メインコンテンツにスキップ
Lenovo ThinkPad P1 Gen 7 Screen Replacement
Spencer Day
Spencer Day
最終更新日: September 4, 2024
30 - 45 分
中レベル
おすすめのガイド
Use this guide to replace a broken or cracked screen on your Lenovo ThinkPad P1 Gen 7 laptop.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
必要な工具と部品
ツール
もっと見る
  1. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Turn off your laptop: 手順 1、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Turn off your laptop: 手順 1、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Turn off your laptop: 手順 1、 3の画像 3
    • Shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the base cover screws: 手順 2、 1の画像 1
    • Use a Phillips screwdriver to loosen the six captive screws securing the base cover.
  3. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the base cover's left side: 手順 3、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the base cover's left side: 手順 3、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the base cover's left side: 手順 3、 3の画像 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-left corner of the frame (near the screen hinge).
    • It can be tricky to get the pick into the seam for the first time. Angle the pick vertically and press down with firm pressure.
    • Pivot the pick down and slide it around the corner to release the clips.
  4. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 4、 3の画像 3
    • Slide the opening pick along the left edge to release the clips securing the cover.
  5. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the base cover's right side: 手順 5、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the base cover's right side: 手順 5、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the base cover's right side: 手順 5、 3の画像 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-right corner of the frame (near the screen hinge).
  6. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 6、 2の画像 2
    • Slide the opening pick along the right edge to release the clips securing the cover.
  7. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Remove the base cover: 手順 7、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Remove the base cover: 手順 7、 2の画像 2
    • Grasp the base cover along the screen hinge edge and pull up to loosen the cover.
  8. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 8、 2の画像 2
    • Lift and remove the base cover.
  9. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the battery screws: 手順 9、 1の画像 1
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to loosen the six captive screws securing the battery.
  10. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Remove the battery: 手順 10、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Remove the battery: 手順 10、 2の画像 2
    • Grasp the top edge of the battery and lift to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
  11. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 11、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 11、 2の画像 2
    • Lift and remove the battery.
  12. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Disconnect the screen: 手順 12、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Disconnect the screen: 手順 12、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Disconnect the screen: 手順 12、 3の画像 3
    • Use the flat end of a spudger to lift the locking flap on the screen cable ZIF connector near the right edge of your laptop.
    • Use your fingers to grip the screen cable and gently pull the connector out of its socket.
  13. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 13、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 13、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 13、 3の画像 3
    • Carefully guide the right screen-cable out from under its cutout in the motherboard, near the right hinge.
  14. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 14、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 14、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 14、 3の画像 3
    • Use the flat end of a spudger to lift the locking flap on the screen cable ZIF connector near the left edge of your laptop.
  15. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 15、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 15、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 15、 3の画像 3
    • Slide an arm of a pair of angled tweezers under the metal neck of one of the Wi‑Fi card coaxial connectors, just below the left screen-cable.
    • Lift straight up to disconnect the cable.
    • Repeat the process to disconnect the other Wi‑Fi card cable.
  16. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 16、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 16、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 16、 3の画像 3
    • Use a spudger or your fingers to gently guide the two thinner cables (black and yellow) and the screen cable out of their clips on the edge of the left fan.
  17. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 17、 1の画像 1
    • Use a Phillips screwdriver to remove the two 4.6 mm‑long screws securing the charging port bracket.
  18. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 18、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 18、 2の画像 2
    • Remove the charging port bracket.
  19. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the hinge screws: 手順 19、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Loosen the hinge screws: 手順 19、 2の画像 2
    • Use a Phillips screwdriver to loosen (not remove) all four hinge screws.
  20. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 20、 2の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 20、 2の画像 2
    • Open your laptop 90 degrees and gently place it keyboard side down on a table, so the screen hangs over the edge.
    • Optionally, you can place a soft cloth under your keyboard to protect it.
  21. Lenovo ThinkPad P1 Gen 7 Screen Replacement, Remove the screen: 手順 21、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Remove the screen: 手順 21、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement, Remove the screen: 手順 21、 3の画像 3
    • Keep a firm grip on your laptop, as it can easily fall off the table.
    • Support the screen with one hand and use your free hand to remove the four 4.4 mm–long Phillips screws securing the hinges.
  22. Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 22、 3の画像 1 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 22、 3の画像 2 Lenovo ThinkPad P1 Gen 7 Screen Replacement: 手順 22、 3の画像 3
    • Hold the screen with both hands and lift the hinges out of their recesses to remove the screen.
    • During reassembly:
    • Make sure the screen hinges are open 90 degrees and guide them into their recesses in the frame.
    • Install and partially tighten the four hinge screws.
    • Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
    • Fully tighten the hinge screws.
終わりに
Spencer Day
メンバー登録日: 09/14/22
95,960 ポイント
662のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,648のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 48
今までの合計 370
