メインコンテンツにスキップ
Google Pixel Watch Vibration Motor Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch とその他 3 人の作成者
最終更新日: July 14, 2024
30 - 45 分
中レベル
Use this guide to remove or replace the vibration motor in your Google Pixel Watch.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach the screen when reassembling the device.
Retaining water resistance after the repair will depend on how precisely the adhesive is reapplied, but your device will lose its IP (Ingress Protection) rating.
Note: This guide was written using a GBZ4S LTE model. If you have the non-LTE version, you can still use this guide—but there might be slight visual discrepancies.
必要な工具と部品
ツール
もっと見る
  1. Google Pixel Watch Vibration Motor Replacement, Remove the watch band: 手順 1、 3の画像 1 Google Pixel Watch Vibration Motor Replacement, Remove the watch band: 手順 1、 3の画像 2 Google Pixel Watch Vibration Motor Replacement, Remove the watch band: 手順 1、 3の画像 3
    • Before starting repairs, turn off your watch and take it off the charger.
    • Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
    • Repeat for the other watch band.
  2. Google Pixel Watch Vibration Motor Replacement, Loosen the screen adhesive: 手順 2、 1の画像 1
    • Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  3. Google Pixel Watch Vibration Motor Replacement, Insert an iFlex: 手順 3、 2の画像 1 Google Pixel Watch Vibration Motor Replacement, Insert an iFlex: 手順 3、 2の画像 2
    この手順で使用する道具:
    iFlex Opening Tool
    $11.99
    • The thin seam between the frame and screen requires a thin metal tool—take your time and work carefully to avoid scraping or gouging the watch body or glass.
    • Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
  4. Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: 手順 4、 3の画像 1 Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: 手順 4、 3の画像 2 Google Pixel Watch Vibration Motor Replacement, Slice the screen adhesive: 手順 4、 3の画像 3
    • When slicing the screen adhesive, insert the iFlex no deeper than 3 mm to prevent damaging internal components.
    • Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
  5. Google Pixel Watch Vibration Motor Replacement, Pry up the screen: 手順 5、 2の画像 1 Google Pixel Watch Vibration Motor Replacement, Pry up the screen: 手順 5、 2の画像 2
    • Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
    • Twist the iFlex to pry the screen up.
    • Don't try to fully remove the screen just yet, as it‘s still connected to the watch assembly by a delicate cable.
  6. Google Pixel Watch Vibration Motor Replacement, Swing open the screen: 手順 6、 3の画像 1 Google Pixel Watch Vibration Motor Replacement, Swing open the screen: 手順 6、 3の画像 2 Google Pixel Watch Vibration Motor Replacement, Swing open the screen: 手順 6、 3の画像 3
    • Be careful not to strain the screen assembly cable when you open the display.
    • Swing the screen open to an upright position.
    • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
  7. Google Pixel Watch Vibration Motor Replacement, Unfasten the speaker bracket: 手順 7、 2の画像 1 Google Pixel Watch Vibration Motor Replacement, Unfasten the speaker bracket: 手順 7、 2の画像 2
    この手順で使用する道具:
    FixMat
    $36.95
    • Use a Torx T2 screwdriver to remove the 2.1 mm-long screw securing the speaker bracket.
  8. Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: 手順 8、 3の画像 1 Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: 手順 8、 3の画像 2 Google Pixel Watch Vibration Motor Replacement, Remove the speaker bracket: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Take care not to puncture or bend the battery with sharp tools—it can leak dangerous chemicals or catch fire.
    • Use a pair of tweezers to remove the speaker bracket.
  9. Google Pixel Watch Vibration Motor Replacement, Disconnect the vibration motor: 手順 9、 2の画像 1 Google Pixel Watch Vibration Motor Replacement, Disconnect the vibration motor: 手順 9、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the vibration motor‘s press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  10. Google Pixel Watch Vibration Motor Replacement, Loosen the vibration motor cable: 手順 10、 2の画像 1 Google Pixel Watch Vibration Motor Replacement, Loosen the vibration motor cable: 手順 10、 2の画像 2
    • Be careful with sharp tools around the battery.
    • Use tweezers to peel up the yellow tape securing the vibration motor cable to the battery.
  11. Google Pixel Watch Vibration Motor Replacement, Unfasten the vibration motor: 手順 11、 1の画像 1
    • Use a Torx T2 screwdriver to remove the two screws securing the vibration motor:
    • One 1.8 mm-long screw
    • One 2.8 mm-long screw
  12. Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: 手順 12、 3の画像 1 Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: 手順 12、 3の画像 2 Google Pixel Watch Vibration Motor Replacement, Remove the grounding bracket: 手順 12、 3の画像 3
    • Use tweezers to lift the grounding bracket out of its recess and remove it.
  13. Google Pixel Watch Vibration Motor Replacement, Remove the vibration motor: 手順 13、 2の画像 1 Google Pixel Watch Vibration Motor Replacement, Remove the vibration motor: 手順 13、 2の画像 2
    • Remove the vibration motor.
終わりに
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
作成者
3人の作成者と共同で作成されました。
メンバー登録日: 11/23/16
229,082 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,425のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 25
今までの合計 654
