メインコンテンツにスキップ
DJI Mavic Pro Front Arm Assembly Replacement
Jamie Bell
Jamie Bell とその他 4 人の作成者
最終更新日: July 11, 2022
見積もりなし
難しい
コミュニティメンバーによる寄稿ガイド
I did a dumb and bonked my not-under-warranty drone into a tree branch. If you’re here you probably bonked yours into something too. Hopefully this will help you get your baby airborne again!
必要な工具と部品
パーツ
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. DJI Mavic Pro Front Arm Assembly Replacement, Top Cover: 手順 1、 1の画像 1
    • Remove 6 hex screws from top cover. These are 1.5 mm and the same length.
  2. DJI Mavic Pro Front Arm Assembly Replacement: 手順 2、 1の画像 1
    • Remove two hex screws on either side of the gimbal. These are 1.5 mm and the same length as the 6 top cover screws.
    • Remove two smaller hex screws from the covers under the front arms. These are 1.5 mm and SHORTER than the prior screws.
  3. DJI Mavic Pro Front Arm Assembly Replacement: 手順 3、 1の画像 1
    • Use the flat end of a spudger to remove the covers under the front arms
    • These covers are fitted tightly enough that it's difficult to get a pry tool underneath. I found that when I pressed my thumb against the outside corner (red arrow) I got just enough of a gap on the opposite side (orange arrow) to squeeze a pry tool into it.
  4. DJI Mavic Pro Front Arm Assembly Replacement: 手順 4、 2の画像 1 DJI Mavic Pro Front Arm Assembly Replacement: 手順 4、 2の画像 2
    • Remove the two 1.5mm hex screws under the cover
  5. DJI Mavic Pro Front Arm Assembly Replacement: 手順 5、 2の画像 1 DJI Mavic Pro Front Arm Assembly Replacement: 手順 5、 2の画像 2
    • Lift the back end of the cover
    • The cover is connected to the body by a cable. Don't open the cover all the way until this cable is unplugged!
    • Unplug the 6-pin GPS connector, then pry along the edges to release the plastic clips holding the top down
    • Remove the cover
    • The clips at the nose of the drone require some extra pressure to release
  6. DJI Mavic Pro Front Arm Assembly Replacement, Desolder the arm wires: 手順 6、 1の画像 1
    • Desolder the larger gray motor wire running to the arm to be replaced
    • Desolder the larger white motor wire
    • Desolder the larger black motor wire
    • Desolder the smaller black LED wire
    • Desolder the smaller white LED wire
    • The marked wires are for the right arm. The wires to desolder when replacing the left arm are the mirror image of the ones shown here.
    • Don't forget that plastic has a tendency to melt when exposed to heat! I may or may not have disregarded this fact and put a mark on my drone...
  7. DJI Mavic Pro Front Arm Assembly Replacement, Remove the bottom heat plate: 手順 7、 1の画像 1
    • Remove 2 hex screws with longer posts
  8. DJI Mavic Pro Front Arm Assembly Replacement: 手順 8、 1の画像 1
    • Remove bottom heat plate
    • This plate may stick a bit due to the thermal compound underneath it. It's a good idea to replace the thermal paste during reassembly
  9. DJI Mavic Pro Front Arm Assembly Replacement, Antenna cable: 手順 9、 1の画像 1
    • If replacing the right front leg, unplug the white front antenna cable
    • If replacing the left front leg, unplug the black front antenna cable
  10. DJI Mavic Pro Front Arm Assembly Replacement, Remove front leg: 手順 10、 1の画像 1
    • On the top of the drone, gently release the rear leg cable bundle from its cable management clip
    • Lift the white or black wire from the previous step up through the drone
  11. DJI Mavic Pro Front Arm Assembly Replacement: 手順 11、 1の画像 1
    • Remove the Phillips head screw below the arm to be replaced
  12. DJI Mavic Pro Front Arm Assembly Replacement: 手順 12、 2の画像 1 DJI Mavic Pro Front Arm Assembly Replacement: 手順 12、 2の画像 2
    • Use a metal pry tool or flat head screwdriver to lift out the spring-loaded hinge
    • The spring in this hinge makes it difficult to reseat during reassembly. The easiest way I found to replace it was to fold the arm back into the closed position, and then grab across the top of the hinge with the very tip of a pair of needle nose pliers, using the pliers to rotate the hinge into position and press it down into place.
  13. DJI Mavic Pro Front Arm Assembly Replacement: 手順 13、 1の画像 1
    • Remove the arm
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jamie Bell
メンバー登録日: 08/01/19
433 ポイント
1ガイドが承認済み
4ガイドコメント
Bravo, thanks for the guide! I found myself in the middle of my repair cursing that antenna wire as I didn’t want to pull up the main board. Then I remembered my trusty secret weapon “ifixit.com”. Oh did you save the day for sure, I was hoping for another access point to unclip the antenna, just had no idea where that would be. I’ve been a fixer for 20 + years, but DJI drones are not something you generally just want to go poking and prodding around blind. So a big thanks for helping me get in and out with ninja precision fellow fixer!
Caleb Fitzgerald - 返信
Glad I could help! They’re definitely complicated little buggers.
Jamie Bell -
Did you use some glue along the three wires for the motor arm? This was destroyed when I replaced one damaged arm. Do you know what type of glue would be good to use?
jookieapc - 返信
I didn’t use any glue, and I haven’t had any issues with it leaving it out. It looks like the original glue is some sort of silicone glue. I would think you could probably use an electronics-safe silicone adhesive, like something you could get from a hobby shop, but I haven’t tried it myself so I couldn’t say for sure.
Jamie Bell -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 56
今までの合計 4,190
