メインコンテンツにスキップ
ツール
以前、このデバイスの修理に使われていた一般的な工具です。修理過程において全部の工具が必要とは限りません。
Background
The Toshiba Satellite C655D-S5084 model was released in 2011 by Toshiba as part of their C650 series. The widescreen display and graphics processor offer a unique visual experience when watching movies, gaming, browsing photos, and more. Toshiba aimed to draw in a larger audience by making this device a multi-tasking machine that could accommodate the needs of the average family to the diligent college student.
Identification
To find your model name/number, click on the Start Menu, then "Help and Support," then "Tools," then "My Computer Information," then "View General Information About this Computer." This will tell you your model number and other identification numbers for your computer. The model number is also printed on a barcode sticker located on the underside of the computer.
Technical Specifications
Processor:
  • Processor: AMP Athlon II Dual-Core Mobile Processor
  • Operating System: Windows 7 Home Premium
  • Graphics: ATI Mobility Radeon HD 4250
Memory and Drives:
  • Hard Drive: 250GB SATA Hard Drive
  • Memory: 3GB DDR3
  • Disk Drive: DVD SuperMulti Drive
Audio and Video:
  • Display: 15.6" LCD
  • Display Resolution: 1280x800
  • Audio Accessories: Headphone Jack (stereo), Microphone Jack (mono), Standard Stereo Speakers
Communication:
  • Webcam: Webcam and Microphone
  • Internet: ethernet and Wi-Fi capabilities
  • Input Devices: Keyboard and Keypad
  • Data: 2 USB Ports and RJ-45 LAN port
Ports:
  • PC Express Slot: 1-ExpressCard™ /34 slot
  • Media: S/P DIF output port (shared with headphone port), 5-in-1 Bridge Media Adapter
  • USB Ports: 1-eSATA/USB (2.0) combo port with Sleep and Charge, 2-USB (2.0) ports with Sleep and Charge
  • ILINK: i.LINK™ IEEE-1394
Dimensions:
  • Dimensions (WxDxH): 15.1" x 11.0" x 1.10"/1.50"
  • Weight: 5.5 lb.
Power:
  • Battery: 6 Cell Li-Ion (48Wh)
  • Power Supply: 65W AC Adapter
Additional Information
作成者
9人の作成者と共同で作成されました。
Shelby Kunz
メンバー登録日: 04/19/13
69 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G20
4 メンバー
15のガイドは作成済み
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 9,058
