メインコンテンツにスキップ
2021年10月に発売された、Apple設計のM1 ProとM1 MaxのSoCを搭載した16インチMacBook Proの修理ガイドと分解情報をご紹介します。モデルA2485です。
20回答 すべてを表示
Display turning off itself
My system fell in water, I took it to a local shop for repair and it was working back but the screen goes off even while working on it. It will only comes up whenever I press any key on the keyboad. This normally happens after the system stay up for like between 15-20 minutes after booting. Please what can I do
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Since this has a history of liquid damage, it's likely that either a component on the logic board related to display logic is damaged, or a component on the display itself is damaged. I would recommend taking it back to the repair shop to see what they recommend! Otherwise you would need to open it up and inspect components for damage and possibly do some level of board repair. Good luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you Zach. I have returned it but the technician said it was a screen. hard to believe because sometimes it work for like 20 minutes before the acting up
さんによる
コメントを追加
Liquid damage often effects the battery, have you checked the battery? Install this gem of an App CoconutBattery it will offer you a better view on what’s happening. Post a snapshot of the Apps main window here so we can see things as well.
I would also run the onboard diagnostics restart the system and press the startup D key to enter, did you get any errors?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Athul さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 17
