コンデンサ交換
1 件の回答 0 スコア |
Nespresso Vertuolineのライトが2回点滅、一時停止、2回点滅などを繰り返します。 |
1 件の回答 0 スコア |
アップルビネガーで洗浄した後、上手く機能しません |
36件の回答 262 スコア |
My Keurig makes brewing noises but doesn't brew. |
37件の回答 11 スコア |
Why is my Keurig Classic constantly turning off while brewing? |
ドキュメント
パーツ
- Delonghi Filter 1-Dose Coffee with Rib - AS00002564
- Delonghi Tray - Coffee Waste Container - 5313228721
- Delonghi Rubber Cleandisk (Black) - AS00001634
- Delonghi Glass Carafe - HZ1029
- Delonghi Water Tank - AS13200250
- Delonghi Water Tank Cover - 7313286089
- Delonghi Carbon Filter - 7313285779
- Delonghi Infuser Diffuser Kit - 7313251451
ツール
モデル
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC 272以上表示
BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
概要
コーヒーメーカーは、家庭や商業施設で手軽にコーヒーを淹れるために設計された家電製品です。さまざまな種類があり、それぞれ異なる方法でコーヒー豆から風味を抽出します。
種類
ドリップコーヒーメーカー
ハンドドリップコーヒーメーカー
ハンドドリップコーヒーメーカーは、コーヒー愛好家が抽出プロセスをより細かくコントロールできる手動抽出器具です。基本的な構造は、紙フィルターや金属フィルターをセットする漏斗状または円錐状のドリッパーで構成されています。フィルターに挽いたコーヒー粉を入れ、ゆっくりと慎重に熱湯を注いで抽出します。
自動ドリップコーヒーメーカー
自動ドリップコーヒーメーカーは、利便性と使いやすさを追求して設計された一般的な電動抽出器具です。抽出プロセスが自動化されており、貯水タンクに水を入れ、フィルターバスケットにコーヒー粉をセットして本体のスイッチを入れるだけで使用できます。加熱された水がコーヒー粉の上に滴下され、抽出されたコーヒーはフィルターを通ってポットやカラフェに溜まります。ポットの下には保温プレートがあり、コーヒーの温度を維持します。モデルによっては、抽出濃度を調節したり、タイマー設定ができる機能も備えています。
浸漬式コーヒーメーカー
コールドブリュー(水出し)コーヒーメーカー
コールドブリューコーヒーメーカーは、水出しコーヒーを簡単かつ効率的に作るための器具です。一般的に、粗挽きのコーヒー豆を冷水または常温水に長時間(通常12〜24時間)浸漬します。できあがるコーヒーは、酸味が少なくまろやかな濃縮液で、飲む前に水やミルクで薄めて楽しむことができます。粉を分離するためのフィルターやメッシュシステムが備わっていることが多く、抽出プロセスが手軽で汚れにくいのが特徴です。
フレンチプレス
フレンチプレスは、シンプルで効果的なコーヒー抽出器具です。円筒形のガラス製またはステンレス製の容器に、プランジャー(押し棒)と金属製のメッシュフィルターが組み合わされています。抽出時は、粗挽きのコーヒー豆を容器内で熱湯に浸します。数分後、プランジャーを押し込むことで、コーヒー粉と抽出されたコーヒーを分離します。抽出中、コーヒー粉が水に直接触れ続けるため、コーヒー本来の風味を活かした濃厚な味わいを楽しめます。
トルコ式コーヒーメーカー
「ジェズベ」や「イブリク」と呼ばれるトルコ式コーヒーメーカーは、トルココーヒーを作るための伝統的な抽出器具です。通常は銅や真鍮製で、長い持ち手と広い底を持つ小ぶりのポットです。極細挽きのコーヒー粉、水、砂糖(お好みで)をジェズベに入れ、弱火で加熱します。混合液を何度も沸騰直前まで温めるという独特の抽出プロセスにより、「カイマク」と呼ばれる厚い泡を持った、強く濃厚なコーヒーができあがります。底に沈殿した極細挽きのコーヒー粉により、個性的で豊かなコーヒー体験が味わえます。
加圧式コーヒーメーカー
AeroPress
AeroPressは、シンプルさと多機能性を兼ね備えたコンパクトなコーヒーメーカーです。円筒形のチャンバー、プランジャー、フィルターキャップで構成されています。抽出時は、コーヒー粉と熱湯をチャンバーに入れ、かき混ぜてからフィルターキャップを装着し、プランジャーを押し込んでコーヒーを抽出します。独自のデザインにより、素早く簡単に抽出が可能で、抽出条件を自分でコントロールしながら、まろやかで豊かなコーヒーを淹れられることで知られています。携帯性、手頃な価格、そしてさまざまな抽出技術を試せることから、コーヒー愛好家に人気があります。
マキネッタ(直火式エスプレッソメーカー)
マキネッタは、蒸気圧を利用した沸騰水を通すことで、濃厚で風味豊かなコーヒーを淹れる直火式コーヒーメーカーです。下部の水用チャンバー、中央のコーヒー粉用漏斗、上部の抽出用チャンバーの3層構造になっています。水が加熱されると、蒸気圧によって水がコーヒー粉を通り抜け、濃厚で凝縮された「モカ」と呼ばれるコーヒーが抽出されます。プロセスは非常にシンプルかつ迅速で、エスプレッソに近い力強いコーヒーが淹れられることから人気があります。
カプセル式コーヒーメーカー
カプセル式コーヒーメーカーは、1杯分のコーヒーを抽出するために設計されたコンパクトで便利な家電です。専用のコーヒーポッドやカプセルを使用することで、手間をかけずに汚れも最小限に抑え、素早く簡単に1杯のコーヒーを淹れることができます。好みに合わせてさまざまな種類のコーヒーを選択でき、そのシンプルさと抽出時間の短さが支持されています。
エスプレッソマシン
エスプレッソマシンは、極細挽きのコーヒー豆に熱湯を強制的に通すことで、濃厚なコーヒーを抽出するために設計された専用器具です。通常約9気圧の高圧下で動作し、コーヒー粉から豊かな風味や香り成分を抽出します。エスプレッソの特徴は、力強く濃厚な味わいと、表面に形成されるクリーミーな泡の層である「クレマ」です。手動式、半自動式、全自動式など様々なタイプがあり、抽出プロセスのコントロールレベルを用途に合わせて選べます。
全自動コーヒーマシン
全自動コーヒーマシンは、コーヒー抽出プロセスを効率化した高度な家電です。コーヒー豆の粉砕から抽出までをすべてマシンが自動で行うため、手作業の必要がありません。抽出時の豆の挽き具合、コーヒーの濃度、飲み物の種類などをカスタマイズ可能で、エスプレッソ、カプチーノ、ラテ、レギュラーコーヒーなど多彩なメニューを楽しめます。内蔵グラインダーと自動抽出システムにより、手間をかけずに安定した品質の淹れたてコーヒーが楽しめます。
パーコレーター
パーコレーターは、ポット、中央の管、穴あきバスケットで構成された伝統的な抽出器具です。ポット内の水が加熱されると、その圧力で水が管を上昇し、バスケット内のコーヒー粉に注がれます。抽出されたコーヒーは再びポットに戻り、好みの濃度になるまで循環し続けます。かつては一般的でしたが、抽出方法や味の好みの変化により、現在ではその多くがドリップコーヒーメーカーに取って代わられています。
サイフォンコーヒーメーカー
サイフォンコーヒーメーカー(真空式コーヒー抽出器)は、物理学の原理を利用した視覚的にも魅力的な抽出器具です。2つのチャンバーで構成されており、下部のチャンバーで水を加熱すると蒸気圧が生じ、水が上のチャンバーへと押し上げられ、そこにセットされたコーヒー粉と混ざります。加熱を止めると、真空効果によって抽出されたコーヒーが再び下のチャンバーへと引き戻されます。このプロセスにより、豆の風味を最大限に引き出した、まろやかでクリアな味わいの香高いコーヒーが楽しめます。
追加情報
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
