メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Pro 12.9" 3rd Gen Screen Replacement
必要な工具と部品
    1. iPad Pro 12.9" 3rd Gen Screen Replacement, Prepare your iPad for disassembly: 手順 1、 1の画像 1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the right edge: 手順 2、 1の画像 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
      FixBotに聞いてみる
      コメントを追加
    2. iPad Pro 12.9" 3rd Gen Screen Replacement, Anti-Clamp instructions: 手順 3、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Anti-Clamp instructions: 手順 3、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Anti-Clamp instructions: 手順 3、 3の画像 3
      この手順で使用する道具:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backward to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      FixBotに聞いてみる
      コメントを追加
    3. iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 4、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 4、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 4、 3の画像 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      FixBotに聞いてみる
      コメントを追加
    4. iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 5、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 5、 2の画像 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      FixBotに聞いてみる
      コメントを追加
    5. iPad Pro 12.9" 3rd Gen Screen Replacement, Insert an opening pick: 手順 6、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Insert an opening pick: 手順 6、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Insert an opening pick: 手順 6、 3の画像 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Apply a suction handle to the screen as close to the center of the right edge as possible.
      • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
      • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
      • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
      • Insert an opening pick into the gap.
      • Don't insert the pick more than 5 mm to avoid damaging the screen.
      FixBotに聞いてみる
      コメントを追加
    6. iPad Pro 12.9" 3rd Gen Screen Replacement, Right edge information: 手順 7、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Right edge information: 手順 7、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Right edge information: 手順 7、 3の画像 3
      • There are two 2 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
      • The first magnet begins about 3 cm from the top of the iPad.
      • The second magnet begins about 3 cm from the bottom of the iPad.
      • Everywhere else, don't insert your opening pick more than 5 mm.
      FixBotに聞いてみる
      コメントを追加
    7. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the right adhesive: 手順 8、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the right adhesive: 手順 8、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the right adhesive: 手順 8、 3の画像 3
      • Slide your opening pick along the right edge of the screen to separate the adhesive.
      • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
      • Leave the pick inserted in the bottom right corner before continuing.
      FixBotに聞いてみる
      コメントを追加
    8. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the corner adhesive: 手順 9、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the corner adhesive: 手順 9、 2の画像 2
      • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
      • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    9. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the bottom edge: 手順 10、 1の画像 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      FixBotに聞いてみる
      コメントを追加
    10. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the bottom adhesive: 手順 11、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the bottom adhesive: 手順 11、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the bottom adhesive: 手順 11、 3の画像 3
      • Insert a second opening pick under the bottom right corner of the screen.
      • Don't insert your opening pick more than 5 mm.
      • Slide your pick to the bottom left corner to separate the bottom adhesive.
      FixBotに聞いてみる
      コメントを追加
    11. iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: 手順 12、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: 手順 12、 2の画像 2
      • Rotate your opening pick around the bottom left corner of the screen.
      • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    12. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the left edge: 手順 13、 1の画像 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      FixBotに聞いてみる
      コメントを追加
    13. iPad Pro 12.9" 3rd Gen Screen Replacement, Left edge information: 手順 14、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Left edge information: 手順 14、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Left edge information: 手順 14、 3の画像 3
      • There are three cutouts along the left edge of the screen where the adhesive is very thin. Don't insert your opening pick more than 2 mm to avoid damaging the screen at these cutouts:
      • The upper cutout begins 4 cm from the top of the frame and is 3 cm long.
      • The middle cutout begins 12 cm from the top of the frame and is 3 cm long.
      • The bottom cutout is 4 cm from the bottom of the frame and is 3 cm long.
      FixBotに聞いてみる
      コメントを追加
    14. iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the left adhesive: 手順 15、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the left adhesive: 手順 15、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the left adhesive: 手順 15、 3の画像 3
      • Insert a third opening pick under the bottom left corner of the screen.
      • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
      • Leave the pick inserted in the top left corner before continuing.
      FixBotに聞いてみる
      コメントを追加
    15. iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: 手順 16、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Slice the corner adhesive: 手順 16、 2の画像 2
      • Slide your opening pick around the top left corner of the screen.
      • Leave your pick in the top left corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    16. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the top edge: 手順 17、 1の画像 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      FixBotに聞いてみる
      コメントを追加
    17. iPad Pro 12.9" 3rd Gen Screen Replacement, Top edge information: 手順 18、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Top edge information: 手順 18、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Top edge information: 手順 18、 3の画像 3
      • While the top edge adhesive softens, note the following:
      • There are two ambient light sensors near the corners. Don't insert your pick more than 1 mm here.
      • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
      • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
      FixBotに聞いてみる
      コメントを追加
    18. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the top adhesive: 手順 19、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the top adhesive: 手順 19、 2の画像 2
      • Slide your opening pick 9 cm toward the top right edge, stopping just before the camera assembly.
      • If you slide any farther, you risk damaging the camera's sensors.
      • Leave your pick inserted before continuing.
      FixBotに聞いてみる
      コメントを追加
    19. iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 20、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 20、 2の画像 2
      • Insert a new opening pick on the other side of the camera assembly, 4 cm from the previous pick.
      • Slide your pick to the top right corner to slice the remaining adhesive.
      FixBotに聞いてみる
      コメントを追加
    20. iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: 手順 21、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: 手順 21、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: 手順 21、 3の画像 3
      • Don't fully remove the screen, as it's attached to the frame by several cables.
      • Grab two opposing corners of the screen and lift up to separate it from the frame.
      • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
      • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
      FixBotに聞いてみる
      コメントを追加
    21. iPad Pro 12.9" 3rd Gen Screen Replacement, Unfasten the upper cable shield: 手順 22、 1の画像 1
      この手順で使用する道具:
      FixMat
      $36.95
      • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
      • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
      • One 2.0 mm-long screw
      • One 1.8 mm-long screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      FixBotに聞いてみる
      コメントを追加
    22. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the upper cable shield: 手順 23、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the upper cable shield: 手順 23、 2の画像 2
      この手順で使用する道具:
      • Use tweezers, or your fingers, to grab and remove the upper cable shield.
      FixBotに聞いてみる
      コメントを追加
    23. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the upper sensors: 手順 24、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the upper sensors: 手順 24、 2の画像 2
      • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
      • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      FixBotに聞いてみる
      コメントを追加
    24. iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: 手順 25、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: 手順 25、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Reposition the screen: 手順 25、 3の画像 3
      • Grip the right edge of the screen and open it like a book.
      • Don't pull up on the screen—the display cables are still attached.
      • Lay the screen down over the left edge of the iPad.
      • Be careful not to strain the display cables.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 12.9" 3rd Gen Screen Replacement, Unfasten the display cable bracket: 手順 26、 1の画像 1
      • Use a Phillips screwdriver to remove the five screws securing the display cable bracket:
      • Four 1.1 mm-long screws
      FixBotに聞いてみる
      コメントを追加
    2. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable bracket: 手順 27、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable bracket: 手順 27、 2の画像 2
      この手順で使用する道具:
      • Use tweezers, or your fingers, to remove the display cable bracket.
      FixBotに聞いてみる
      コメントを追加
    3. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the top display cables: 手順 28、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the top display cables: 手順 28、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the top display cables: 手順 28、 3の画像 3
      • Use a spudger to pry up and disconnect the two top display cable press connectors.
      FixBotに聞いてみる
      コメントを追加
    4. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the bottom display cables: 手順 29、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the bottom display cables: 手順 29、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the bottom display cables: 手順 29、 3の画像 3
      • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
      FixBotに聞いてみる
      コメントを追加
    5. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the screen: 手順 30、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the screen: 手順 30、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the screen: 手順 30、 3の画像 3
      • Remove the screen.
      FixBotに聞いてみる
      コメントを追加
    1. iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the display bracket tape: 手順 31、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the display bracket tape: 手順 31、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the display bracket tape: 手順 31、 3の画像 3
      • Peel back the tape from the display cable bracket located at the bottom right of the screen.
      FixBotに聞いてみる
      コメントを追加
    2. iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 32、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 32、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 32、 3の画像 3
      • Continue peeling the tape along its outer edge until the bracket is fully exposed.
      FixBotに聞いてみる
      コメントを追加
    3. iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 33、 1の画像 1
      • Remove the tape.
      • Set the tape aside. You'll use it during reassembly.
      FixBotに聞いてみる
      コメントを追加
    4. iPad Pro 12.9" 3rd Gen Screen Replacement, Unfasten the display cable bracket: 手順 34、 1の画像 1
      • Use a Phillips screwdriver to remove the two 1.3 mm-long screws securing the display cable bracket.
      FixBotに聞いてみる
      コメントを追加
    5. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable bracket: 手順 35、 1の画像 1
      • Remove the display cable bracket.
      FixBotに聞いてみる
      コメントを追加
    6. iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the remaining tape: 手順 36、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the remaining tape: 手順 36、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the remaining tape: 手順 36、 3の画像 3
      • Peel off the tape connecting the display and digitizer cables.
      FixBotに聞いてみる
      コメントを追加
    7. iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the display cable: 手順 37、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the display cable: 手順 37、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Disconnect the display cable: 手順 37、 3の画像 3
      この手順で使用する道具:
      • Use a spudger to pry up and disconnect the bottom display cable press connector on the screen.
      • Use tweezers to bend the bottom press connector away from the screen—exposing the top press connector.
      FixBotに聞いてみる
      コメントを追加
    8. iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 38、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 38、 2の画像 2
      • Use a spudger to pry up and disconnect the top display cable press connector on the screen.
      FixBotに聞いてみる
      コメントを追加
    9. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable: 手順 39、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the display cable: 手順 39、 2の画像 2
      • The display cable is lightly adhered to the screen.
      • Use your fingers to peel the display cable from the screen.
      • Remove the display cable.
      • Set the cable aside. You'll use it during reassembly.
      FixBotに聞いてみる
      コメントを追加
    10. iPad Pro 12.9" 3rd Gen Screen Replacement, Top sensor assembly information: 手順 40、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Top sensor assembly information: 手順 40、 2の画像 2
      • The top sensor assembly is composed of four sensors:
      • Two ambient light sensors
      • One proximity sensor
      • One microphone
      • You'll need to separate each sensor from the screen before removing the entire assembly.
      FixBotに聞いてみる
      コメントを追加
    11. iPad Pro 12.9" 3rd Gen Screen Replacement, Heat the top sensor assembly: 手順 41、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    12. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the ambient light sensors: 手順 42、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the ambient light sensors: 手順 42、 2の画像 2
      • Insert one arm of your angled tweezers between the ambient light sensor and the screen.
      • Pry up to separate the sensor from the screen.
      • This might take significant force.
      • Repeat this procedure for the other ambient light sensor.
      FixBotに聞いてみる
      コメントを追加
    13. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the proximity sensor: 手順 43、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the proximity sensor: 手順 43、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the proximity sensor: 手順 43、 3の画像 3
      • Be very careful during this step, as the sensor cable can tear. Work slowly and apply more heat if you encounter resistance.
      • Insert one arm of your angled tweezers between the proximity sensor cable and the screen.
      • Slide the tweezers toward the screen while prying to separate the sensor from the screen.
      • This might take significant force and multiple iOpener heating cycles.
      FixBotに聞いてみる
      コメントを追加
    14. iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the tape: 手順 44、 2の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Peel the tape: 手順 44、 2の画像 2
      • Peel off any tape covering the microphone.
      FixBotに聞いてみる
      コメントを追加
    15. iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the microphone: 手順 45、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the microphone: 手順 45、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Separate the microphone: 手順 45、 3の画像 3
      • Slide an opening tool under the microphone to separate its adhesive.
      • Pry up to separate the microphone from the screen.
      FixBotに聞いてみる
      コメントを追加
    16. iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the top sensor assembly: 手順 46、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the top sensor assembly: 手順 46、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement, Remove the top sensor assembly: 手順 46、 3の画像 3
      • Slide an opening pick under the top sensor assembly cable to separate it from the screen.
      FixBotに聞いてみる
      コメントを追加
    17. iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 47、 3の画像 1 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 47、 3の画像 2 iPad Pro 12.9" 3rd Gen Screen Replacement: 手順 47、 3の画像 3
      • Continue sliding your opening pick along the top sensor assembly until it's completely separated from the screen.
      • Remove the top sensor assembly.
      FixBotに聞いてみる
      コメントを追加
    18. iPad Pro 12.9" 3rd Gen Screen Replacement, Reassembly information: 手順 48、 1の画像 1
      この手順で使用する道具:
      Tesa 61395 Tape
      $8.95
      • During reassembly, perform the following:
      • Align the top sensor assembly on your replacement screen.
      • Use Tesa tape, or similar double-sided tape, to secure the cables to the screen.
      • Use E6000 adhesive, or similar adhesive, to secure the sensors to their cutouts on the screen.
      FixBotに聞いてみる
      コメントを追加
終わりに
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 3rd Generation Answers community for help.
キャンセル: このガイドを終了できませんでした。
56 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
247,513 ポイント
1,203のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
79,252のガイドは作成済み
45件のガイドコメント
My Face ID no longer works?
Steve Pisano - 返信 共有
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
Mark D Schlossman - 返信 共有
why not get a new flex cable from ebay or aliexpress
imab - 返信 共有
What adhesive do you use to reattach their screen?
puppitkey - 返信 共有
If the screen you ordered did not come with one you have to order it make sure it has IP rating of 68
Zach Benson - 返信 共有
コメントを追加
統計データ:
過去 24時間: 29
過去 7 日: 180
過去 30 日: 875
今までの合計 94,066
