はじめに
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to remove the mainboard assembly in your GuliKit KingKong 2 Pro.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
Tilt your opening pick downwards to widen the gap.
Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
Slide the opening pick along the gap to separate the front assembly from the back cover.
この手順で使用する道具:Tweezers$4.99
Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
Remove the vibration motors by lifting them out of the controller housing.
Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
Four 7.8 mm-long screws.
Two 11 mm-long screws.
Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
Remove the mainboard assembly by lifting it out of the controller housing.
