メインコンテンツにスキップ
Motorola Edge Loudspeaker Replacement
Jennifer Berg
Jennifer Berg とその他 4 人の作成者
最終更新日: March 21, 2025
30 - 45 分
中レベル
Follow this guide to remove and replace the loudspeaker on a Motorola Edge.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
必要な工具と部品
ツール
もっと見る
  1. Motorola Edge Loudspeaker Replacement, Heat the bottom edge: 手順 1、 1の画像 1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
    I am having no luck removing the back cover on Moto edge. Can apply heat for more than 2 minutes?
    John Wright - 返信
    You may! Heating beyond two minutes won't hurt your device; the iOpener doesn't get hot enough to do that. Apply the iOpener as long and as much as you need to loosen the adhesive.
    Alex Diaz-Kokaisl -
  2. Motorola Edge Loudspeaker Replacement, Separate the bottom adhesive: 手順 2、 3の画像 1 Motorola Edge Loudspeaker Replacement, Separate the bottom adhesive: 手順 2、 3の画像 2 Motorola Edge Loudspeaker Replacement, Separate the bottom adhesive: 手順 2、 3の画像 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge Loudspeaker Replacement, Slice the bottom adhesive: 手順 3、 3の画像 1 Motorola Edge Loudspeaker Replacement, Slice the bottom adhesive: 手順 3、 3の画像 2 Motorola Edge Loudspeaker Replacement, Slice the bottom adhesive: 手順 3、 3の画像 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola Edge Loudspeaker Replacement, Heat the right edge: 手順 4、 1の画像 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola Edge Loudspeaker Replacement, Separate the corner adhesive: 手順 5、 3の画像 1 Motorola Edge Loudspeaker Replacement, Separate the corner adhesive: 手順 5、 3の画像 2 Motorola Edge Loudspeaker Replacement, Separate the corner adhesive: 手順 5、 3の画像 3
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola Edge Loudspeaker Replacement, Separate the right adhesive: 手順 6、 3の画像 1 Motorola Edge Loudspeaker Replacement, Separate the right adhesive: 手順 6、 3の画像 2 Motorola Edge Loudspeaker Replacement, Separate the right adhesive: 手順 6、 3の画像 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola Edge Loudspeaker Replacement, Remove the back cover: 手順 7、 3の画像 1 Motorola Edge Loudspeaker Replacement, Remove the back cover: 手順 7、 3の画像 2 Motorola Edge Loudspeaker Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola Edge Loudspeaker Replacement, Remove the motherboard's screws: 手順 8、 1の画像 1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola Edge Loudspeaker Replacement, Remove the motherboard cover: 手順 9、 3の画像 1 Motorola Edge Loudspeaker Replacement, Remove the motherboard cover: 手順 9、 3の画像 2 Motorola Edge Loudspeaker Replacement, Remove the motherboard cover: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  10. Motorola Edge Loudspeaker Replacement, Disconnect the battery cable's press connector: 手順 10、 2の画像 1 Motorola Edge Loudspeaker Replacement, Disconnect the battery cable's press connector: 手順 10、 2の画像 2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Motorola Edge Loudspeaker Replacement, Remove the daughterboard's t5 screws: 手順 11、 2の画像 1 Motorola Edge Loudspeaker Replacement, Remove the daughterboard's t5 screws: 手順 11、 2の画像 2
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  12. Motorola Edge Loudspeaker Replacement, Remove the daughterboard cover: 手順 12、 3の画像 1 Motorola Edge Loudspeaker Replacement, Remove the daughterboard cover: 手順 12、 3の画像 2 Motorola Edge Loudspeaker Replacement, Remove the daughterboard cover: 手順 12、 3の画像 3
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
    Where is the speaker location? That's title of this video. Tho I do appreciate the video showing how to open it up.
    Ms. M - 返信
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
作成者
4人の作成者と共同で作成されました。
Jennifer Berg
メンバー登録日: 03/21/22
2,759 ポイント
24のガイドは作成済み
1件のガイドコメント
I replaced my charging port and needed to move the loudspeaker. When I put my loudspeaker back in my phone I noticed it doesn't work. I believe this also houses the vibration mechanic, and the phone vibrates.
My question is: How does the loudspeaker actually connect to the phone? From what I can see it's just a floating piece with no type of connector from this piece to the phone. I would like to verify if I may have connected it incorrectly before I purchase another loudspeaker.
QuadMind - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 316
