What can I use to keep a screw from falling out?
Is there anything I can use (besides glue) to keep a screw from falling out of my laptop? I suppose it's stripped. Maybe I just need a new screw? Thanks for any help.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Lock tight is a semi glue that will hold but not make it impossible to remove screws.
http://www.southbayriders.com/forums/att...
this is the blue stuff you might already see on the threads of the screws in your laptop it can be purchased at most hardware stores there are different levels of stick by color you want blue
このアンサーは役に立ちましたか?
Thank you! That's what I was thinking of. Exactly. You're a gentleman and a scholar.
watch my life hack tricks for this problem
I think you need the purple one http://henkeladhesivesna.com/blog/when-a...
The Red compound is in a blue tube, and the blue compound is in a red tube ! ?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 4,633
