メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
20回答 すべてを表示
Need help with SMD resistor equivelant.PS42Q96HD
I have this PS42Q96HD SAMSUNG TV WITH A SMD RESISTOR MISSING ON THE POWER BOARD B44-00194A
( with 302 on top in position rs828 on board which says it is 3kΩ ± 5% ),
And i am wandering if i could use another with higher rating As mine is missing if so what could i use meaning either number on top or the amount of ohms I am showing on picture the position on the board as it is missing
Thankyou in advance guys
Update (01/10/2020)
Hi Jayeff Sorry for not explaining correctly Its just i have loadsa various psu boards and wandered if i could of used another smd to replace the one marked 302 on top as in pic as they don`t have that on on them.Would just need to know the number on top to see if ii have a one that would do same job properly,Thnx.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @moggy01
What do you mean by rating?
If you mean power rating that is not a problem.
If you mean the resistance value, I wouldn’t stray too far away from the specified resistance value as its’ value was selected, in conjunction with RS827 and that of the opto coupler, to set the required base voltage level for QS807.
It already has a low tolerance value of 5% so the circuit designers didn’t want the resistance to vary more than between the range of 2850 - 3150 Ohms.
Here’s an image taken from the schematics for the board.
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi @moggy01
Either find a resistor with 302 marking or use an Ohmmeter to measure the resistance if you are unsure.
I'd measure the resistance of one marked 302 anyway just to make sure that it is 3000 Ohms give or take 5%
さんによる
Hi JayeffI will thnx
さんによる
Well got sick of trying with the board i couldn`t sort it so got one off ebay but Thankyou for all the help.
さんによる
コメントを追加
回答を追加する
moggy01 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 124
