メインコンテンツにスキップ
This LTE capable Android Wear 2.0 watch could be purchased direct from Google or AT&T. It actually supports Verizon even though it isn't listed in the specifications. Model numbers are W280A or W281A
3回答 すべてを表示
lg watch replacement band
is their any way to replace the bands on a lg watch sport even thought the watches bands are packed full of NFC antennas and many more things needed for it to function properly one is broke and im not sure where to get a replacement piece
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
model is w280A
さんによる
Hi, I think the only way to get it is from here:
https://globaldirectparts.com/oem-lg-wat...
You have to buy both straps separately.
And yes, it's easy to replace them: Just remove the two screws on the sides of the strapholder and gently pull out the straps, by pressing them also slightly towards the backside of the watch. Like this you're able to click out the two bands, which have connectors towards the watch itself.
The new straps can be attached in the same way again... Good luck! (Have to replace mine too, as they have been proken both together now after only 2 years of usage! Crappy design... The next watch is for sure not a LG watch anymore...
さんによる
There is a website that sells the bands for $35 per side but they are on back order.
I found a guy on ebay that sells refurbished ones that he makes with a 3d printer for $70 for both sides shipped.
https://www.ebay.com/itm/LG-Watch-Sports...
さんによる
Then I found another guy that sells replacement bands on ebay without the antennas, so you have to remove the antennas from your origianl band and slide them into the replacement for $21 for both sides shipped.
https://www.ebay.com/itm/Lg-sport-watch-...
さんによる
コメントを追加
5件の回答
ベストアンサー
YES! It’s easy… check out my new guide!!
LG Watch Sport Band Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Found it! they sell each separately https://globaldirectparts.com/oem-lg-wat...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
No longer available. These links are old.
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Wow, thanks for all those links! In my watch, the both antennas were broken also, but solution 1 and especially 2 sound good! And to be honest: I changed to the TicWatch pro 4G in the meantime and are really happy with it, especially regarding battery time thanks to the layered double display.
Well, on solution 2 just the protectors are printed with a 3D printer, the band itself is an original one as it looks like. Thanks for sharing!
さんによる
You're welcome. Happy to share, hopefully it could help others in the future.
さんによる
コメントを追加
I found my replacement straps on eBay, they really do have almost everything for sale on there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
for you that need a straps repleacment for LG W280 , i can provide it as a custom made by hand with leather based . just add my telegram @itbloon and i will send the pic .thankyou
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hayden Rogers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 5,255
