メインコンテンツにスキップ
HP Omen 15-ax243dx Battery Replacement
vangnam
vangnam とその他 5 人の作成者
最終更新日: September 1, 2020
5 - 10 分
簡単
Is your battery dying often? Does it not hold charge or even not charge at all? Follow this guide to successfully remove and replace the battery from your HP-Omen laptop.
必要な工具と部品
修理キット
キットには、修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
  1. HP Omen 15-ax243dx Battery Replacement, Battery: 手順 1、 2の画像 1 HP Omen 15-ax243dx Battery Replacement, Battery: 手順 1、 2の画像 2
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
    Isn’t the plastic plug toward the center, and screw beneath it, a problem?
    risorcurt - 返信
    There is no screw under the center plug, the bottom is just held on by clips after all 10 screws have been removed
    Nigel Bancroft -
  2. HP Omen 15-ax243dx Battery Replacement: 手順 2、 2の画像 1 HP Omen 15-ax243dx Battery Replacement: 手順 2、 2の画像 2
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Battery Replacement: 手順 3、 2の画像 1 HP Omen 15-ax243dx Battery Replacement: 手順 3、 2の画像 2
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Battery Replacement: 手順 4、 2の画像 1 HP Omen 15-ax243dx Battery Replacement: 手順 4、 2の画像 2
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
vangnam
メンバー登録日: 10/19/17
594 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 UMass Dartmouth, Team S6-G7, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S6G7
3 メンバー
7のガイドは作成済み
8 件のコメント
Hello,
I replaced the battery but it is not charging. I know it’s an easy repair, but I checked the pins but not sure where the problem is.
Any ideas?
Thank you
Kiran M - 返信
Hi Kiran,
Does the laptop show any indication that it detects the battery?
Arthur Shi -
I’ve replaced the battery with one I bought from here, and I believe it may be faulty? My laptop is not detecting a battery, I opened it back up and followed the guide again to make sure I did everything right, and made sure the battery cord was inserting securely, still nothing.
AwSnoopy - 返信
Hello! Please contact our customer support and we will get the issue resolved!
Arthur Shi -
We took the battery out of your laptop then put it back in because it wouldnt turn on, it turns on now but the left usb ports are not getting powered, is there any way to make sure that they are powered when we get our replacement battery in the laptop?
Drake Mitchell - 返信
Will this battery work for an HP Omen 15-ax250wm? It looks like it should but better safe than sorry.
Nyx - 返信
For my own needs, I did confirm both the 15-ax250wm and the 15-ax243dx use the same 4-cell, 63.3 Wh Li-ion battery. References: https://support.hp.com/us-en/document/c0... and https://support.hp.com/us-en/document/c0....
Jeromy Tichner -
I bought a battery to replace my old battery on the hp omen 15 cause it was swollen and it made the laptop die faster. When I replace it was doing the same for a while until it lasted for longer but still dies roughly fast. Any clue why it dies fast?
Chris Giron - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 36
過去 30 日: 196
今までの合計 24,147
