メインコンテンツにスキップ
目次
学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Computer is Not Connecting to the Internet
The computer doesn’t show any available networks or won’t connect to available networks.
Wi-Fi Adapter is Turned off
Ensure the Wi-Fi adapter is turned on. Go into Settings > Network and Internet > Wi-fi > Change Adapter Options. In the control panel window, right-click on Wi-Fi and select Enable.
Ensure the Wi-Fi card is turned on via the switch sharing the f8 key.
Wi-Fi Drivers are Out of Date
Sometimes the computer will not update the Wi-Fi drivers along with the usual system updates like it is supposed to. To manually update them, open up Device Manager from the taskbar. Navigate to Network Adapters and select the name of the Network Adapter in the laptop. This is usually named something like Intel(R) Dual Band Wireless-AC 8265. Right-click and select Update Driver.
These drivers are also downloadable from the company’s website https://pcsupport.lenovo.com/us/en/produ....
If updating does not work, you are also able to reinstall the driver entirely. From the control panel menu from above, right click on the Network Adapter again and select Uninstall. Restart the computer and the drivers will install automatically.
Computer is not responding
The computer has a blank screen or is not responding to keystrokes or trackpad.
Loss of Signal
Press and hold the power button until the computer turns off(10 seconds). Then, restart the computer.
If the above step did not work, then activate the emergency reset button. This is located on the bottom of the laptop and can be activated by inserting a paperclip in the hole. Connect the laptop to AC power and turn it on.
Motherboard Unresponsive
If the computer screen is completely black and the computer is not responding to any attempts to turn it on, the motherboard could be malfunctioning. To replace the motherboard, refer to our motherboard replacement guide.
Trackpad Doesn’t Work
The trackpad does not sense movement when in use.
Operating System Issue
Reinstall the latest version of Windows, and restart computer. To reinstall Windows: https://support.microsoft.com/en-us/help...
Trackpad Hardware Issue
If reinstalling the latest version of Windows does not solve the problem, the trackpad must be replaced. For a step by step guide on how to replace the trackpad, refer to the trackpad replacement guide.
USB - C port Unresponsive
The USB-C port is not working, including not being able to charge the laptop.
Old Firmware
Lenovo recommends immediately installing the newest driver and firmware packages, driver first, then the firmware. To check what software and firmware is installed, go to the Windows 10 search bar and type Thunderbolt, right click on the blue and white lightning bolt icon, select About > Details > NVM Firmware version. Newest versions of both the driver and firmware can be found on the company’s website. https://pcsupport.lenovo.com/ca/en/solut...
Battery Cannot Hold a Charge
The battery life is significantly less than advertised or decreased from its original capacity.
4K Screens Require More Power
4K screens inherently require more battery power to display the same content as a 1080p screen. Battery life is a trade-off that is made when purchasing a laptop with a 4K screen. To best extend the battery life, enable Windows 10 battery saver mode by selecting on the battery icon in the system tray and moving the slider to the left, selecting “Battery Saver.”
Battery at End of Lifespan
As a consumable component, lithium ion batteries have a finite number of charging cycles they can withstand before they greatly lose their original capacity. For a step by step guide to replace the battery, refer to our battery replacement guide.
Solid State Drive(SSD) Storage Full
The SSD has run out of storage and computer is not able to store files
SSD is Too Full
If files aren’t getting stored on the SSD, it requires a cleanup to remove excess files. To perform a Cleanup on Windows: https://support.microsoft.com/en-us/help...
If the SSD is still full after removing excess files and you want more storage for the computer, the SSD must be replaced. Refer to our SSD replacement guide.
作成者
4人の作成者と共同で作成されました。
Tushar Sharma
メンバー登録日: 01/28/20
679 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S19-G2, White Winter 2020 Cal Poly, Team S19-G2, White Winter 2020人のメンバー
CPSU-WHITE-W20S19G2
4 メンバー
20のガイドは作成済み
2 件のコメント
My lenovo x1 carbon won't not turn on
Rasheed Adekanbi - 返信
My lenovo x1 carbon 7th generation is not powering on
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 69
今までの合計 10,299
