MacBook Pro 13" Retina Display Early 2015 ヒートシンクの交換
はじめに
手順 1 に進むヒートシンクを交換したり、取り外すにはこの手順を参照してください。
この手順で使用する道具:Magnetic Project Mat$19.95
上部ケースと底ケースを留めている次の10本のネジを外します。
2.3 mm P5ペンタローブネジ−2本
3.0 mm P5ペンタローブネジー8本
この修理では、各ネジの装着位置をメモ書きして管理してください。再組み立ての際は、デバイスにダメージを与えないよう、正しい場所に装着してください。
上部ケースと底ケースの間に指を差し込みます。
ゆっくりと底ケースを上部ケースから離していきます。
To reattach bottom case I found it helpful to line fingers up with clips under case should snap easily
If your old battery has swollen, the lower case may “pop” open. Don’t lose your screws!
I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
If you’re doing an iFixIt battery replacement, the replacement battery has two rubber nubs which are right where the clips are that receive these studs. Folks have been saying it’s hard to get the studs to clip back in after replacement, and I had the same issue. I trimmed the top of these rubber nubs, which are a bit bigger than those on the original battery, with some side cutters. That made the fit much better.
Rob Gorbet - 返信
A plastic foam cover also covers plug and socket and the whole battery. It is easy to remove it from the right side to the trackpad wire that the battery plug is free like shown in the picture. I kept it to use it again later.
I have done tons of these battery replacements.
You don’t need to do anything on the list after you disconnect the battery, apart from carefully moving the speakers out of the way, and then prise up the battery modules. I just very carefully, and with little even motions, use a large slot screwdriver. Being careful to keep it flat, to not puncture the battery.
Easy peasy. I have never had an issue after dozens of the tasks…
davelarose - 返信
Dear Sir,
as you seem to be very much experienced with battery replacements you might perhaps give me a hint why after having removed the battery pack successfilly, the keyboard doesn't work anymore after booting the system. The Touchpad works, the keyboard backlight works but typing does not function at all.
I only disconnected the battery connector and touched nothing else. I am quite desperate …
I agree with Dave la Rose, provided you use heat rather than solvent to remove the old battery (or possibly floss, haven’t done that). Please see my comment further down this thread on how to use an iOpener for correctly heating the glue joint
After removing battery contact board plastic. My screwdriver accidentally fell and touched the battery board. And it short circuited. Now my battery doesn't charge. My laptop doesn't work without charger now. shuts after a few minutes of use. Can i fix it without sending it for repairs?
Is replacing the battery necessary?
スパッジャーの平面側先端を使って、バッテリーコネクターをロジックボード上のソケットからまっすぐ持ち上げます。
I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
+1
I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
Lift from the long, flat side, not the shorter side. In this picture, you should lift from the NORTH part of the connector, not the WEST side like they are doing. This is because you can spread the pressure from lifting the connector across more area, as compared to the side. I accidentally broke off part of my battery connector lifting it up the way shown, but was able to do it the way I described without problem. Make sure to lift from the wide part so you don’t have my same trouble!
The connector is no more than 1mm thick… the socket is 3-to-4mm deep so make sure you’re trying to remove the connector itself, and not pulling at the socket.
Richie Egg - 返信
You can do it from the side like the picture, but i would recommend twisting almost like a screw driver once you have leverage under the overhanging part of the left side like in the picture. Twist the tool so that it starts to put pressure on the top, until you’ll hear it click out. You can be somewhat forceful but it shouldn’t require a lot of strength. Guiding the tool with one hand and twisting with the other is a good way to attempt this.
After I put the battery back I found out at this step that the new battery connector was off by 2 mm (because I installed my battery slightly off). Since the connector is rigid, I removed it’s plastic cover (just like we all did in Step 4) to free the cable, which allowed me to bent it enough to properly plug the connector.
Well, I’m reading this step in the battery replacement repair guide, so it’s pretty critical to disconnect the battery from the main board. I’m guessing these steps are reused in other guides where disconnecting the battery might not be such an obvious need.
surf -
Also wondering the same. I came here from a link to replace the fan. Is it necessary to disconnect the battery inorder to replace the fan?
The connector wires from the battery to the connector are long
You'll have to bend them downward and into the small cove that exists so the connector can fit in place.
So use the a plastic card or flat end of the spudger to bend them downward and folded a bit back so the connector will fit in place.
Use your old battery as a guide for how they should be bent.Hi All ,
I followed the instructions step by step and changed the board successfully and reconnected everything back. When I powered it back on I can see it is charging again however it just displays a black screen and no display. Keyboard light comes on as well and the apple logo light on the back lid also turns on. Not sure what is wrong ? It has been charging for more than 15 minutes and still no joy. Anyone able to help solve or identify the issue .
Thanks
The connector cover is slightly wider and longer than the socket (<1mm) so there is a small "lip" around the top that can be used to lift it.
If your are not familiar with those repairs, and as with most of those connections, I recommend to take the time to observe your computer and the pictures from the tutorial, reading instructions and comments before starting each step. This battery connector needs both a bit of force and of precision. For a battery repair the connection of the new battery is a bit more tricky, you need to have your battery in the right position and to force it a bit the connector
David Obis - 返信
Hi, I only want to remove/examine/possibly replace the left speaker as it's crackling..........I don't think I need to remove the battery connector to the logic board?
Did you get an answer to your question? I have the same thought.
If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
@sebasgaes, shoot, I'm only part way through the process, but I skipped this step thinking it wasn't necessary. I'm only through step 12 right now, but is there a fix if my machine doesn't recognize the wifi hardware after I've put it all back together? I don't see reference to the "I/O board cable" anywhere else in the instructions, so I'm confused about your mention of that...
UPDATE: I completed the job, rebooted, and all is well, wifi and all. Thanks anyway; gotta love iFixIt!!
jiclark -
ヒートシンクの端からゴム製のファンバンパーを丁寧に取り出します。
have lost the rubber fann bumper, what part do you have to buy to get this rubber? thank you
I changed out the noisy fan around 4-5 months ago. And lately it was back and I was super irritated about the poor quality of the replacement fan. Opening up the case and blowing on the ventilator some compressed air there was no noise whatsoever. I have this feeling that my “noisi fan” was actually the loose end of this rubber cover/bumper which could vibrate in the air flow channel. So verify that you insert rubber cover clips back to its slots on under the edge of the sink.
Use a flashlight and magnifying glass to see how the bottom of the bumper that wraps around the heatsink sits into the fan duct before you remove it. If it is not seated properly it can make noise. You’re welcome.
スパッジャーの平面側先端を使って、4つのフォーム製ステッカーをヒートシンクのネジから剥がします。
Ok, might be a dumb question, but where can I get the foam stickers, and are they absolutely necessary after reassembling the heat sink?
I re-used the ones that I pulled off, and my guess is that they aren’t really necessary since they seem to just fit between the Torx screws and the bottom cover. I really doubt they are part of the heat removal system but are there to prevent vibration.
When I removed the pads, they separated from the double face tape adhering them to the screws. The tape stuck to the screws. I lifted the tape off with a utility knife and saved it. On reassembly, the tape would stick to the screws, but would not hold the pads. Still worthwhile putting the tape on the screws because it keeps adhesive from clogging the head of the screw. I cleaned the pads well (IPA or denatured alcohol will work). To get them to stick I put a minuscule dab on the screw and on the bottom of the pad.
ロジックボードに留められたヒートシンクから次のネジを外します。
2.7 mm T5ネジ(シルバー)ー1本
T5ネジ(黒)ー4本
Please be very very careful when reassembling. The four black screws seem to be poor quality and the top snapped off two of them when trying to tighten them. Does anyone know the size of these or compatibility from other models as finding a replacement for them is proving to be almost impossible without shipping them in for a ridiculous price…
The single screw on the left hand side on the image above, what type of screw is it? The one on my Macbook is a phillips head one. And for some reason, I couldn’t put it back. Any advise?
These should all be T5 Torx screws. There could be variations in the construction of the laptop compared to this guide, but I’d check out our ID Your MacBook tool to be sure you’re following the correct guide! If you are following the correct guide, be sure all the elements under the screw are properly seated, if they’re not well aligned the screw may not get a good anchor. Best of luck!
I can confirm that on my 2015 13” Macbook Pro, the single screw on the left hand side is a #000 phillips screw.
Mine is also a philips head
They are Torx T5 on my MacBook Pro (Retina, 13-inch, Early 2015)
I’m doing 2 early 2015 13” macbook pro’s right now simultaneously and both have same size torx for all 5 screws. Upgrading logic board in one and putting its old logic board in dead mac.
BTW, I’m a double EE, been doing this a long time and wanted to mention that i use only high quality German made tools for my torx and other drivers. I have found repeatedly, that the cheap tools that are given away in kits, wear out fast, sometimes after one use and lead to issues with fasteners. My drivers are made by WIHA. They are expensive but well worth it if you plan on doing this more than once or even once!
For those of you that do have the Phillips head for the single screw on the left-hand side, do you have a driver suggestion that worked well for you, without stripping the head? I have tried the 000 bit and one of the 000 drivers from ifixit but those are beginning to strip the head. I need a driver that has deep drive but I’m unsure as to which brand I should buy. I’ll spend the money for the right driver. Thanks!
Ray Grogan - 返信
You can't go wrong with WIHA.
Dumb question - if my replacement logic board comes with a new heat sink attached, can I ignore these steps (other than removing the red-circled screw)? Hoping so since this part seems like a PITA.
I too have a Phillips head for that one screw (early 2015 13” retina MBP, technically an Apple refurb). The bit I used is labelled J000 from my precision toolkit. Be careful since it so small, but i had no issues with tearing up the screw head.
ラップトップからヒートシンクを取り出します。
We need a picture of reinstallation of the 2.7mm T5 screw on the left side of the thermal bar on the head sink. That screw goes into the stud that was previously installed. It is the only place in the computer that uses a combination post. In my machine, that screw was not silver. I don't know if that was standard or not.
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
58 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
6 件のコメント
what part should i purchae to get the rubber fan bumper?
Bonjour !
Merci pour ce tutoriel de qualité ! Pour la pâte thermique, j’ai opté pour la Grizzly Kryonaut… Un peu overkill pour un MBP 13” de 2015, mais cela devrait contribuer à sa longévité !
Une remarque cependant : sur mon modèle, la vis en ROUGE de l’ETAPE 9 n’était pas une Torx T5, mais une Y00 ! Cela ne m’a pas posé de problème car j’avais le kit complet de tournevis, mais cela l’aurait été si je n’avais acheté qu’un P5 et un T5 ! Faites attention !
Bonne continuation !
PS: si certains doutent de leurs capacités à réaliser cette opération, sachez que je suis grand débutant en informatique et que je n’ai eu AUCUN problème. La partie la plus ardue étant le retrait du connecteur de la batterie !
Used this guide to pop the heat sink and scrape off the old thermal paste. Cleaned and re-applied with new paste, hopefully leading to better thermal performance. One thing I noticed is that the heatsink doesn’t cover the second module (presumed to be the integrated GPU) next to the CPU? Perhaps this is why thermal performance is so abysmal on these little guys.
In my MacBook Pro, the screw in step 9 that is farthest away from the CPU is a Philips screw, rather than T5 Torx.
I bought my MacBook Pro in 2016, over a year after it came out, so this might be different depending on when yours was manufactured.
I had to replace the thermal paste of my MBP 13" early 2015 (A1502) it was always in the 74°C even when I was not doing anything, and the fan was obviously overworking.
I was confused by so many comments on whether I should put a pea size or a line of my thermal paste (Noctua NT-H1 3.5g) I went for a little line and didn't touch it. I didn't apply any on the little left square (I saw some people doing it but mine didn't have any before, so I chose not to). I used a microfiber cloth and cleaned everything, no isopropyl alcohol was needed. Go with what you think is best !
Once I turned on the mac, the temperature was just in the 50-60° and almost reached 70° for a slight second. I was expecting much better. But the next day, the temperature was cruising in the 40° range. I guess the paste needed some time to spread, I'm still happy to not have spread it myself.
The screw everyone is talking about, mine was a T5.
Good luck, it's not complicated, you got this !
For all the screws you use the P5 pentalobe screwdriver?
Carlos - 返信
Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
Fredrik -
I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
marketing - 返信
I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
On a side note, only use quality tools, the cheap ones will break or strip the screws.
Dustin Steward - 返信
Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
doubleclutch - 返信
This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
Evan Shulman -
A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
Note that this is a useful technique when installing ANY threaded fastener.
doubleclutch - 返信
Hi peeps,
I have a wifi problem on this MBP 13” early 2015 and was pleasently surprised to find your guide to changing the airport card.
However upon closer inspection it seems that on my MBP (purchased new or so I thought) the 3 antennae seem so have been soldered together at the point where they are clamped to the chassis. I have photos but cannot post here. Can anyone conform that where the 3 antennae wires are held to the chssis by the 2 scew metal support (just before disappearing into the screen hinge), the support is not meant to short the 3 wires together. This makes no sense for 3 seperate antennae wires.
Any advice /close up photos is welcome here.
dom
colonel mustard - 返信
Tip: Use post-it notes to keep track of screws
1. Pack of post it notes
2. Stick screws to the sticky part of the post it note
3. Write on the post it note which step and what kind of screw it is
ibash - 返信
Hi, in order to drain the battery I am running:
yes > /dev/null
in 4 terminals, so the CPU maxes out at almost 99%.
I hope this speeds up the battery draining process.
And the backlight is at maximum brightness :-)
You can see the cpu load in Activity Monitor.
Its draining at 20% per 15 minutes.
Any concerns about draining the battery in this way?
Andre van der Ham - 返信
Something I’ve been curious about, is it possible to upgrade a late 2013 Retina model MacBook Pro, with the improved 16gb ram and i7 processor logic board from the 2015 retina model? I’d be interested to try but not ready to shell out the $500+ to be the first lol
Chat Dawgie - 返信
Without rehashing what others have said, I would highly recommend reading through the steps *and* the comments for each before tackling your replacement for tips. Highlights for me were: only disconnecting what actually needed to be disconnected, rotating the spudger to release the track pad cable, a hair dryer worked perfectly fine, and the pencil outline of the battery before you remove. You got this!
N DesRochers - 返信
Installation of replacement AirPort card was easier than I had expected thanks to this guide. Thank you.
chaslaw - 返信
I use replaced SSD and it was super easy and working great. I can finally upgrade Mac OS with plenty of room to spare and no more low memory alerts. Well worth investment and didn’t have to buy new laptop
Pete James - 返信
It's interesting that this tutorial is rated Moderate even though you need to remove the battery. The battery removal tutorial which is basically the same but with fewer steps is rated Difficult.
Marv Ruona - 返信
when i pulled the screws out i arranged them in the same way they were in. the top 2 middle screws appeared to be shorter than the rest. in order to keep them in place i got a square of packing tape sticky side up, taped both sides down with 2 other pieces of tape. and then put the screws head down in the order i pulled them.
Jason Wade - 返信
Excellent instructions although checking battery and speakers aligned before fixing batteries into place is essential. MacBook good as new!
John Foreman - 返信
I find it helpful to spread a soft, slightly fuzzy cloth (like flannel) over my workspace before doing something with small parts. It keeps screws and things from rolling or bouncing away. A towel might be too plush, though, as a screw might get lost in it.
Richard KeslerWest - 返信
I cannot get the two screws (that are different than the other ones) out and now they’re stripped. Any idea what to do without using a drill?
Honeybee94 - 返信
DO NOT REMOVE SPEAKER CABLES!! The connectors are fragile. Just remove speakers and bend attached cable away from battery. Same for trackpad cable connector at front side. This cable crosses the middle of the battery. Just remove the one connector on the back side - leave front side connector attached and fold cable toward front of computer out of way of battery.
Paul Lebow - 返信
Is there a mistake in the wrench size?
When I did it I used a 1.3mm one.
ちくわちくわ - 返信
The Dutch site fixje.nl says (see under "Welke MacBook Pro A1502 batterij kopen?") that the A1582 battery, which is for the Early 2015 version of the A1502 13-inch MacBook Pro, will fit the Late 2013–Mid 2014 versions of the A1502 13-inch MacBook Pro.
The A5182 battery has a higher capacity (6559 mAh) than the A1493 battery (6330 mAh), which is for the Late 2013–Mid 2014 models.
Can anyone confirm that the Early 2015 battery will actually fit in and work with the earlier A1502 models?
Philip Dygeus - 返信
Just finished the battery replacement for Macbook Pro 13 in Early 2015. Followed the instructions to the letter. Everything went back together perfectly and now waiting for the battery to charge. Very appreciative of the instructions and the tools provided to do this job! Thank you iFixit!!
LOL - now considering replacing the SSD hard drive...
Abraham Wick - 返信
