メインコンテンツにスキップ
Razer Blade 15" (2018) Battery Replacement
Clay Eickemeyer
Clay Eickemeyer とその他 2 人の作成者
最終更新日: November 12, 2024
30 - 45 分
中レベル
おすすめのガイド
Use this guide to replace the battery in your Razer Blade 15" (2018).
If your laptop dies quickly or doesn't hold a charge, it might be time to replace the battery.
Note: This laptop supports expandable storage with an HDD (hard disk drive). This guide requires that you remove the hard drive from your laptop, if it has one. If your model doesn't have a hard drive, skip the steps showing how to remove it.
必要な工具と部品
修理キット
キットには、修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Razer Blade 15" (2018) Battery Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 1 Razer Blade 15" (2018) Battery Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) Battery Replacement, Unfasten the back cover: 手順 2、 1の画像 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) Battery Replacement, Insert an opening pick: 手順 3、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Insert an opening pick: 手順 3、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) Battery Replacement, Angle the opening pick: 手順 4、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Angle the opening pick: 手順 4、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Angle the opening pick: 手順 4、 3の画像 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) Battery Replacement, Free the bottom right corner: 手順 5、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Free the bottom right corner: 手順 5、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Free the bottom right corner: 手順 5、 3の画像 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Battery Replacement, Free the front edge: 手順 6、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Free the front edge: 手順 6、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Free the front edge: 手順 6、 3の画像 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) Battery Replacement, Remove the back cover: 手順 7、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Remove the back cover: 手順 7、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) Battery Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 1 Razer Blade 15" (2018) Battery Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) Battery Replacement, Peel up the battery cable tape: 手順 9、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Peel up the battery cable tape: 手順 9、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Peel up the battery cable tape: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) Battery Replacement, Disconnect the battery: 手順 10、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Disconnect the battery: 手順 10、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Disconnect the battery: 手順 10、 3の画像 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) Battery Replacement, Disconnect the hard drive: 手順 11、 2の画像 1 Razer Blade 15" (2018) Battery Replacement, Disconnect the hard drive: 手順 11、 2の画像 2
    • Grab the pull tab on the hard drive press connector, just below the right fan.
    • Pull up and disconnect the connector from its socket.
    • During reassembly, align the press connector over its socket and press down until it clicks into place. If it doesn't connect, re-align it and try again.
  12. Razer Blade 15" (2018) Battery Replacement, Unfasten the hard drive mounts: 手順 12、 2の画像 1 Razer Blade 15" (2018) Battery Replacement, Unfasten the hard drive mounts: 手順 12、 2の画像 2
    • Use your Phillips screwdriver to remove the four screws securing the hard drive mounts:
    • Three 3.2 mm screws
    • One 5.2 mm screw
  13. Razer Blade 15" (2018) Battery Replacement, Remove the hard drive: 手順 13、 2の画像 1 Razer Blade 15" (2018) Battery Replacement, Remove the hard drive: 手順 13、 2の画像 2
    • Lift the hard drive straight up to remove it.
  14. Razer Blade 15" (2018) Battery Replacement, Remove the hard drive adapter: 手順 14、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Remove the hard drive adapter: 手順 14、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Remove the hard drive adapter: 手順 14、 3の画像 3
    • If your laptop doesn't have a hard drive, you need to remove the adapter to access the battery. If you just removed your hard drive, skip this step.
    • Grab the hard drive adapter on the left edge of the battery.
    • Peel the adapter and its tape from the battery and set it aside.
  15. Razer Blade 15" (2018) Battery Replacement, Free the battery cable: 手順 15、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Free the battery cable: 手順 15、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Free the battery cable: 手順 15、 3の画像 3
    • Unclip the battery cable from the top and right tabs of the battery.
  16. Razer Blade 15" (2018) Battery Replacement, Unfasten the battery: 手順 16、 1の画像 1
    • Use your Phillips screwdriver to remove the five 5.2 mm screws securing the battery.
  17. Razer Blade 15" (2018) Battery Replacement, Remove the battery: 手順 17、 3の画像 1 Razer Blade 15" (2018) Battery Replacement, Remove the battery: 手順 17、 3の画像 2 Razer Blade 15" (2018) Battery Replacement, Remove the battery: 手順 17、 3の画像 3
    • Lift the top edge of the battery from its recess in the frame and remove it.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
作成者
2人の作成者と共同で作成されました。
Clay Eickemeyer
メンバー登録日: 09/19/22
82,294 ポイント
455のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
9 メンバー
11,499のガイドは作成済み
1件のガイドコメント
I just changed my battery to the one provided by ifixit it
Windows says battery not detected but when I unplugged the laptop stays on
So i guess the battery is working try to uninstall from devices and reset but still same isuue ?
Any suggestions ?
J H - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 141
今までの合計 3,636
