メインコンテンツにスキップ
iPhone X ディスプレイアセンブリの交換
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. iPhone X ディスプレイアセンブリの交換, ペンタローブネジ: 手順 1、 1の画像 1
    • 作業開始前にiPhoneのバッテリーを25%以下まで放電してください。充電されたリチウムイオンバッテリーは、穴が空いた場合、引火や爆発の恐れがあります。
    • 分解を始める前に、iPhoneの電源を切ってください。
    • iPhone下部底面に留められた2本の6.9㎜ロングタイプのペンタローブネジを取り外します。
    • ネジが潰れたり、ダメージが入った場合は、交換してください
    • iPhoneのディスプレイを開口することにより、ディスプレイの耐水シールが破損します。このステップを進める前に交換用のシールを用意しておくか、耐水シールの交換をしないで再組み立てする場合は液体の浸水に注意してください。
    There are 6.81mm long screws!
    Daniel - 返信
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - 返信
    same situation here
    kaunomarcius - 返信
    Same issue for me too, how do I get the stripped screw out?
    patronics - 返信
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    patronics - 返信
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - 返信
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - 返信
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - 返信
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - 返信
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - 返信
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - 返信
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - 返信
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - 返信
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - 返信
  2. iPhone X ディスプレイアセンブリの交換, ひび割れた画面の上にテープを貼る: 手順 2、 3の画像 1 iPhone X ディスプレイアセンブリの交換, ひび割れた画面の上にテープを貼る: 手順 2、 3の画像 2 iPhone X ディスプレイアセンブリの交換, ひび割れた画面の上にテープを貼る: 手順 2、 3の画像 3
    • iPhoneの画面が割れてしまった場合、ガラスをテーピングで覆えば、さらなる破損の広がりを抑えることができます。また修理中に発生するアクシデントを防ぐことができます。
    • iPhoneの画面全体に、透明な梱包用テープを重ね合わせます。
    • 作業中、飛散する可能性のあるガラスから目を保護するため、安全眼鏡を着用してください。
    • 次の手順でうまく吸盤が装着しない場合は、強力なテープ(ガムテープなど)を持ち手に折って、代わりにスクリーンを持ち上げてみてください。
    • それでもうまくいかない場合は、吸盤カップに瞬間接着剤をつけて、スクリーン上に貼り付けてください。
  3. iPhone X ディスプレイアセンブリの交換, リバースクランプの使用方法: 手順 3、 3の画像 1 iPhone X ディスプレイアセンブリの交換, リバースクランプの使用方法: 手順 3、 3の画像 2 iPhone X ディスプレイアセンブリの交換, リバースクランプの使用方法: 手順 3、 3の画像 3
    この手順で使用する道具:
    Clampy - Anti-Clamp
    $24.95
    • 次の3つの手順では、デバイスの開口作業を簡単にするために開発されたツール、リバースクランプの使い方を紹介します。リバースクランプを使用しない場合は、この3つの手順をスキップして別の方法をご覧ください。
    • リバースクランプの詳細な使用方法については、 こちらのガイドをご覧ください。
    • 青いハンドルをヒンジ側に引くと、リバースクランプのアームを解除します。
    • 吸盤は、スクリーンのホームボタンのすぐ上に、前面と背面側に1つずつ装着します。
    • 吸盤カップ両側をしっかりと締め合わせると、標的の場所にしっかりと装着させることができます。
    • デバイスの表面が滑りやすく、リバースクランプがしっかりと装着できない場合は、 梱包用テープで表面を覆ってから、強いグリップを作ることができます。
  4. iPhone X ディスプレイアセンブリの交換: 手順 4、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 4、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 4、 3の画像 3
    • 青いハンドルをヒンジ側に引くと、リバースクランのアームを解除します。
    • ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
    • 吸盤の位置が合っていることを確認してください。位置がずれてきた場合は、吸盤を少し緩めてアームの位置を合わせてください。
  5. iPhone X ディスプレイアセンブリの交換: 手順 5、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 5、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 5、 3の画像 3
    • iOpenerを温めて、Anti-Clampのアームに通します。
    • ドライヤーヒートガン、ホットプレートなどを使うこともできますが、極端に熱くするとディスプレイや内蔵バッテリーにダメージを与えることがありますので、注意してください。
    • iOpenerを半分に折って、iPhoneの下端に重ねます。
    • 1分ほど待つと接着剤が剥がれ、隙間ができます。
    • スクリーンそのものではなく、スクリーンとプラスチックベゼルの下にオープニングピックを挿入します。
    • リバースクランプで十分な隙間ができない場合は、その部分にさらに熱を加えて、ハンドルを時計回りに半回転させてください。
    • 一度に半回転以上回さず、1分ほど待ってからさらに半回転、回します。時間をかけてリバースクランプを回していきます。
    • 次の3つの手順をスキップしてください。
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 返信
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  6. iPhone X ディスプレイアセンブリの交換: 手順 6、 1の画像 1
    • iPhoneの下側端を温めるとディスプレイに留められた圧着材を柔らかくでき、開口作業がスムーズになります。
    • ヘアドライヤーヒートガンまたはiOpener を準備してiPhoneの下側端に約1分間あてます。するとディスプレイ下の圧着材が柔らかくなります。
    • ヘアドライヤーやヒートガンを使う場合は、加熱しすぎないようにして下さい。スクリーンを破損する恐れがあります。
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - 返信
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - 返信
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - 返信
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - 返信
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - 返信
    thaks for this advise, I was looking for this as I dont have a heat gun haha, nice hack
    Andres Chaparro -
  7. iPhone X ディスプレイアセンブリの交換: 手順 7、 2の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 7、 2の画像 2
    • シングルタイプの吸盤カップを使用している場合は、デバイスの下側端に吸盤を取り付けます。カーブしているガラス部分の上は避けてください。
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - 返信
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - 返信
  8. iPhone X ディスプレイアセンブリの交換: 手順 8、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 8、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 8、 3の画像 3
    • 吸盤カップを同じ強さでしっかりと引き上げます。スクリーンとフレームの間にわずかな隙間を作るための圧力で引いてください。
    • スクリーンのプラスチックベゼルの下の隙間にオープニングピックを挿入します。スクリーン自体には挿入しないでください
    • ディスプレイに固定された防水用圧着材は大変強度があります。まずこの一番最初に隙間を作る作業でかなりの力を要します。隙間が作れない場合は、さらに熱を当ててスクリーンを上下に揺さぶることで圧着材を緩めてください。
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - 返信
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - 返信
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 返信
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - 返信
  9. iPhone X ディスプレイアセンブリの交換: 手順 9、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 9、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 9、 3の画像 3
    • 開口ピックを下側左コーナー周辺までスライドしてからiPhoneの左側上部に向けて移動します。ディスプレイに固定された圧着材を切り込みながら進んでください。
    • ピックを3mm以上差し込むと、内部部品が破損する恐れがありますので、ご注意ください。
  10. iPhone X ディスプレイアセンブリの交換, スクリーンの情報: 手順 10、 1の画像 1
    • iPhoneの右端には、デリケートなケーブルがあります。ここにピックを差し込まないでください。ケーブルが破損することがあります。
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - 返信
  11. iPhone X ディスプレイアセンブリの交換: 手順 11、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 11、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 11、 3の画像 3
    • iPhoneの下側端に開口ピックを再挿入してください。今度は右側に向けてスライドして圧着材を切り込みます。
    • オープニングピックを3mm以上差し込まないでください。ディスプレイケーブルを破損することがあります。
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
    William Olstad - 返信
  12. iPhone X ディスプレイアセンブリの交換: 手順 12、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 12、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 12、 3の画像 3
    • ディスプレイ上部端はクリップと接着剤で固定されています。
    • ディスプレイをLighting ポートの方向に揺らしながら引っ張り、ディスプレイ上部のコーナー周辺に開口ピックを差し込んでスライドします。
    • 作業に力を入れると、クリップが壊れてしまうことがあります。慎重に作業を進めてください。
    • 3mm以上オープニングピックを差し込まないでください。フロントパネルのセンサーアレイが破損することがあります。
    • 反対側のコーナーにも開口ピックをスライドして、ディスプレイを固定している残りの接着剤を全て切開します。
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - 返信
  13. iPhone X ディスプレイアセンブリの交換: 手順 13、 1の画像 1
    • 吸盤カップ上の小さな持ち手(ノブ)を引いて、フロントパネルから外します。
  14. iPhone X ディスプレイアセンブリの交換: 手順 14、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 14、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 14、 3の画像 3
    • iPhoneの左側からディスプレイを持ち上げて開口します。(本のページをめくるように)
    • まだディスプレイを完全に外さないでください。幾つかの壊れやすいリボンケーブルが基板と繋がったままです。
    • 画像のように、フレームからディスプレイが外れて、デバイスに引っかかっていないか確認してください。
    • ディスプレイを衝立のようなものに立て掛けて固定してください。
    • 再組み立ての際は、ディスプレイを元の位置にもどします。上部端に沿って付けられたクリップを揃えて、上部からはめていきます。簡単に元の位置に入らない場合は、ディスプレイ周辺に付けられたクリップの状態が曲がっていないか確認してください
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - 返信
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - 返信
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - 返信
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - 返信
  15. iPhone X ディスプレイアセンブリの交換, ディスプレイアセンブリ: 手順 15、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • 基板のコネクター用ブラケットを固定している次の長さのY000ネジを5本外します。
    • 1.1 mm ネジー3本
    • 3.1 mmネジー1本
    • 3.7 mmネジー1本
    • この作業中、各ネジの詳細と管理を徹底してください。再組み立てする際に、正しい位置に各ネジを装着しなければiPhoneにダメージを与えてしまいます。
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - 返信
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - 返信
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - 返信
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - 返信
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - 返信
  16. iPhone X ディスプレイアセンブリの交換: 手順 16、 1の画像 1
    • ブラケットを外します。
    • ブラケットは軽く接着剤で固定されています。丁寧にかつ、しっかりと持ち上げて外してください。
    • 再組み立ての際には、この作業中iPhoneの電源を入れて全ての機能の点検ができます。点検が終わったら、ディスプレイを接着剤で固定してください。次の組み立て作業に進む前に、iPhoneの電源をかならず切ってください。
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - 返信
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - 返信
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - 返信
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
    Max Glanzmann - 返信
  17. iPhone X ディスプレイアセンブリの交換: 手順 17、 2の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 17、 2の画像 2
    • スパッジャーの先端や汚れのない指の先を使って、バッテリーコネクターを基板上のソケットから持ち上げて外します。
    • このソケット周辺にあるブラックのシリコン製シールと他の基板コネクターにダメージを与えないようにご注意ください。これらのシールには特別な防水防塵機能が加えられているためです。
    • 作業中、アクシデントでソケットと接触してしまい電源が誤って入らないように、コネクターを基板から少し曲げ、接触しない位置に固定します。
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - 返信
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - 返信
    Thanks, already did it)
    Stephen Hedrick -
  18. iPhone X ディスプレイアセンブリの交換: 手順 18、 2の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 18、 2の画像 2
    • スパッジャーの先端や爪の先を使って、フロントパネルセンサーアセンブリのコネクターの接続を外します。
  19. iPhone X ディスプレイアセンブリの交換: 手順 19、 2の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 19、 2の画像 2
    • スパッジャーの先端や爪の先を使って、OLEDパネル用ケーブルコネクターの接続を外します。
    • このようなプレスコネクターを再装着するには、丁寧にコネクターの片側を揃えて押し込み固定してから、反対側のコネクターも同様に押し込みます。コネクターの中央を押さえないでください。コネクターを誤った位置に装着してしまうとピンが曲がってしまい、永続的なダメージに繋がります。
    Snap ‘em in like little Legos.
    Ray Johnson - 返信
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - 返信
  20. iPhone X ディスプレイアセンブリの交換: 手順 20、 2の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 20、 2の画像 2
    • スパッジャーの先端を使って、デジタイザのケーブルコネクターをソケットから引き上げて外します。
    • このコネクターは奥に取り付けられているため、再装着の作業が少し困難です。時間をかけてゆっくりと、装着する位置を揃えながら指で優しく押し込んでください。まず最初に片側から、そして反対側のコネクターを装着します。きちんと装着されたか指に伝わるクリック感でわかるはずです。
    • 修理後、タッチスクリーンに支障がある場合はバッテリーの接続を外してこのデジタイザのケーブルコネクターを一度外して再点検してください。きちんと装着されているか、ソケット部分に埃や汚れがないか確認してください。
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - 返信
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - 返信
  21. iPhone X ディスプレイアセンブリの交換: 手順 21、 3の画像 1 iPhone X ディスプレイアセンブリの交換: 手順 21、 3の画像 2 iPhone X ディスプレイアセンブリの交換: 手順 21、 3の画像 3
    • フロントパネルのセンサーアセンブリのフレックスケーブルは軽く接着剤で留められています。
    • 接着剤が外れるまでゆっくりとケーブルを持ち上げます。
    Do this sensor affect face id?
    bonglkv - 返信
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - 返信
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - 返信
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    William Olstad - 返信
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - 返信
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - 返信
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - 返信
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - 返信
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - 返信
    I have damaged the front panel sensor assembly flex cable. Does it carry multiple channels of info or is it just one solid piece that can be soldered back together? If not, will the phone still work except Face ID?
    Bodger Rabbit - 返信
  22. iPhone X ディスプレイアセンブリの交換: 手順 22、 1の画像 1
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - 返信
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - 返信
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - 返信
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - 返信
    Just to confirm the face id is not affected when replacing the earpiece assembly? Am I correct
    mubeen.2011@hotmail.co.uk - 返信
    Sorry for the late response, but you are NOT correct. Replacing the earpiece speaker assembly will result in the loss of Face ID functionality. That's the whole assembly, including the speaker, dot projector and flood illuminator. If you unsolder the speaker from the assembly, that can be replaced by itself without losing Face ID, but any other part will cause it to quit working.
    Jerry Wheeler -
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
13 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
3人の作成者と共同で作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
439,253 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,410のガイドは作成済み
コメント 1 件
Meh, i had to Replace the sensors and camera unit thingy too, but i managed it without advice, the iPhone X is nicer to repair as any other iPhone.
Thanks for the detailed step by step description. :)
(the iphone 8 teardown for example lacks extremely much Details)
GotWaffles ? - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 6
過去 30 日: 13
今までの合計 12,051
