Speaker does not turn on!
I have had my speaker for a while now and for some reason everytime i try to turn it on but it doesn’t actually turn on. I already tried charging it for an hour and it didn’t work, any help??
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
Try another charger to make sure that isn’t the issue. Otherwise check out this troubleshooting page for your device. If there isn’t any charging port damage you’re aware of, you may need to replace the battery.
このアンサーは役に立ちましたか?
Which is the batterie on my Axess SPB 1031????
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 1,553
3 件のコメント
Where would I buy the battery at?
Saira Mendoza さんによる
Happened to me. It's a faulty power button. I need to replace it. But I found out that strategically position it in a specific spot, it will turn on. Like in the middle. Sometimes take like 10 seconds to get it working.
Angel Hdz さんによる
I am having the same problem, but mine is actually the switch. Can it be replaced? It will turn on sometimes if you move the switch to on and then back towards off just a little. Sometimes it work and other times it will not come on at all. Have had it about a year and half. But hardly ever use it. Probably doesn’t have 15 hours on it.
Mitchell Ford さんによる
