メインコンテンツにスキップ
The Samsung Galaxy A04 is a series of Android smartphones manufactured by Samsung Electronics. Released on 2022, October 10
20回答 すべてを表示
Why is my phone changing so slow
Why my phone battery died so fast
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
How can I the sound call of my phone
さんによる
Charging slow
さんによる
コメントを追加
3件の回答
最も参考になった回答
@vuyiswaors63437 if your battery charge depletes quickly and has difficulty charging, I would start off by replacing the battery first. Then re-evaluate for any other issue. The model you listed is relatively new. I would check for any let over warranty first.Don't do anything until you find out if it is covered under warranty or not.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
First thing to try for any phone charging slowly, especially if the phone says something about check the charger connection or anything within the ballpark of super slow charging is: get a NEW charging cord.
USB cables go bad over time from repeated flexing, twisting, bending etc, and the wires inside them fray and break. Frayed wires can't carry as much amperage and broken wires carry no amperage.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Are you using the OEM charger? If the phone was purchased used, the supplied charger may not be OEM and therefore not able to supply the necessary voltage or current.
Check the charger specs. I don't know if this supports QC3, but with a 5000ma battery, the charger should be at least 5V 3A.
The OEM charger may be the adaptive fast charger. That is 25W or 5A @ 5V. Your cable must also be capable of delivering that much current.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Why is phone too slow when I'm using it?!
さんによる
@treach88408 The phone might be slow when you are using it if you have many apps open at the same time. If Bluetooth and WiFi is on, that will use up battery faster. If you are using a lot of screen time with the brightness high, that will definitely run the battery down.
さんによる
コメントを追加
回答を追加する
Vuyiswa or siduduzo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 835
