メインコンテンツにスキップ
Black and Decker CM0700BZ Water Piping Replacement
Shawn Robichaud
Shawn Robichaud とその他 4 人の作成者
最終更新日: October 30, 2024
10 - 15 分
中レベル
The water pipes may become clogged, dirtied, or damaged to the point where they have to be removed and cleaned, or replaced entirely. This guide will show the steps to the disassembly process.
必要な工具と部品
ツール
もっと見る
  1. Black and Decker CM0700BZ Water Piping Replacement, Lid: 手順 1、 2の画像 1 Black and Decker CM0700BZ Water Piping Replacement, Lid: 手順 1、 2の画像 2
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Water Piping Replacement: 手順 2、 3の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 2、 3の画像 2 Black and Decker CM0700BZ Water Piping Replacement: 手順 2、 3の画像 3
    • Place your finger, screwdriver, or spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Water Piping Replacement: 手順 3、 3の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 3、 3の画像 2 Black and Decker CM0700BZ Water Piping Replacement: 手順 3、 3の画像 3
    • Hold the tab while pushing back on the lid.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Water Piping Replacement: 手順 4、 2の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 4、 2の画像 2
    • Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
    • Pry facing away from the lid to force the peg out.
    • You should hear a pop when it disconnects.
    • Hold the lid and pull it away from the other insert.
  5. Black and Decker CM0700BZ Water Piping Replacement: 手順 5、 1の画像 1
    • To also remove the shower head, use the Shower Head guide.
  6. Black and Decker CM0700BZ Water Piping Replacement, Water Pipes: 手順 6、 2の画像 1 Black and Decker CM0700BZ Water Piping Replacement, Water Pipes: 手順 6、 2の画像 2
    • Remove the carafe holder from the bottom of the coffee machine.
  7. Black and Decker CM0700BZ Water Piping Replacement: 手順 7、 3の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 7、 3の画像 2 Black and Decker CM0700BZ Water Piping Replacement: 手順 7、 3の画像 3
    • Place coffee maker on its side, with the bottom facing you.
    • Remove two 10mm Phillips #1 screws and one 10mm Tri-Point Y1 screws with their designated tips.
  8. Black and Decker CM0700BZ Water Piping Replacement: 手順 8、 3の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 8、 3の画像 2 Black and Decker CM0700BZ Water Piping Replacement: 手順 8、 3の画像 3
    • Slowly pry bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid and set aside.
  9. Black and Decker CM0700BZ Water Piping Replacement: 手順 9、 1の画像 1
    • Follow Step #4 of the Power Button guide, but leave the button in the machine.
  10. Black and Decker CM0700BZ Water Piping Replacement: 手順 10、 3の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 10、 3の画像 2 Black and Decker CM0700BZ Water Piping Replacement: 手順 10、 3の画像 3
    • Remove the four 10mm Phillips #1 screws.
    • Slowly pull the water tank up to expose the water pipes.
  11. Black and Decker CM0700BZ Water Piping Replacement: 手順 11、 3の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 11、 3の画像 2 Black and Decker CM0700BZ Water Piping Replacement: 手順 11、 3の画像 3
    この手順で使用する道具:
    • Squeeze on the prongs with tweezers and hold.
    • Pull the water tank while squeezing the tighteners to loosen the water pipes off of the water tank.
    • The heating element should now be loose. Remove the heating element from the machine.
  12. Black and Decker CM0700BZ Water Piping Replacement: 手順 12、 2の画像 1 Black and Decker CM0700BZ Water Piping Replacement: 手順 12、 2の画像 2
    • Squeeze and hold with tweezers again.
    • Pull the water tubes off the heating element while squeezing with tweezers.
終わりに
作成者
4人の作成者と共同で作成されました。
Shawn Robichaud
メンバー登録日: 10/26/22
729 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 UMass Dartmouth, Team 1-2, Shaddix Spring 2023人のメンバー
UMASSD-SHADDIX-S23S1G2
4 メンバー
15のガイドは作成済み
コメント 1 件
Thanks! Just cleaning out the shower head helped it with the pluged tube. (That and vinegar+ and a splash of a strong liquid cleaner... ) cough — For some reason I decided (stupidity) to pour brewed coffee back into the tank and it had grounds on the bottom. Talk about a blondie moment! 😅 I'm just glad it's working, am never doing that again!
Jess - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 23
今までの合計 667
