メインコンテンツにスキップ
Nothing Phone (1) Earpiece Speaker Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch とその他 人の作成者
最終更新日: July 31, 2024
25 - 45 分
中レベル
Use this guide to replace the earpiece speaker on your Nothing Phone (1).
You’ll need replacement adhesive to reattach the rear glass when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Nothing Phone (1) Earpiece Speaker Replacement, Heat the rear glass: 手順 1、 1の画像 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Nothing Phone (1) Earpiece Speaker Replacement, Insert an opening pick: 手順 2、 3の画像 1 Nothing Phone (1) Earpiece Speaker Replacement, Insert an opening pick: 手順 2、 3の画像 2 Nothing Phone (1) Earpiece Speaker Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Nothing Phone (1) Earpiece Speaker Replacement, Slice the adhesive: 手順 3、 2の画像 1 Nothing Phone (1) Earpiece Speaker Replacement, Slice the adhesive: 手順 3、 2の画像 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Nothing Phone (1) Earpiece Speaker Replacement, Slice the adhesive: 手順 4、 3の画像 1 Nothing Phone (1) Earpiece Speaker Replacement, Slice the adhesive: 手順 4、 3の画像 2 Nothing Phone (1) Earpiece Speaker Replacement, Slice the adhesive: 手順 4、 3の画像 3
    • When you slice near the glyph, insert only the tip of the opening pick (~2-3 mm) to avoid damaging the LEDs.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Nothing Phone (1) Earpiece Speaker Replacement: 手順 5、 2の画像 1 Nothing Phone (1) Earpiece Speaker Replacement: 手順 5、 2の画像 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Nothing Phone (1) Earpiece Speaker Replacement: 手順 6、 2の画像 1 Nothing Phone (1) Earpiece Speaker Replacement: 手順 6、 2の画像 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
  7. Nothing Phone (1) Earpiece Speaker Replacement, Remove the rear glass: 手順 7、 2の画像 1 Nothing Phone (1) Earpiece Speaker Replacement, Remove the rear glass: 手順 7、 2の画像 2
    この手順で使用する道具:
    Dust Blower
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Since the rear glass of the Nothing Phone (1) is transparent a dust blower may come in handy for cleaning before installing a new rear glass.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Nothing Phone (1) Earpiece Speaker Replacement, Remove the plastic cover: 手順 8、 3の画像 1 Nothing Phone (1) Earpiece Speaker Replacement, Remove the plastic cover: 手順 8、 3の画像 2 Nothing Phone (1) Earpiece Speaker Replacement, Remove the plastic cover: 手順 8、 3の画像 3
    • The plastic covering the earpiece speaker is held in place by mild adhesive. If you're having a hard time removing it, apply a heated iOpener for 1-2 minutes to loosen the adhesive underneath.
    • Insert an opening pick underneath the grey plastic cover at the top edge of your phone.
    • Use your opening pick to pry up the plastic cover.
    • Remove the plastic cover.
  9. Nothing Phone (1) Earpiece Speaker Replacement, Unfasten the earpiece speaker screws: 手順 9、 1の画像 1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the earpiece speaker.
  10. Nothing Phone (1) Earpiece Speaker Replacement, Remove the earpiece speaker: 手順 10、 3の画像 1 Nothing Phone (1) Earpiece Speaker Replacement, Remove the earpiece speaker: 手順 10、 3の画像 2 Nothing Phone (1) Earpiece Speaker Replacement, Remove the earpiece speaker: 手順 10、 3の画像 3
    この手順で使用する道具:
    • Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
    • Use your spudger to pry up the earpiece speaker.
    • Use a pair of tweezers or your fingers to remove the earpiece speaker.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
メンバー登録日: 11/23/16
230,367 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,545のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 47
今までの合計 1,313
