MagSafeポート
2件の回答 0 スコア |
Spilled coke on my mac |
1 件の回答 0 スコア |
No Display outside of recovery. |
1 件の回答 0 スコア |
Replacing the space bar - without breaking the new one. |
1 件の回答 0 スコア |
Constantly reset myApple ID password, won't work on other devices |
パーツ
- MacBook Pro and MacBook Air (A2442, A2485, A2681, A2779, A2780, A2941, A2991, A2918, A2992, A3112, A3113, A3114, A3185, A3186, A3401, A3403) Key Caps
- MacBook Air 13" and 15" (A2681, A3113, A2941, A3114) Key Caps
- MacBook Air 15" (2024) Trackpad
- MacBook Air 15" (A2941, A3114) Display Assembly
- MacBook Pro and MacBook Air USB-C to MagSafe 3 Cable
- MacBook Air 15" (2024) Keyboard
- MacBook Air 15" (2024) Trackpad Cable
- MacBook Air 15" (2024) AMR Sensor
ツール
- iFixit Precision 4 mm Screwdriver Bit
- Tesa 61395 Tape
- Spudger
- iOpener
- Tweezers
- iFixit Opening Picks (Set of 6)
- Suction Handle
- Microfiber Cleaning Cloths
- iFixit Precision Bit Driver, Aluminum
- Plastic Cards
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
モデル
A3114 EMC 8612 2024 Mac13,13 4.05 GHz M3 8-Core Processor/10-Core GPU/16-Core Neural Engine
Background
The 2024 15" MacBook Air was the second 15" Air to be released. It's very similar to its predecessor, with the main difference being the updated M3 chip. The 15" M3 MacBook Air was released on March 8th, 2024, with base models starting at $1,299. Just like last year's model, the 15" M3 MacBook Air is available in Silver, Starlight, Space Gray, and Midnight.
Identification
The 15" MacBook Air with the M3 chip is identifiable by model number A3114, which is on the bottom edge of the back cover. You can get more information about your laptop by selecting About This Mac from the Apple menu in the upper-left corner of your screen. The laptop has a MagSafe port and two Thunderbolt ports on the left edge, and a headphone jack on the right edge. There's a "notch" on the top edge of the display for the camera, and a Touch-ID/power button on the top right corner of the keyboard. This MacBook Air comes in four colors: Silver, Starlight, Space Gray, and Midnight.
Visit Apple's Identify your MacBook Air model page for more information.
Technical Specifications
Display
- Liquid Retina
- 15.3-inch (diagonal) LED-backlit display with IPS technology; 2880-by-1864 native resolution at 224 pixels per inch
- 500 nits brightness
- Color
- Support for 1 billion colors
- Wide color (P3)
- True Tone technology
- Simultaneously supports full native resolution on the built-in display at 1 billion colors and:
- One external display with up to 6K resolution at 60Hz
- Close the MacBook Air lid to use a second external display with up to 5K resolution at 60Hz
Processor
- Apple M3 Chip
- 8-core CPU with 4 performance cores and 4 efficiency cores
- 10-core GPU
- Hardware-accelerated ray tracing
- 16-core Neural Engine
- 100GB/s memory bandwidth
- Media Engine
- ハードウェアアクセラレーションによるH.264、HEVC、ProRes、およびProRes RAW
- ビデオデコードエンジン
- ビデオエンコードエンジン
- ProRes エンコードおよびデコードエンジン
- AV1 デコードエンジン
ストレージ
- 256GB SSD、512GB、1TB、2TBに拡張可能
メモリ
- 8GBユニファイド・メモリ(16GBまたは24GBに拡張可能)
ワイヤレス
- Wi-Fi 6E (802.11ax)
- Bluetooth 5.3
バッテリー
- 最大18時間のApple TVアプリ映画再生
- 最大15時間のワイヤレスWeb
- 66.5ワット時リチウムポリマーバッテリー
- 35WデュアルUSB-Cポートコンパクト電源アダプタ
- USB-C to MagSafe 3ケーブル
- 70WのUSB-C電源アダプタで急速充電可能
サイズ
- 高さ x幅 x 奥行き: 1.15 x 34.04 x 23.76 cm
- 重量: 1.51 kg
ポート
- MagSafe 3 ポート
- 3.5 mm ヘッドホンジャック
- 2つのThunderbolt / USB 4ポートは以下に対応:
- 充電
- Displayポート
- Thunderbolt 3 (最大40Gb/s)
- USB 4 (最大40Gb/s)
追加情報
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
