メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
Why is sound/mictophone/vibrator not working?
I replaced my iphone 4s screen by my self.
When I was finished and checked the phone I found out that there was no sound coming out of it at all. No sound from either speaker.
(both cameras worked , bluetooth and wifi worked and celural antena worked)
I tested it by making and receiving a call and I found out that neither my microphone nor my vibrator was working.
I tried rebooting and hard reseting it but it didn’t work. That let me to believe it is a hardware problem.
I reopened the phone and made sure all the connectors where connected properly , and they were. (still all those things I mentioned didn’t work)
I probably damaged something during the repair.
What can I do ? Do I need to replace anything ?
By the way I filmed everything with another phone (quality is bad) , so any expert can briefly watch it and maybe tell me where I did wrong.
(https://www.youtube.com/watch?v=M7MqRjCG... )
Any answer is welcomed.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント:
Video says its unavailable
Check or change the charging flex...
さんによる
I forgot to add that headphones don't work either .
Will they work if I change the charging flex ?
さんによる
Try disconnecting the charging flex and see if u get headphones working, failing that plug in the charging port and disconnect the headphone flex it's the one connected to the volume buttons and see if u get sound out of the bottom :)
さんによる
@c9679 Video is now online
さんによる
Lol I am sooo sooo sorry that is too painful to watch I watched till u struggled to remove the battery and I just couldn't watch further... so sorry please do try disconnecting the headphone port flex and the other suggestions I recommended lol
さんによる
コメントを追加
1 件の回答
First thing I would swap is the charge port. As this controls all the functions you mentioned (minus the vibrate issue)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nektarios さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 92
