How to Fix a Slipped Bicycle Chain
はじめに
手順 1 に進むSlipped bike chains may be caused by several different problems including poor shifting technique, the chain being too long, or a worn out chain or rear casters.
必要な工具と部品
Before getting off the bike, downshift bike into lowest front gear (using the left shifter).
Continue pedaling. This step alone may realign the chain.
If Step 1 did not work, get off the bike and lift the rear tire while spinning the pedals with your hand.
Rotating the wheel worked like a charm! My bike now pedals normal. All I did was spin the rear wheel counter-clockwise. Thank you for the good advice!
If your chain continues to slip, the chain or cogs are probably worn out. Have a local mechanic look at your bike and determine which needs to be replaced. If it's the chain, visit this guide <Triace A310 Chain Replacement>
21 の人々がこのガイドを完成させました。
7 件のコメント
Thank you so much for this article--so many helpful tips here. But, I just saw this post ("Over 200 Bike Repair Videos and Hundreds of Pages of Illustrated Guides") and actually was reading about this same topic the other day. I did some searching around and stumbled onto this cool article… I thought it was helpful… http://diybikerepairguide.weebly.com
Thanks for the information. How do I know how long the new chain should be. Hint, don't have broken one.
Thanks for your post. A bicycle normally drops off a gear or chain ring as the teeth have worn and become narrow.The chain has a bad link and stretched. To increase complexity, you have lots of options to ensure the dropped chain. You may like this too- http://www.mybiked.com/rechain-bike-usef...
I have a chain guide on my bike only now that the chain is off, I can’t seem to lift the chain onto the top of the chain ring as the guide is blocking this.
