メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Note8 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Note8 Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Switch off your phone.
    • Prepare an iOpener for softening the adhesive on the back of the Note8.
    • Apply the iOpener on the back of the Note8 along the side with the power button.
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Galaxy Note8 Battery Replacement: 手順 2、 3の画像 1 Samsung Galaxy Note8 Battery Replacement: 手順 2、 3の画像 2 Samsung Galaxy Note8 Battery Replacement: 手順 2、 3の画像 3
    • Use a suction handle to lift the back cover and create an opening pick to get in the gap.
    • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
    • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
    • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
    • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
    • Use another pick and move it to the top corner.
    • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Galaxy Note8 Battery Replacement: 手順 3、 3の画像 1 Samsung Galaxy Note8 Battery Replacement: 手順 3、 3の画像 2 Samsung Galaxy Note8 Battery Replacement: 手順 3、 3の画像 3
    • Again take another opening pick and carefully move it around the corner and along the top edge.
    • Reheat with an iOpener if necessary.
    • Leave the pick at the top right corner to keep the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Galaxy Note8 Battery Replacement: 手順 4、 3の画像 1 Samsung Galaxy Note8 Battery Replacement: 手順 4、 3の画像 2 Samsung Galaxy Note8 Battery Replacement: 手順 4、 3の画像 3
    • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
    • Leave the pick at the bottom right corner to keep the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Galaxy Note8 Battery Replacement: 手順 5、 3の画像 1 Samsung Galaxy Note8 Battery Replacement: 手順 5、 3の画像 2 Samsung Galaxy Note8 Battery Replacement: 手順 5、 3の画像 3
    • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
    • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
    • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Galaxy Note8 Battery Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Use a pair of tweezers to disconnect the fingerprint sensor.
    • The connector might already have come off when flipping the back cover open.
    FixBotに聞いてみる
    コメントを追加
  7. Samsung Galaxy Note8 Battery Replacement: 手順 7、 1の画像 1
    • Remove the back cover.
    • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    FixBotに聞いてみる
    コメントを追加
  8. Samsung Galaxy Note8 Battery Replacement, NFC Antenna and Charging Coil Assembly: 手順 8、 1の画像 1
    • Remove the ten Phillips #00 screws.
    FixBotに聞いてみる
    コメントを追加
  9. Samsung Galaxy Note8 Battery Replacement: 手順 9、 2の画像 1 Samsung Galaxy Note8 Battery Replacement: 手順 9、 2の画像 2
    • Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
    • Lever the top of the assembly out of the case.
    FixBotに聞いてみる
    コメントを追加
  10. Samsung Galaxy Note8 Battery Replacement: 手順 10、 1の画像 1
    • Carefully pull up the complete charging coil and NFC antenna assembly.
    • The bottom left part of the assembly is slightly glued down to the frame.
    FixBotに聞いてみる
    コメントを追加
  11. Samsung Galaxy Note8 Battery Replacement, Battery Disconnect: 手順 11、 1の画像 1
    • Use the flat end of a spudger to disconnect the battery connector.
    FixBotに聞いてみる
    コメントを追加
  12. Samsung Galaxy Note8 Battery Replacement, Battery: 手順 12、 1の画像 1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath the battery. Reheat and reapply the iOpener as needed.
    • Alternatively or when the battery is blown up, you can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    FixBotに聞いてみる
    コメントを追加
  13. Samsung Galaxy Note8 Battery Replacement: 手順 13、 2の画像 1 Samsung Galaxy Note8 Battery Replacement: 手順 13、 2の画像 2
    • Use the flat end of a spudger to pry up the battery from the top right corner.
    • You will be prying against the case directly above the mainboard. Pry carefully to avoid damaging any close components.
    • You may need to reheat and reapply the iOpener repeatedly to further soften the adhesive. The adhesive is tough and it may take a few tries to get the spudger started under the battery.
    • Use the spudger to pry up the battery until you can insert an opening pick to prevent the adhesive from resealing.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    FixBotに聞いてみる
    コメントを追加
  14. Samsung Galaxy Note8 Battery Replacement: 手順 14、 3の画像 1 Samsung Galaxy Note8 Battery Replacement: 手順 14、 3の画像 2 Samsung Galaxy Note8 Battery Replacement: 手順 14、 3の画像 3
    • Use the flat end of the spudger to pry up the top left corner of the battery where the flex cable is located.
    • Slide the spudger along the side of the battery to break apart remaining adhesive.
    • When prying keep to the areas marked orange. Avoid the red area in the middle which is the back of the display.
    FixBotに聞いてみる
    コメントを追加
  15. Samsung Galaxy Note8 Battery Replacement: 手順 15、 1の画像 1
    • Lift the battery out of the case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Follow this guide to install battery adhesive.
    • Follow this guide to install custom-cut adhesives.
    FixBotに聞いてみる
    コメントを追加
終わりに
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
To reassemble your device, follow these instructions in reverse order, replacing the adhesive where needed.
If possible, turn on your phone and test your repair before closing and sealing up the phone.
For best results, when your repair is complete, calibrate your newly-installed battery.
キャンセル: このガイドを終了できませんでした。
77 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
133,914 ポイント
189のガイドは作成済み
チーム
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer人のメンバー
Business
1 メンバー
1,145のガイドは作成済み
10件のガイドコメント
Awesome fix. Do you have anything for the front glass replacements by chance? I want to do both at the same time
Rick Moore - 返信 共有
For those wondering how to apply the replacement adhesive, there is a video on the iFixit YouTube channel about installing adhesive on Samsung devices. Its a bit generic, but it points you in the right direction.
Christopher Zibbell - 返信 共有
Hi Christopher,
I’ve edited the last step to include some adhesive guides! Hope that helps!
Arthur Shi - 返信 共有
Thanks!! Very good detail. I was able to get the back cover off and replace the battery - the phone is working like a champ!
Phil Brooks - 返信 共有
Would it be possible to augment the mAh? instead of 3300 mAh giving a little bit more power?
William Houli - 返信 共有
コメントを追加
統計データ:
過去 24時間: 19
過去 7 日: 77
過去 30 日: 366
今までの合計 113,617
