メインコンテンツにスキップ
Motorola Droid Turbo 2 Midframe Replacement
Arthur Shi
Arthur Shi とその他 7 人の作成者
最終更新日: May 23, 2024
20 - 40 分
中レベル
Follow this guide to remove the midframe of the Droid Turbo 2.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Motorola Droid Turbo 2 Midframe Replacement, Midframe: 手順 1、 3の画像 1 Motorola Droid Turbo 2 Midframe Replacement, Midframe: 手順 1、 3の画像 2 Motorola Droid Turbo 2 Midframe Replacement, Midframe: 手順 1、 3の画像 3
    • Power off your phone before you begin working.
    • Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • Remove the SIM card tray assembly from the phone.
  2. Motorola Droid Turbo 2 Midframe Replacement: 手順 2、 1の画像 1
    • Heat an iOpener and apply it to the top edge of the phone for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Droid Turbo 2 Midframe Replacement: 手順 3、 2の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 3、 2の画像 2
    • Angle an opening pick and firmly press so that it slips under the back cover.
    • Depending on the age of the phone, this can be difficult. Additional heating with the iOpener may help. You can pry carefully with a metal spudger to create a gap for the opening pick.
  4. Motorola Droid Turbo 2 Midframe Replacement: 手順 4、 3の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 4、 3の画像 2 Motorola Droid Turbo 2 Midframe Replacement: 手順 4、 3の画像 3
    • Slide the opening pick along the top edge of the phone to break up the adhesive.
    • Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
  5. Motorola Droid Turbo 2 Midframe Replacement: 手順 5、 3の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 5、 3の画像 2 Motorola Droid Turbo 2 Midframe Replacement: 手順 5、 3の画像 3
    • Repeat the iOpener heating and slicing procedures for the remaining three sides.
    • Make sure to cut into the deeper areas as the back cover is held on by a large adhesive surface.
  6. Motorola Droid Turbo 2 Midframe Replacement: 手順 6、 3の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 6、 3の画像 2 Motorola Droid Turbo 2 Midframe Replacement: 手順 6、 3の画像 3
    • Once you have cut through the adhesive, slowly peel the back cover away from the frame.
    • Remove the back cover.
    • During reassembly, follow this rear cover adhesive guide to properly apply the pre-cut adhesive strip.
  7. Motorola Droid Turbo 2 Midframe Replacement: 手順 7、 3の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 7、 3の画像 2 Motorola Droid Turbo 2 Midframe Replacement: 手順 7、 3の画像 3
    • Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
    • To reinstall the cover, align the cover and use your finger to push it forward into place.
  8. Motorola Droid Turbo 2 Midframe Replacement: 手順 8、 3の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 8、 3の画像 2 Motorola Droid Turbo 2 Midframe Replacement: 手順 8、 3の画像 3
    • Use the point of a spudger to pry up and remove the coil connector rubber cover.
  9. Motorola Droid Turbo 2 Midframe Replacement: 手順 9、 2の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 9、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the flash connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  10. Motorola Droid Turbo 2 Midframe Replacement: 手順 10、 2の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 10、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
  11. Motorola Droid Turbo 2 Midframe Replacement: 手順 11、 1の画像 1
    • Remove the following T3 screws securing the midframe:
    • Thirteen 3.1 mm black screws
    • Four 4.3 mm silver screws
    • Due to screw and bit variance, you may have better luck with a T4 driver. The proper bit should seat fully in the screwhead and feel slightly loose. The bit should not feel like it's stuck in the screwhead.
  12. Motorola Droid Turbo 2 Midframe Replacement: 手順 12、 2の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 12、 2の画像 2
    • Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
  13. Motorola Droid Turbo 2 Midframe Replacement: 手順 13、 2の画像 1 Motorola Droid Turbo 2 Midframe Replacement: 手順 13、 2の画像 2
    • Remove the midframe from the phone.
    • You can tape over the side buttons to prevent them from falling out during your repair.
    • If the buttons fall out of the midframe, reinsert them in the orientation as shown before you reinstall the midframe.
終わりに
Repair didn’t go as planned? Check out our Motorola Moto Droid Turbo 2 Answers community for troubleshooting help.
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
283,144 ポイント
587のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,550のガイドは作成済み
3 件のコメント
Other than the comments I left above, I felt this was a nice simple-to-follow guide that gives me confidence to try this myself.
If you fix the items listed above, it will be perfect.
Thanks!
pj.catania - 返信
Good post and the extra comments help.
Jane Doe - 返信
Where can I buy a good T3 screwdriver?
I have tried 3 brands and the screwdriver rounds off instead of removing the screw.
David Peterson - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 20
今までの合計 7,631
