メインコンテンツにスキップ
Motorola Moto G 5G (2022) Motherboard Replacement
Clay Eickemeyer
Clay Eickemeyer とその他 3 人の作成者
最終更新日: May 7, 2024
50分 - 1時間
中レベル
This guide demonstrates how to remove and replace the motherboard assembly on your 2022 Motorola Moto G. This component also contains the rear-facing microphone, front-facing sensors, and heat-dispersion tape.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
必要な工具と部品
ツール
もっと見る
  1. Motorola Moto G 5G (2022) Motherboard Replacement, Eject the SIM card tray: 手順 1、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Eject the SIM card tray: 手順 1、 2の画像 2
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the SIM card tray: 手順 2、 1の画像 1
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Motherboard Replacement, Back cover removal information: 手順 3、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Back cover removal information: 手順 3、 2の画像 2
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Motherboard Replacement, Insert an opening pick: 手順 4、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Insert an opening pick: 手順 4、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Insert an opening pick: 手順 4、 3の画像 3
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Motherboard Replacement, Release the right clips: 手順 5、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Release the right clips: 手順 5、 2の画像 2
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Motherboard Replacement, Release the bottom clips: 手順 6、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Release the bottom clips: 手順 6、 2の画像 2
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Motherboard Replacement, Release the left clips: 手順 7、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Release the left clips: 手順 7、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Release the left clips: 手順 7、 3の画像 3
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Motherboard Replacement, Release the top clips: 手順 8、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Release the top clips: 手順 8、 2の画像 2
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Motherboard Replacement: 手順 9、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement: 手順 9、 2の画像 2
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the back cover: 手順 10、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the back cover: 手順 10、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the back cover: 手順 10、 3の画像 3
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: 手順 11、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: 手順 11、 2の画像 2
    この手順で使用する道具:
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Motherboard Replacement, Only the back cover remains: 手順 12、 1の画像 1
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
  13. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the power button cable bracket: 手順 13、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the power button cable bracket: 手順 13、 2の画像 2
    • Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
  14. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button cable bracket: 手順 14、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button cable bracket: 手順 14、 2の画像 2
    この手順で使用する道具:
    • Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
  15. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the power button: 手順 15、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the power button: 手順 15、 2の画像 2
    • Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
  16. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: 手順 16、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the power button: 手順 16、 2の画像 2
    • Grab and remove the power button.
    • If you're using tweezers, take care not to puncture the battery—a punctured battery may leak dangerous chemicals or cause a fire.
  17. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard cover: 手順 17、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard cover: 手順 17、 2の画像 2
    • Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  18. Motorola Moto G 5G (2022) Motherboard Replacement, Pry the motherboard cover: 手順 18、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Pry the motherboard cover: 手順 18、 2の画像 2
    • Insert an opening pick between the bottom-left corner of the cover and the motherboard.
    • Pry up to release the cover's small clips securing it to the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • Work your way around the perimeter to free the cover if it feels stuck.
  19. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard cover: 手順 19、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard cover: 手順 19、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard cover: 手順 19、 3の画像 3
    この手順で使用する道具:
    • Grab and remove the motherboard cover from the phone.
  20. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the battery: 手順 20、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the battery: 手順 20、 2の画像 2
    • Use the pointed end of a spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: 手順 21、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: 手順 21、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: 手順 21、 3の画像 3
    この手順で使用する道具:
    • Peel the tape from the display connector.
    • If you are using a pair of tweezers, use caution to avoid the battery.
    • If you're having trouble peeling the tape, heat an iOpener and apply it to the tape for 60 seconds.
  22. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the display: 手順 22、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the display: 手順 22、 2の画像 2
    • Use the pointed end of a spudger to pry and disconnect the screen's press connector.
  23. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the graphite film: 手順 23、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Lift the graphite film: 手順 23、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Lift the graphite film: 手順 23、 3の画像 3
    • Fold the graphite heat film away from the battery to expose the lower section of the motherboard.
  24. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the board connector: 手順 24、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the board connector: 手順 24、 2の画像 2
    • Use the pointed end of a spudger to pry and disconnect the board cable's press connector.
  25. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the black antenna cable: 手順 25、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the black antenna cable: 手順 25、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the black antenna cable: 手順 25、 3の画像 3
    • Use the pointed end of your spudger to pry and disconnect the head of the black antenna cable.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • Free the cable from the clip below the head of the connector.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
    • During reassembly, make sure to secure the cable to the clip below the head of the connector.
  26. Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the white antenna cable: 手順 26、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Disconnect the white antenna cable: 手順 26、 2の画像 2
    • Repeat the previous step for the white antenna cable.
  27. Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard: 手順 27、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Unfasten the motherboard: 手順 27、 2の画像 2
    • Use your Phillips screwdriver to remove the 2.9 mm-long screw from the bottom-right corner of the motherboard.
  28. Motorola Moto G 5G (2022) Motherboard Replacement, Lift the motherboard: 手順 28、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Lift the motherboard: 手順 28、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Lift the motherboard: 手順 28、 3の画像 3
    • Insert the pointed end of a spudger between the lower left of the motherboard and the frame.
    • Lift upward on this bottom edge to free the motherboard from the frame.
  29. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard: 手順 29、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the motherboard: 手順 29、 2の画像 2
    • Grab the motherboard from the bottom edge and lift it from its recess.
    • Be sure the loose cables don't catch on the motherboard as its removed.
  30. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the main camera: 手順 30、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the main camera: 手順 30、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the main camera: 手順 30、 3の画像 3
    • Flip the motherboard over so that the lens of the main camera is facing down.
    • Use the pointed end of your spudger to pry and disconnect the main camera's press connector.
    • Remove the main camera from the motherboard.
  31. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the macro camera: 手順 31、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the macro camera: 手順 31、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the macro camera: 手順 31、 3の画像 3
    • Use the pointed end of a spudger to pry and disconnect the macro camera's press connector.
    • The camera may eject from the motherboard. Be careful to not lose it.
    • Grab and remove the macro camera.
  32. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the depth camera: 手順 32、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the depth camera: 手順 32、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the depth camera: 手順 32、 3の画像 3
    • Use the pointed end of a spudger to pry and disconnect the depth camera's press connector.
    • Grab and remove the depth camera.
  33. Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: 手順 33、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: 手順 33、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Peel away the tape: 手順 33、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to peel the tape connecting the front-facing camera to the motherboard.
  34. Motorola Moto G 5G (2022) Motherboard Replacement, Remove the front-facing camera: 手順 34、 3の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the front-facing camera: 手順 34、 3の画像 2 Motorola Moto G 5G (2022) Motherboard Replacement, Remove the front-facing camera: 手順 34、 3の画像 3
    • Use the pointed end of a spudger to pry and disconnect the camera's press connector.
    • Grab and remove the camera.
  35. Motorola Moto G 5G (2022) Motherboard Replacement: 手順 35、 2の画像 1 Motorola Moto G 5G (2022) Motherboard Replacement: 手順 35、 2の画像 2
    • All that remains is the motherboard.
終わりに
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Clay Eickemeyer
メンバー登録日: 09/19/22
81,019 ポイント
455のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
9 メンバー
11,337のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 22
今までの合計 1,162
