メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy S23 Screen Replacement
必要な工具と部品
  1. Samsung Galaxy S23 Screen Replacement, Prepare your phone for disassembly: 手順 1、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Prepare your phone for disassembly: 手順 1、 2の画像 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Galaxy S23 Screen Replacement, Heat the right edge: 手順 2、 1の画像 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Galaxy S23 Screen Replacement, Insert an opening pick: 手順 3、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: 手順 3、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: 手順 4、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: 手順 4、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Separate the right adhesive: 手順 4、 3の画像 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Galaxy S23 Screen Replacement, Heat the bottom edge: 手順 5、 1の画像 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 6、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 6、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 6、 3の画像 3
    • Insert a second opening pick at the bottom right corner.
    • Rotate it around the bottom right corner to separate the adhesive.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Galaxy S23 Screen Replacement, Separate the bottom adhesive: 手順 7、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the bottom adhesive: 手順 7、 2の画像 2
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Galaxy S23 Screen Replacement, Heat the left edge: 手順 8、 1の画像 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 9、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 9、 2の画像 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
    FixBotに聞いてみる
    コメントを追加
  10. Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: 手順 10、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: 手順 10、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Separate the left adhesive: 手順 10、 3の画像 3
    • Insert a third opening pick at the bottom left corner.
    • Slide your pick toward the top left corner to separate the adhesive.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  11. Samsung Galaxy S23 Screen Replacement, Heat the top edge: 手順 11、 1の画像 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
    FixBotに聞いてみる
    コメントを追加
  12. Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 12、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 12、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Separate the corner adhesive: 手順 12、 3の画像 3
    • Insert a fourth opening pick at the top left corner.
    • Rotate it around the top left corner to separate the adhesive.
    FixBotに聞いてみる
    コメントを追加
  13. Samsung Galaxy S23 Screen Replacement, Separate the top adhesive: 手順 13、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the top adhesive: 手順 13、 2の画像 2
    • Slide your opening pick to the top right corner to separate the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  14. Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: 手順 14、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: 手順 14、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Separate the flash adhesive: 手順 14、 3の画像 3
    • There's a remaining patch of adhesive directly under the flash.
    • Line up the tip of an opening pick with the flash cutout.
    • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
    • You should see the opening pick through the flash cutout.
    • Keep sliding the pick toward the bottom of the phone until you feel the adhesive completely separate from the back cover.
    • Avoid touching the rear cameras with your pick. Pushing against the lenses risks damaging them.
    FixBotに聞いてみる
    コメントを追加
  15. Samsung Galaxy S23 Screen Replacement, Remove the back cover: 手順 15、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Remove the back cover: 手順 15、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Remove the back cover: 手順 15、 3の画像 3
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
    FixBotに聞いてみる
    コメントを追加
  16. Samsung Galaxy S23 Screen Replacement, Disconnect the wireless charging coil: 手順 16、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Disconnect the wireless charging coil: 手順 16、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    FixBotに聞いてみる
    コメントを追加
  17. Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: 手順 17、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: 手順 17、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker screws: 手順 17、 3の画像 3
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
    FixBotに聞いてみる
    コメントを追加
  18. Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: 手順 18、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: 手順 18、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Remove the wireless charging coil and loudspeaker: 手順 18、 3の画像 3
    • Insert the point of your spudger in the notch at the top left corner of the loudspeaker.
    • Pry up to unclip the loudspeaker from the frame.
    FixBotに聞いてみる
    コメントを追加
  19. Samsung Galaxy S23 Screen Replacement: 手順 19、 3の画像 1 Samsung Galaxy S23 Screen Replacement: 手順 19、 3の画像 2 Samsung Galaxy S23 Screen Replacement: 手順 19、 3の画像 3
    • Use your fingers to lift the loudspeaker away from the frame to fully separate it.
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
    FixBotに聞いてみる
    コメントを追加
  20. Samsung Galaxy S23 Screen Replacement, Disconnect the battery: 手順 20、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Disconnect the battery: 手順 20、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the battery press connector.
    FixBotに聞いてみる
    コメントを追加
  21. Samsung Galaxy S23 Screen Replacement, Disconnect the display: 手順 21、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Disconnect the display: 手順 21、 2の画像 2
    • Use the flat end of your spudger to pry up and disconnect the display cable press connector from the back of the screen.
    FixBotに聞いてみる
    コメントを追加
  22. Samsung Galaxy S23 Screen Replacement, Put the back cover on: 手順 22、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Put the back cover on: 手順 22、 2の画像 2
    • Put the back cover on the frame to protect the battery and your phone's internals from damage.
    • Don't apply new adhesive at this step, as you'll need to remove the back cover again to finish reassembly. The old adhesive will be enough to keep the back cover in place while you replace the screen.
    • Flip your phone over so the screen is facing up.
    FixBotに聞いてみる
    コメントを追加
  23. Samsung Galaxy S23 Screen Replacement, Tool and safety information: 手順 23、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Tool and safety information: 手順 23、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Tool and safety information: 手順 23、 3の画像 3
    この手順で使用する道具:
    iFlex Opening Tool
    $11.99
    • The gap between the front glass and frame is very small. You'll need a thin, rigid tool such as an iFlex to create an initial gap.
    • Take the following safety precautions while removing the front glass during the next steps:
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp.
    • The front glass may shatter and spread shards of glass around your workspace. Consider wearing gloves and safety glasses to protect yourself.
    FixBotに聞いてみる
    コメントを追加
  24. Samsung Galaxy S23 Screen Replacement, Heat the screen: 手順 24、 1の画像 1
    • Use a hair dryer or heat gun to heat the top edge of the screen until it's almost too hot to touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    FixBotに聞いてみる
    コメントを追加
  25. Samsung Galaxy S23 Screen Replacement, Insert an iFlex: 手順 25、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Insert an iFlex: 手順 25、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Insert an iFlex: 手順 25、 3の画像 3
    • Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
    • Insert the iFlex at a downward angle in the earpiece speaker gap between the top edge of the front glass and frame.
    • Lift the suction handle with strong, steady force and lower the iFlex so it slides under the front glass. A large portion of the front glass may separate—that's fine.
    • The front glass will peel away from the display panel, causing it to appear discolored. This is normal. You will remove the display panel in a later step.
    • The iFlex only needs to be inserted just enough to separate the front glass and create an initial gap. If inserted too far, it may damage the front-facing camera.
    FixBotに聞いてみる
    コメントを追加
  26. Samsung Galaxy S23 Screen Replacement, Insert an opening pick: 手順 26、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: 手順 26、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Insert an opening pick: 手順 26、 3の画像 3
    • Rotate the iFlex around one of the top corners of the front glass to separate enough adhesive to insert an opening pick.
    FixBotに聞いてみる
    コメントを追加
  27. Samsung Galaxy S23 Screen Replacement, Remove the front glass: 手順 27、 3の画像 1 Samsung Galaxy S23 Screen Replacement, Remove the front glass: 手順 27、 3の画像 2 Samsung Galaxy S23 Screen Replacement, Remove the front glass: 手順 27、 3の画像 3
    • Slide the opening pick around the perimeter of the front glass to separate the adhesive securing it to the frame.
    FixBotに聞いてみる
    コメントを追加
  28. Samsung Galaxy S23 Screen Replacement: 手順 28、 2の画像 1 Samsung Galaxy S23 Screen Replacement: 手順 28、 2の画像 2
    • Lift the front glass off the frame and remove it.
    FixBotに聞いてみる
    コメントを追加
  29. Samsung Galaxy S23 Screen Replacement, Remove the screen panel: 手順 29、 2の画像 1 Samsung Galaxy S23 Screen Replacement, Remove the screen panel: 手順 29、 2の画像 2
    • Insert an opening pick under the screen panel.
    • If you're having trouble separating the adhesive, use a hair dryer or heat gun to heat the screen panel until it's warm to the touch.
    FixBotに聞いてみる
    コメントを追加
  30. Samsung Galaxy S23 Screen Replacement: 手順 30、 3の画像 1 Samsung Galaxy S23 Screen Replacement: 手順 30、 3の画像 2 Samsung Galaxy S23 Screen Replacement: 手順 30、 3の画像 3
    • Slide the opening pick around the perimeter of the screen panel to separate the adhesive securing it to the frame.
    FixBotに聞いてみる
    コメントを追加
  31. Samsung Galaxy S23 Screen Replacement: 手順 31、 3の画像 1 Samsung Galaxy S23 Screen Replacement: 手順 31、 3の画像 2 Samsung Galaxy S23 Screen Replacement: 手順 31、 3の画像 3
    • Grip a corner of the screen panel and slowly peel it off the frame to separate the remaining adhesive.
    • Remove the screen panel.
    • You're now ready to replace your screen.
    FixBotに聞いてみる
    コメントを追加
終わりに
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S23 Answers Community for troubleshooting help.
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
244,459 ポイント
1,203のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
27,589のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 36
過去 7 日: 291
過去 30 日: 1,373
今までの合計 21,668
