メインコンテンツにスキップ
Samsung Galaxy Note20 USB-C Port Replacement
Kyle Smith
Kyle Smith
最終更新日: March 9, 2023
1 - 2 時間
中レベル
Use this guide to replace the USB-C port on your Samsung Galaxy Note20.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
必要な工具と部品
ツール
もっと見る
  1. Samsung Galaxy Note20 USB-C Port Replacement, Heat the rear cover: 手順 1、 1の画像 1
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen, internal battery, and the plastic rear cover are susceptible to heat damage.
  2. Samsung Galaxy Note20 USB-C Port Replacement, Insert an opening pick: 手順 2、 3の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Insert an opening pick: 手順 2、 3の画像 2 Samsung Galaxy Note20 USB-C Port Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
  3. Samsung Galaxy Note20 USB-C Port Replacement, Begin to cut the adhesive: 手順 3、 3の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Begin to cut the adhesive: 手順 3、 3の画像 2 Samsung Galaxy Note20 USB-C Port Replacement, Begin to cut the adhesive: 手順 3、 3の画像 3
    • As you cut through the adhesive around the perimeter of the phone, don't insert the pick more than 5 mm to avoid damaging internal components.
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note20 USB-C Port Replacement, Cut along the perimeter of the rear cover: 手順 4、 3の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Cut along the perimeter of the rear cover: 手順 4、 3の画像 2 Samsung Galaxy Note20 USB-C Port Replacement, Cut along the perimeter of the rear cover: 手順 4、 3の画像 3
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • If the rear cover is still attached to the frame after cutting through all four sides, try slicing through the adhesive again with an opening pick.
  5. Samsung Galaxy Note20 USB-C Port Replacement, Remove the rear cover: 手順 5、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Remove the rear cover: 手順 5、 2の画像 2
    • Lift the rear cover straight up to remove it.
  6. Samsung Galaxy Note20 USB-C Port Replacement, Remove the motherboard shield: 手順 6、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
    • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
  7. Samsung Galaxy Note20 USB-C Port Replacement: 手順 7、 3の画像 1 Samsung Galaxy Note20 USB-C Port Replacement: 手順 7、 3の画像 2 Samsung Galaxy Note20 USB-C Port Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to lift up and flip back the motherboard shield.
    • Be careful when handling the motherboard shield because its edges are thin and sharp.
  8. Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the battery: 手順 8、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the battery: 手順 8、 2の画像 2
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the wireless charging coil: 手順 9、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the wireless charging coil: 手順 9、 2の画像 2
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
  10. Samsung Galaxy Note20 USB-C Port Replacement, Remove the wireless charging coil: 手順 10、 3の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Remove the wireless charging coil: 手順 10、 3の画像 2 Samsung Galaxy Note20 USB-C Port Replacement, Remove the wireless charging coil: 手順 10、 3の画像 3
    • Grip the motherboard shield with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the device with light adhesive.
    • Remove the wireless charging coil.
  11. Samsung Galaxy Note20 USB-C Port Replacement, Unscrew the loudspeaker: 手順 11、 1の画像 1
    • Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
  12. Samsung Galaxy Note20 USB-C Port Replacement, Remove the loudspeaker: 手順 12、 3の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Remove the loudspeaker: 手順 12、 3の画像 2 Samsung Galaxy Note20 USB-C Port Replacement, Remove the loudspeaker: 手順 12、 3の画像 3
    この手順で使用する道具:
    • Insert the pointed end of a spudger underneath the loudspeaker near its top left screw hole.
    • Use the spudger to pry up and detach the loudspeaker from the frame.
    • Use a pair of tweezers to lift and remove the loudspeaker.
    • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
  13. Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the interconnect cables: 手順 13、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Disconnect the interconnect cables: 手順 13、 2の画像 2
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
  14. Samsung Galaxy Note20 USB-C Port Replacement: 手順 14、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement: 手順 14、 2の画像 2
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
  15. Samsung Galaxy Note20 USB-C Port Replacement: 手順 15、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement: 手順 15、 2の画像 2
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
  16. Samsung Galaxy Note20 USB-C Port Replacement: 手順 16、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement: 手順 16、 2の画像 2
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
  17. Samsung Galaxy Note20 USB-C Port Replacement, Remove the daughterboard: 手順 17、 1の画像 1
    • Use a Phillips screwdriver to remove the 2.9 mm screw securing the daughterboard to the frame.
  18. Samsung Galaxy Note20 USB-C Port Replacement: 手順 18、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement: 手順 18、 2の画像 2
    • The daughterboard is fitted to the frame by three spring connectors along its bottom edge.
    • Insert the pointed end of a spudger under the right side of the daughterboard near the screw boss.
    • Use the spudger to pry up and detach the daughterboard from the frame.
    • There are small surface-mounted components underneath the daughterboard. Only insert the spudger as far as necessary to avoid damaging the components.
  19. Samsung Galaxy Note20 USB-C Port Replacement: 手順 19、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement: 手順 19、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to lift and remove the daughterboard.
  20. Samsung Galaxy Note20 USB-C Port Replacement, Unscrew the USB-C port: 手順 20、 1の画像 1
    • Use a Phillips screwdriver to remove the two 2.9 mm screws securing the USB-C port to the phone.
  21. Samsung Galaxy Note20 USB-C Port Replacement, Loosen the USB-C port: 手順 21、 2の画像 1 Samsung Galaxy Note20 USB-C Port Replacement, Loosen the USB-C port: 手順 21、 2の画像 2
    • Insert the pointed end of a spudger under the right side screw hole on the USB-C port.
    • Pry up the USB-C port to loosen it from the frame.
    • The USB-C port may fling out of its slot while it is being pried.
    • The USB-C port is held in place by a red rubber gasket. Prying up with a steady force will gradually loosen the USB-C port from its slot.
  22. Samsung Galaxy Note20 USB-C Port Replacement, Remove the USB-C port: 手順 22、 1の画像 1
    • Grip the USB-C cable with your fingers close to the USB-C port.
    • Remove the USB-C port by pulling it up and away from the bottom of the phone.
    • Avoid bending the ribbon cable more than necessary to prevent damage.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
5 の人々がこのガイドを完成させました。
Kyle Smith
メンバー登録日: 02/01/21
44,815 ポイント
123のガイドは作成済み
コメント 1 件
The guide is good, was going to finish the guide while replacing the battery. However the cable connected to the USB-c port was (at least for me) soldered. I had to reinstall the old port until I can get my soldering iron. Will attempt soon. Otherwise great guide.
Yarran Byrne - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 35
過去 30 日: 90
今までの合計 8,251
