メインコンテンツにスキップ
2022年10月に発売されたGoogleのスマートフォン「Pixel 7 Pro」の修理・分解情報です。モデル番号はGP4BCとGE2AEで識別できます。
20回答 すべてを表示
Microphone Issues after screen replacement
After I replaced the screen on my pixel 7 pro my bottom microphone must've stopped working, atleast I think it's bottom, I can make phone calls but not use google assistant or any sound recording apps.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
have the same problem
さんによる
コメントを追加
1 件の回答
最も参考になった回答
From Reddit; Hello, nothing worked for my 7 pro until I found this work around. Download Voice Recorder & Voice Memos, open the app, and try recording. You can stop recording but dont close the app. The mic will start working. I set the app preference to work in background and never close the app. Then, open the Recorder app. It will start working normally. Transcription works beautifully. All phone apps work normally while Voice Recorder & Voice Memos is open in the background.
BINGO the voice recorder and voice memos fixed my issue, tried all the other crap and none worked. I suspect the app uses the other mics, so may not fix the lower mic issue, but allows one of the other for voice recording. Either way, I can now voice text again, my large thumbs don't fit the small keyboard well. Thanks ReviewTall3533!!!
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I have same issue. Don't find any solution.
さんによる
I've tried this. It uses only the camera microphone (above the display), not the lower one that doesn't work since my screen replacement
さんによる
I have the same probleme. Don't find any solution.
さんによる
コメントを追加
回答を追加する
NIck Nolan (Double.N) さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 37
今までの合計 719
