メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 8 Battery Replacement
必要な工具と部品
  1. OnePlus 8 Battery Replacement, Heat the rear glass: 手順 1、 1の画像 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
    FixBotに聞いてみる
    コメントを追加
  2. OnePlus 8 Battery Replacement, Insert an opening pick: 手順 2、 3の画像 1 OnePlus 8 Battery Replacement, Insert an opening pick: 手順 2、 3の画像 2 OnePlus 8 Battery Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
    FixBotに聞いてみる
    コメントを追加
  3. OnePlus 8 Battery Replacement, Slice the bottom edge adhesive: 手順 3、 3の画像 1 OnePlus 8 Battery Replacement, Slice the bottom edge adhesive: 手順 3、 3の画像 2 OnePlus 8 Battery Replacement, Slice the bottom edge adhesive: 手順 3、 3の画像 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  4. OnePlus 8 Battery Replacement: 手順 4、 3の画像 1 OnePlus 8 Battery Replacement: 手順 4、 3の画像 2 OnePlus 8 Battery Replacement: 手順 4、 3の画像 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  5. OnePlus 8 Battery Replacement, Slice the left edge adhesive: 手順 5、 3の画像 1 OnePlus 8 Battery Replacement, Slice the left edge adhesive: 手順 5、 3の画像 2 OnePlus 8 Battery Replacement, Slice the left edge adhesive: 手順 5、 3の画像 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  6. OnePlus 8 Battery Replacement, Slice the top edge adhesive: 手順 6、 3の画像 1 OnePlus 8 Battery Replacement, Slice the top edge adhesive: 手順 6、 3の画像 2 OnePlus 8 Battery Replacement, Slice the top edge adhesive: 手順 6、 3の画像 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  7. OnePlus 8 Battery Replacement, Slice the right edge adhesive: 手順 7、 3の画像 1 OnePlus 8 Battery Replacement, Slice the right edge adhesive: 手順 7、 3の画像 2 OnePlus 8 Battery Replacement, Slice the right edge adhesive: 手順 7、 3の画像 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
    FixBotに聞いてみる
    コメントを追加
  8. OnePlus 8 Battery Replacement, Remove the rear glass: 手順 8、 3の画像 1 OnePlus 8 Battery Replacement, Remove the rear glass: 手順 8、 3の画像 2 OnePlus 8 Battery Replacement, Remove the rear glass: 手順 8、 3の画像 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    FixBotに聞いてみる
    コメントを追加
  9. OnePlus 8 Battery Replacement, Unfasten the motherboard cover: 手順 9、 1の画像 1
    この手順で使用する道具:
    • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  10. OnePlus 8 Battery Replacement, Pry up the motherboard cover: 手順 10、 3の画像 1 OnePlus 8 Battery Replacement, Pry up the motherboard cover: 手順 10、 3の画像 2 OnePlus 8 Battery Replacement, Pry up the motherboard cover: 手順 10、 3の画像 3
    • The motherboard cover is secured by tight clips.
    • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
    • Twist the spudger to release the clips.
    • Lever the motherboard cover up until you can grip it with your fingers.
    FixBotに聞いてみる
    コメントを追加
  11. OnePlus 8 Battery Replacement, Remove the motherboard cover: 手順 11、 2の画像 1 OnePlus 8 Battery Replacement, Remove the motherboard cover: 手順 11、 2の画像 2
    • Remove the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  12. OnePlus 8 Battery Replacement, Disconnect the battery cable: 手順 12、 2の画像 1 OnePlus 8 Battery Replacement, Disconnect the battery cable: 手順 12、 2の画像 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    FixBotに聞いてみる
    コメントを追加
  13. OnePlus 8 Battery Replacement, Lift the tape on the battery: 手順 13、 3の画像 1 OnePlus 8 Battery Replacement, Lift the tape on the battery: 手順 13、 3の画像 2 OnePlus 8 Battery Replacement, Lift the tape on the battery: 手順 13、 3の画像 3
    • Use a spudger or your fingers to peel the tape up from the right edge of the battery.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    FixBotに聞いてみる
    コメントを追加
  14. OnePlus 8 Battery Replacement, Lift up the battery: 手順 14、 3の画像 1 OnePlus 8 Battery Replacement, Lift up the battery: 手順 14、 3の画像 2 OnePlus 8 Battery Replacement, Lift up the battery: 手順 14、 3の画像 3
    • The battery is secured to the frame with adhesive. Pull tabs are provided to separate the adhesive and remove the battery.
    • Peel the red pull tab away from the top of the battery.
    • Using one hand to hold the phone steady, use your other hand to slowly and steadily lift the red pull tab up to separate the adhesive securing the battery underneath.
    • If you're having trouble removing the battery, you can apply an iOpener to the screen side to loosen the adhesive underneath the battery.
    FixBotに聞いてみる
    コメントを追加
  15. OnePlus 8 Battery Replacement, Remove the battery: 手順 15、 3の画像 1 OnePlus 8 Battery Replacement, Remove the battery: 手順 15、 3の画像 2 OnePlus 8 Battery Replacement, Remove the battery: 手順 15、 3の画像 3
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Peel the battery away from the extra tape on its left edge and remove it.
    • Temporarily reconnect the battery to the motherboard before you press it into place to ensure correct alignment. Disconnect the battery after it's seated.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the frame where the old adhesive was located, not directly onto the battery itself.
    • Press the new battery firmly into place to secure it.
    FixBotに聞いてみる
    コメントを追加
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Manuel Haeussermann
メンバー登録日: 07/13/22
25,958 ポイント
71のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
29,038のガイドは作成済み
1件のガイドコメント
Thanks highly.
First real smart phone and was surprised that my battery decided to gain some weight :)
Bloated is usually what woman talk about when pregnant. A phone? Anyway it went as smooth as it could be. Only issue is my own as to how engineering has gotten
to the point that such exceptionally tiny connectors can be made to precisely fit where its supposed too. I was glad to feel the connectors snap in then started
realizing how tight the tolerances are to make them fit. I guess the ole 9 volt batteries are a past thing but I reminisce about them anyway. Laugh about when I last used one and how its now funny that I would get upset when I tried to put one in backwards. Times have really changed.
thx again.
Me andmi - 返信 共有
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 56
過去 30 日: 282
今までの合計 16,314
