メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Note10+ Battery Replacement
必要な工具と部品
    1. Samsung Galaxy Note10+ Battery Replacement, Heat the rear cover: 手順 1、 1の画像 1
      • Completely power off your phone before you begin disassembly.
      • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy Note10+ Battery Replacement, Insert an opening pick: 手順 2、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement, Insert an opening pick: 手順 2、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement, Insert an opening pick: 手順 2、 3の画像 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert the point of an opening pick into the gap.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Galaxy Note10+ Battery Replacement, Begin to slice the adhesive: 手順 3、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement, Begin to slice the adhesive: 手順 3、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement, Begin to slice the adhesive: 手順 3、 3の画像 3
      • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
      • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      FixBotに聞いてみる
      コメントを追加
    4. Samsung Galaxy Note10+ Battery Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
      • The rear cover will begin to separate from the phone as you finish all sides of the phone.
      FixBotに聞いてみる
      コメントを追加
    5. Samsung Galaxy Note10+ Battery Replacement, Lift off the rear cover: 手順 5、 2の画像 1 Samsung Galaxy Note10+ Battery Replacement, Lift off the rear cover: 手順 5、 2の画像 2
      • Lift the rear cover straight up to remove it.
      • Follow this guide to reinstall the rear cover and replace the adhesive.
      • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
      • If you're using Tesa tape to reattach components, follow this guide.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Galaxy Note10+ Battery Replacement, Lift up the metal cover: 手順 6、 1の画像 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy Note10+ Battery Replacement: 手順 7、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement: 手順 7、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement: 手順 7、 3の画像 3
      この手順で使用する道具:
      • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Galaxy Note10+ Battery Replacement, Disconnect the battery: 手順 8、 2の画像 1 Samsung Galaxy Note10+ Battery Replacement, Disconnect the battery: 手順 8、 2の画像 2
      • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
      FixBotに聞いてみる
      コメントを追加
    4. Samsung Galaxy Note10+ Battery Replacement, Disconnect the wireless charging coil: 手順 9、 2の画像 1 Samsung Galaxy Note10+ Battery Replacement, Disconnect the wireless charging coil: 手順 9、 2の画像 2
      • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    5. Samsung Galaxy Note10+ Battery Replacement, Remove the wireless charging coil: 手順 10、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement, Remove the wireless charging coil: 手順 10、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement, Remove the wireless charging coil: 手順 10、 3の画像 3
      • Tilt the metal shielding up so you can grip it with your fingers.
      • Peel the wireless charging coil up and away from the device.
      • The wireless charging coil is secured to the phone with some light adhesive.
      • Remove the wireless charging coil.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Galaxy Note10+ Battery Replacement, Remove the loudspeaker screws: 手順 11、 1の画像 1
      • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy Note10+ Battery Replacement, Remove the loudspeaker: 手順 12、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement, Remove the loudspeaker: 手順 12、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement, Remove the loudspeaker: 手順 12、 3の画像 3
      この手順で使用する道具:
      • Use a pair of tweezers to remove the loudspeaker.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Galaxy Note10+ Battery Replacement, Remove the interconnect cables: 手順 13、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement, Remove the interconnect cables: 手順 13、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement, Remove the interconnect cables: 手順 13、 3の画像 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
      • Disconnect the secondary interconnect cable from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy Note10+ Battery Replacement: 手順 14、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement: 手順 14、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement: 手順 14、 3の画像 3
      • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
      • Disconnect the secondary interconnect cable from the daughterboard.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Galaxy Note10+ Battery Replacement: 手順 15、 2の画像 1 Samsung Galaxy Note10+ Battery Replacement: 手順 15、 2の画像 2
      • Remove both interconnect cables.
      FixBotに聞いてみる
      コメントを追加
    1. Samsung Galaxy Note10+ Battery Replacement, Disconnect the display cable: 手順 16、 2の画像 1 Samsung Galaxy Note10+ Battery Replacement, Disconnect the display cable: 手順 16、 2の画像 2
      • Use the pointed end of a spudger to disconnect the display cable connector from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Samsung Galaxy Note10+ Battery Replacement, Loosen the battery adhesive: 手順 17、 2の画像 1 Samsung Galaxy Note10+ Battery Replacement, Loosen the battery adhesive: 手順 17、 2の画像 2
      • Apply 1-2 drops of high concentration (90% or greater) isopropyl alcohol underneath the battery at the tear-shaped indents near the corners of the battery well.
      • Using too much alcohol can damage the display.
      • Wait about two minutes for the isopropyl alcohol to penetrate and weaken the battery adhesive before you proceed to the next step.
      FixBotに聞いてみる
      コメントを追加
    3. Samsung Galaxy Note10+ Battery Replacement, Remove the battery: 手順 18、 3の画像 1 Samsung Galaxy Note10+ Battery Replacement, Remove the battery: 手順 18、 3の画像 2 Samsung Galaxy Note10+ Battery Replacement, Remove the battery: 手順 18、 3の画像 3
      • Apply a suction cup to the back of the battery.
      • Pull up on the suction cup with strong, steady force to begin to separate the battery from the frame.
      • If this is difficult, apply a few more drops of isopropyl alcohol underneath the battery, let it sit for two minutes, and try again.
      • Insert the point of an opening pick into the gap created between the battery and frame.
      • Don't insert the opening pick more than halfway or you risk damaging the fingerprint sensor underneath.
      • Pull up on the suction cup to remove the battery.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      • When you're reassembling your phone, remove the old adhesive and apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
      FixBotに聞いてみる
      コメントを追加
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
36 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
168,740 ポイント
437のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
68,591のガイドは作成済み
16件のガイドコメント
What kind of adhesive would you recommend to adhere the back glass to the phone after repair?
Andrew Johnson - 返信 共有
Hey! Here’s a link to the rear cover adhesive!
Carsten Frauenheim - 返信 共有
Thank you! I have all my stuff ordered now. I can’t wait to follow this guide and get my battery back to new!
Do I only need the rear cover adhesive or the perimeter adhesive as well?
Martin Schulz - 返信 共有
Hi,
I would like to replace my note 10 plus battery, wireless charging n nfc, please advise on what to buy from you.
Thanks
Alex
Alex Wong - 返信 共有
コメントを追加
統計データ:
過去 24時間: 23
過去 7 日: 205
過去 30 日: 726
今までの合計 55,149
