Huawei Mate 10 Fingerprint Sensor Replacement
はじめに
手順 1 に進むFollow this guide to remove and replace a broken fingerprint sensor for the Mate 10. The process is very extensive, requiring the removal of many heavily-glued-in components.
Note that the procedure will destructively remove the screen. The Mate 10 uses very strong adhesive to hold the screen in place, making non-invasive removal very difficult without specialty tools.
Gaining access to the fingerprint sensor also requires removing the firmly glued battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
The back cover held in place with a very strong perimeter adhesive. During removal, the adhesive may rip out parts of the coating from the glass back cover, leaving behind patches of clear glass.
必要な工具と部品
パーツ
ツール
もっと見る
Heat an iOpener and apply it to the bottom edge of the phone for two minutes. Re-heat the iOpener as needed.
While you wait, note the location of the adhesive holding the back cover in place.
You may pull up chunks of the cover's color coating as you remove the adhesive. To reduce the chances of this occurring, apply heat or high concentration isopropyl alcohol to the adhesive to weaken it.
Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
Pull the plastic bracket away from the top edge of the phone.
Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
Remove the plastic bracket along with the heat dissipation layer.
Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
Use the point of a spudger to pry up and disconnect the white antenna cable from the bottom of the phone.
Insert the point of a spudger in one of the notches along the bottom edge of the daughterboard.
Push the daughterboard away from the bottom of the phone to loosen the board.
Repeat the process with a second notch to fully release the daughterboard.
Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket.
Place a suction cup near the bottom left corner of the phone. The edge there has slightly thinner adhesive.
Pull on the suction cup with strong, steady force to create a gap in the seam.
Insert an opening pick in the gap.
Repeat the heating and pulling process multiple times to soften the adhesive.
Use a playing card instead of an opening pick to insert in the gap.
Try heating and prying at a different location.
Use a Jimmy to make the initial entry. Be careful working with metal tools, as they will scratch the frame and chip the glass screen.
Once you have sliced around the perimeter, grasp the screen from the top corners and lift up.
Use an opening pick to slice through any remaining adhesive holding onto the screen.
Carefully thread the fingerprint sensor cable through its frame cutout.
Thread the display cable through its frame cutout.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mate 10 Answers community for help.
