メインコンテンツにスキップ
目次
学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Galaxy tab will not play audio from speakers
No matter what audio application, the sound will not work through the built-in speakers. Even with the volume turned on to maximum level!
Unresponsive Software
Try refreshing your device by holding the power button for 5 to 7 seconds to power off, wait 1 minute, and power on the device.
Headphone Port Malfunction
Check sound in the headphone port.
If it does work with the headphones, then the device could be thinking that the headphones are still plugged in, even though they are not.
If still no sound, then attempt Hard Reset, also known as Factory Reset.
Hard Reset
WARNING: This form of reset will erase all data and preferences from your device’s internal storage including, music and documents, system and apps data and settings, and user data. So make sure to back up anything you want to save.
  • Option 1
    1. Go to the Home Screen
    2. Press the Menu key
    3. Then Settings
    4. Then Privacy
    5. Then Factory Data reset
    6. Follow the prompts to perform the Reset
  • Option 2
    1. Power off the device
    2. Hold the Up Volume button
    3. Then, while still pressing the Up Volume button, press the Power button for 10 to 15 seconds
    4. Use the Volume buttons to navigate up and down the menus to the option WIPE DATA/FACTORY RESET
    5. Choose the option by using the Power button
Bad Speakers
It is possible that the speakers could have physical damage.
Bad motherboard board
If nothing else works, there might be a problem with the hardware.
Galaxy tab will not play audio from headphones
Volume is turned up to maximum and is not muted. Tested sound on various applications and headphones, and no sound is coming from any of them, but sound is coming through speakers
Unresponsive software
There may be a problem with your device's software. First complete a soft reset, and if still no sound, then a hard reset.
Soft Reset
A soft reset is forcing the device to shut down. Simply hold the power button for 5 to 7 seconds to power off, wait 1 minute, and power on the device.
Hard Reset
WARNING: This form of reset will erase all data and preferences from the device’s internal storage including, music and documents, system and apps data and settings, and user data. So make sure to back up anything you want to save.
  • Option 1
    1. Go to Home Screen
    2. Press Menu key
    3. Then Settings
    4. Then Privacy
  • Option 2
    1. Power off device
Loose Headphone Port
Because the port is loose, the device may not think the there is a headphone plugged in. you can either tighten or [無効なガイドリンク] the port.
Dead Battery
The battery can no longer hold a charge. Capable of being turned on only when plugged in with charger, but when the charger is unplugged, the device will immediately power off.
Battery Has Lived Its Life
The battery is no longer usable and will have to be replaced.
Camera on Galaxy Tab is not working
Use the Camera shortcut, the app starts, but see nothing for the camera image.
Software Problem
There can be a problem with the camera's software. You can reset the settings for the camera application by clearing the cache and data.
If it doesn't work, try and soft reset and test. If it still doesn't work try a Hard reset
Soft Reset
Do not tear apart your device just yet! Try this simple fix first! A soft reset is forcing the device to shut down. Simply hold the power button for 5 to 7 seconds to power off, wait 1 minute, and power on the device.
Hard Reset
  • Option 1
    3. Then Settings
    4. Then Privacy
  • Option 2
Connection Problems
There may be some physical connection problems with the camera.
Galaxy Tab is Not Charging
When charger cord is plugged in, the device is not charging.
No Power to Cord
Make sure that the cord is plugged into a wall socket that has power going to it.
Note: The device will not charge when connected to a computer USB port because the voltage from the port is too weak.
Broken Cord
Sometimes, through wear-and-tear, there may be a tear in the cord’s protective covering. This may be shorting the electric current traveling through the cord and not providing enough electricity. The cord can either be spliced or replaced.
Broken Charger Connector
The connector for the charger may be broken.
Broken Charger Port
The part where the connector for the charger connects with the device may be broken or dusty.
If it is dusty, use an can of air to clean it out.
If broken, you will have to [無効なガイドリンク].
Unresponsize Screen
''Sometimes the screen freezes up and a forced reset has to be done."
Needs to Be Updated
Sometimes because the device the is outdated, this an cause problems with running applications that are meant for the updated version.
  • Check your version
    3. Then Settings
    4. Then About Device
    5. Tap on Software Update
    6. Then Update Now
    7. It should tell you if you are in need of update or not.
      • If you do complete update.
Software Problem
There is probably a problem with your software. you can either do a hard reset or contact the manufacture.
作成者
3人の作成者と共同で作成されました。
Andrew Francis
メンバー登録日: 09/23/14
93 ポイント
0のガイドは作成済み
チーム
USF Tampa, Team 11-4, Blackwell Fall 2014 USF Tampa, Team 11-4, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S11G4
4 メンバー
10のガイドは作成済み
2 件のコメント
My camera isn't working and the light on the back will not turn off I've tried everything
Jodee Sapp - 返信
After i fully charge samsung galaxy tab 8.9 tablet to 100% and start it it shows full but says low battry and turn off any way to fix it
myfairyland2001 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 11
今までの合計 9,331
