola Edge Display Panel Replacement, Remove the daughterboard's t5 screws: 手順 14、 2の画像 2
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  15. Motorola Edge Display Panel Replacement, Remove the daughterboard cover: 手順 15、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the daughterboard cover: 手順 15、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the daughterboard cover: 手順 15、 3の画像 3
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
  16. Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the motherboard: 手順 16、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the motherboard: 手順 16、 2の画像 2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
  17. Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the daughterboard: 手順 17、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the interconnect cable from the daughterboard: 手順 17、 2の画像 2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  18. Motorola Edge Display Panel Replacement, Remove the interconnect cable: 手順 18、 2の画像 1 Motorola Edge Display Panel Replacement, Remove the interconnect cable: 手順 18、 2の画像 2
    • Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
  19. Motorola Edge Display Panel Replacement, Remove the copper tape: 手順 19、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the copper tape: 手順 19、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the copper tape: 手順 19、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt tweezers to peel up and remove the copper tape covering the front camera ribbon cable.
  20. Motorola Edge Display Panel Replacement, Remove the front camera cable's press connector: 手順 20、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the front camera cable's press connector: 手順 20、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the front camera cable's press connector: 手順 20、 3の画像 3
    • Use a spudger to pry up the front camera cable's press connector and disconnect it from the motherboard.
    • Remove the front camera.
  21. Motorola Edge Display Panel Replacement, Remove the wide angle camera's press connector: 手順 21、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the wide angle camera's press connector: 手順 21、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the wide angle camera's press connector: 手順 21、 3の画像 3
    • Use a spudger to pry up the wide angle camera cable's press connector and disconnect it from the motherboard.
    • Remove the wide angle camera.
  22. Motorola Edge Display Panel Replacement, Remove the main camera cable's press connector: 手順 22、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the main camera cable's press connector: 手順 22、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the main camera cable's press connector: 手順 22、 3の画像 3
    • Use a spudger to pry up the main camera cable's press connector and disconnect it from the motherboard.
    • Remove the main camera.
  23. Motorola Edge Display Panel Replacement, Remove the telephoto camera's press connector: 手順 23、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the telephoto camera's press connector: 手順 23、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the telephoto camera's press connector: 手順 23、 3の画像 3
    • Use a spudger to pry up and disconnect the telephoto camera cable's press connector from the motherboard.
    • Remove the telephoto camera.
  24. Motorola Edge Display Panel Replacement, Disconnect the screen ribbon cable's press connector: 手順 24、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the screen ribbon cable's press connector: 手順 24、 2の画像 2
    • Use a spudger to pry up and disconnect the screen ribbon cable's press connector from the motherboard.
  25. Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: 手順 25、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: 手順 25、 2の画像 2
    • Use a spudger to pry up the black coaxial cable and detach it from the motherboard.
  26. Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: 手順 26、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: 手順 26、 2の画像 2
    • Use a spudger to pry up the white coaxial cable and detach it from the motherboard.
  27. Motorola Edge Display Panel Replacement, Remove the motherboard: 手順 27、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the motherboard: 手順 27、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the motherboard: 手順 27、 3の画像 3
    • Use a spudger to pry up and remove the motherboard.
    • Make sure no cables get trapped under the motherboard during reassembly.
  28. Motorola Edge Display Panel Replacement, Disconnect the fingerprint sensor cable's press connector: 手順 28、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the fingerprint sensor cable's press connector: 手順 28、 2の画像 2
    • Use a spudger to pry up the fingerprint sensor cable's press connector and disconnect it from the daughterboard.
  29. Motorola Edge Display Panel Replacement, Remove the daughterboard screw: 手順 29、 2の画像 1 Motorola Edge Display Panel Replacement, Remove the daughterboard screw: 手順 29、 2の画像 2
    • Use a T5 Torx screwdriver to remove the single 3.2 mm screw securing the daughterboard.
  30. Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: 手順 30、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the black coaxial cable: 手順 30、 2の画像 2
    • Use a spudger to pry up the black coaxial cable and detach it from the daughterboard.
  31. Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: 手順 31、 2の画像 1 Motorola Edge Display Panel Replacement, Disconnect the white coaxial cable: 手順 31、 2の画像 2
    • Use a spudger to pry up the white coaxial cable and disconnect it from the daughterboard.
  32. Motorola Edge Display Panel Replacement, Remove the daughterboard: 手順 32、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the daughterboard: 手順 32、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the daughterboard: 手順 32、 3の画像 3
    • Use a spudger to pry up and separate the daughterboard from the rest of the phone.
    • When removing and replacing the daughterboard, be careful not to damage any of the cables that attach to it.
  33. Motorola Edge Display Panel Replacement, Weaken the battery's adhesive: 手順 33、 1の画像 1
    • Heat an iOpener and place it on the screen for two minutes in order to loosen the adhesive on the battery.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  34. Motorola Edge Display Panel Replacement, Create a gap between the battery and the frame: 手順 34、 2の画像 1 Motorola Edge Display Panel Replacement, Create a gap between the battery and the frame: 手順 34、 2の画像 2
    • Wedge the pointed end of an opening pick between the right side of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Be careful not to damage the screen's ribbon cable, which is located underneath the battery.
  35. Motorola Edge Display Panel Replacement, Switch to a plastic card: 手順 35、 3の画像 1 Motorola Edge Display Panel Replacement, Switch to a plastic card: 手順 35、 3の画像 2 Motorola Edge Display Panel Replacement, Switch to a plastic card: 手順 35、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • After making a gap between the battery and the frame, replace the opening pick with a plastic card.
    • A plastic card will help ensure that the battery is not bent or damaged while being removed.
  36. Motorola Edge Display Panel Replacement, Cut through the battery's adhesive: 手順 36、 3の画像 1 Motorola Edge Display Panel Replacement, Cut through the battery's adhesive: 手順 36、 3の画像 2 Motorola Edge Display Panel Replacement, Cut through the battery's adhesive: 手順 36、 3の画像 3
    • Carefully slide a plastic card underneath the battery to cut through the adhesive.
  37. Motorola Edge Display Panel Replacement, Remove the battery: 手順 37、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the battery: 手順 37、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the battery: 手順 37、 3の画像 3
    • Slide a plastic card under the battery, then carefully lift the battery up until the adhesive is loose enough to remove the battery.
  38. Motorola Edge Display Panel Replacement: 手順 38、 3の画像 1 Motorola Edge Display Panel Replacement: 手順 38、 3の画像 2 Motorola Edge Display Panel Replacement: 手順 38、 3の画像 3
    • Separate and remove the battery from the midframe.
    • If the battery is deformed, dented, or damaged in any way, don't reinstall it. Reinstalling a damaged battery is a potential safety hazard. Replace it with a new one.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the battery.
  39. Motorola Edge Display Panel Replacement, Remove the midframe: 手順 39、 3の画像 1 Motorola Edge Display Panel Replacement, Remove the midframe: 手順 39、 3の画像 2 Motorola Edge Display Panel Replacement, Remove the midframe: 手順 39、 3の画像 3
    • Turn the phone over and remove the midframe while gently threading the screen ribbon cable through the opening in the midframe.
  40. Motorola Edge Display Panel Replacement, Replace the display panel: 手順 40、 1の画像 1
    • All that remains is the display panel.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jennifer Berg
メンバー登録日: 03/21/22
2,751 ポイント
24のガイドは作成済み
コメント 1 件
Hallo, das ausbauen ist wirklich sehr gut dokumentiert und gut nachvollziehbar...Super.
Zum zusammenbauen wären vielleicht noch einige Infos hilfreich. Z.B. das Wiederverkleben.
Mit welchem Kleber und mit welchem Werkzeug kann ich die verklebten Elemente fixieren.
Frage: zu welchem Zweck brauche ich das beidseitig klebende Tesa-Band?
LG Peter
Peter Wollstadt - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 40
今までの合計 2,964
