メインコンテンツにスキップ
Apple設計のM1 ProとM1 MaxのSoCを搭載した14インチMacBook Proの修理ガイドと分解情報をご紹介します。2021年10月に発売。モデル番号はA2442。
Why is the MBP 14" not turning on?
Hey everyone, I've got a MacBook Pro 14" M2 from 2021 that was running smoothly until recently. Now, it won't boot up no matter what I try – I've checked the power cable, the charger, and held down the Touch ID button. Frustrated, I decided to open it up and disconnect the battery, and that seemed to do the trick. However, here's the catch: I have to repeat this process every morning because it refuses to boot again.
I've experimented with leaving it charged and turned off, but nothing seems to change. It's almost like the battery drains overnight, and then it struggles to recognize the charger or boot. Could this be related to macOS Sonoma? I've heard it has some battery consumption issues. Should I consider rolling back to Ventura, or could this be a battery-related problem? Currently, the battery is at 86% capacity with approximately 700 cycles. Any insights or suggestions would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
First, run Apple Diagnostics and Coconut Battery.
Using Apple Diagnostics
Coconut Battery
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Take a snapshot on what CoconutBattery shows you and paste it here so we can see it as well.
さんによる
Forgot to mention that I did run Apple Diagnostics and show no issues, will try this coconut battery and will came back with the result
さんによる
Sorry for the delay posting the results of coconut battery
さんによる
コメントを追加
回答を追加する
Alejandro Peñafiel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 128
