メインコンテンツにスキップ
長く待ちわびた人気モデルMac miniの最新モデルです。プロセッサはオプションで3.6 GHz quad-core Intel Core i3、3.0 GHz 6-core Intel Core i5もしくは3.2GHz 6-core Intel Core i7プロセッサから選べます。
20回答 すべてを表示
Connecting a Dell Optiplex Moniter to Mac Mini i3 A1993 2018
In this case I am sure that the Mac i3 is functioning and that the Dell Optiplex Moniter is also functional; there is no USB port on the Moniter.
Previously I had an Apple A1347 Mac Mini running with a Vodafone Router and I am using the same cables now, but there is no responce from the Moniter, the Dell Self Test only appears and moves around on the screen.
The ethernet cable is functioning on my PC and I also use a Net Gear Prosafe GS105 with cross over cables on the PC.
I now have a Shell Energy Router DGA0122NLK and I am not absolutely sure if I am using the correct ports on it as not much details were sent, but it works for my Viglen Genie PC.
What I realy want to do is get the Mac Mini, Coffee Lake running the PC is only a server computer in this situation.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You appear to be dancing around talking about USB which is not involved in hooking up your display. Next you get into Ethernet and a router which again have no bearing on hooking up a display.
Your Mac has a combo port! The Thunderbolt port also supports mDP connected displays or a mDP to HDMI or other display interface.
As to making it a headless server or running Windows let’s first get the system working as a Mac, then you can get to these issues.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Savlen Dempsley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 77
