メインコンテンツにスキップ
GuliKit KingKong 2 Pro Battery Replacement
必要な工具と部品
  1. GuliKit KingKong 2 Pro Battery Replacement, Unfasten the back cover screws: 手順 1、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. GuliKit KingKong 2 Pro Battery Replacement, Insert an opening pick: 手順 2、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Insert an opening pick: 手順 2、 2の画像 2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. GuliKit KingKong 2 Pro Battery Replacement, Separate the front assembly and back cover: 手順 3、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Separate the front assembly and back cover: 手順 3、 2の画像 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. GuliKit KingKong 2 Pro Battery Replacement: 手順 4、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement: 手順 4、 2の画像 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. GuliKit KingKong 2 Pro Battery Replacement, Remove the back cover: 手順 5、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Remove the back cover: 手順 5、 2の画像 2
    • Separate the back cover from the front assembly and remove it.
  6. GuliKit KingKong 2 Pro Battery Replacement, Disconnect the right vibration motor: 手順 6、 3の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Disconnect the right vibration motor: 手順 6、 3の画像 2 GuliKit KingKong 2 Pro Battery Replacement, Disconnect the right vibration motor: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
  7. GuliKit KingKong 2 Pro Battery Replacement, Disconnect the left vibration motor: 手順 7、 3の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Disconnect the left vibration motor: 手順 7、 3の画像 2 GuliKit KingKong 2 Pro Battery Replacement, Disconnect the left vibration motor: 手順 7、 3の画像 3
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
  8. GuliKit KingKong 2 Pro Battery Replacement, Remove the vibration motors: 手順 8、 1の画像 1
    • Remove the vibration motors by lifting them out of the controller housing.
  9. GuliKit KingKong 2 Pro Battery Replacement, Release the interconnect cable ZIF connector: 手順 9、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Release the interconnect cable ZIF connector: 手順 9、 2の画像 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  10. GuliKit KingKong 2 Pro Battery Replacement, Disconnect the interconnect cable: 手順 10、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Disconnect the interconnect cable: 手順 10、 2の画像 2
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
  11. GuliKit KingKong 2 Pro Battery Replacement, Unfasten the mainboard assembly screws: 手順 11、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
  12. GuliKit KingKong 2 Pro Battery Replacement, Remove the mainboard shield: 手順 12、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Remove the mainboard shield: 手順 12、 2の画像 2
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
  13. GuliKit KingKong 2 Pro Battery Replacement, Remove the mainboard assembly: 手順 13、 3の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Remove the mainboard assembly: 手順 13、 3の画像 2 GuliKit KingKong 2 Pro Battery Replacement, Remove the mainboard assembly: 手順 13、 3の画像 3
    • Remove the mainboard assembly by lifting it out of the controller housing.
  14. GuliKit KingKong 2 Pro Battery Replacement, Unfasten the battery frame screw: 手順 14、 1の画像 1
    • Take care not to puncture the battery with your tool—a punctured battery may leak dangerous chemicals or cause a fire.
    • Use a Phillips #00 screwdriver to remove the single 7.8 mm-long screw securing the battery frame.
  15. GuliKit KingKong 2 Pro Battery Replacement, Free the battery frame: 手順 15、 3の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Free the battery frame: 手順 15、 3の画像 2 GuliKit KingKong 2 Pro Battery Replacement, Free the battery frame: 手順 15、 3の画像 3
    • Free the battery frame by lifting it off the plastic pins holding it in place.
  16. GuliKit KingKong 2 Pro Battery Replacement, Disconnect the battery: 手順 16、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Disconnect the battery: 手順 16、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a pair of blunt nose tweezers to disconnect the battery connector by pulling it straight out of its socket.
    • Remove the battery and its frame from the controller housing.
  17. GuliKit KingKong 2 Pro Battery Replacement, Loosen the battery adhesive: 手順 17、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Loosen the battery adhesive: 手順 17、 2の画像 2
    • The GuliKit KingKong 2 Pro battery is held in place by mild adhesive.
    • Apply a heated iOpener to the back of the battery frame for two minutes to loosen the adhesive underneath the battery.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the battery.
  18. GuliKit KingKong 2 Pro Battery Replacement, Remove the battery: 手順 18、 2の画像 1 GuliKit KingKong 2 Pro Battery Replacement, Remove the battery: 手順 18、 2の画像 2
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Insert an opening pick into the gap between the battery frame and the battery.
    • Slide the opening pick underneath the battery to cut the adhesive and pry it up.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the frame at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
204,902 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,420のガイドは作成済み
3 件のコメント
where i can buy battery? I think i get new gamepad with dead battery.
Darrick - 返信
What are the dimensions of the battery so we know which battery to order?
PinataStorm - 返信
I am wondering where I can buy a replacement battery, I have ordered several off of Amazon, but the connector is far smaller than ones I have found. If the size of the connector has a size that I could reference, that would be great as well.
Cobriss - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 24
過去 30 日: 144
今までの合計 4,919
