Motorola Edge Loudspeaker Replacement
はじめに
手順 1 に進むFollow this guide to remove and replace the loudspeaker on a Motorola Edge.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave the pick in to prevent the adhesive from resealing.
Rotate the opening pick around the bottom-right corner of the phone.
Insert a new opening pick into the gap you just created.
Slide the pick along the right edge of the phone to separate the adhesive.
Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
Remove the back cover, taking care not to damage the components inside the phone.
Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
この手順で使用する道具:Tweezers$4.99
Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
コメント 1 件
I replaced my charging port and needed to move the loudspeaker. When I put my loudspeaker back in my phone I noticed it doesn't work. I believe this also houses the vibration mechanic, and the phone vibrates.
My question is: How does the loudspeaker actually connect to the phone? From what I can see it's just a floating piece with no type of connector from this piece to the phone. I would like to verify if I may have connected it incorrectly before I purchase another loudspeaker.
