メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Axess SPBT1031 Battery Replacement
必要な工具と部品
  1. Axess SPBT1031 Battery Replacement, Red Interface Plate: 手順 1、 1の画像 1
    • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
    FixBotに聞いてみる
    コメントを追加
  2. Axess SPBT1031 Battery Replacement: 手順 2、 1の画像 1
    • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  3. Axess SPBT1031 Battery Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
    FixBotに聞いてみる
    コメントを追加
  4. Axess SPBT1031 Battery Replacement: 手順 4、 1の画像 1
    • Separate the red interface plate from the black face plate by pulling them apart.
    FixBotに聞いてみる
    コメントを追加
  5. Axess SPBT1031 Battery Replacement, Black Faceplate: 手順 5、 1の画像 1
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
    FixBotに聞いてみる
    コメントを追加
  6. Axess SPBT1031 Battery Replacement: 手順 6、 1の画像 1
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
    FixBotに聞いてみる
    コメントを追加
  7. Axess SPBT1031 Battery Replacement, Battery: 手順 7、 1の画像 1
    • Look into the back of the black face plate and find the battery which is wrapped in green.
    • Battery is glued in place, remove by peeling it off.
    FixBotに聞いてみる
    コメントを追加
  8. Axess SPBT1031 Battery Replacement: 手順 8、 1の画像 1
    • Once the glue is removed, look into the red interface plate and then locate the bottom of the motherboard.
    • On the bottom of the motherboard, locate the black and red wire connected to the plastic red socket and remove the white insert from this socket.
    FixBotに聞いてみる
    コメントを追加
  9. Axess SPBT1031 Battery Replacement: 手順 9、 1の画像 1
    • Run the black and red wire in reverse through the hole in the black face plate to remove the battery.
    • Remove the battery from the black face plate.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Elvira Lou Evangelista
メンバー登録日: 03/09/16
975 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016人のメンバー
UMASSD-BOTVIN-S16S8G6
3 メンバー
8のガイドは作成済み
3件のガイドコメント
ok, so is there any reason that I would not be able to put in a bigger battery for longer play? I realize I would have to mount it differently.
bartman777 - 返信 共有
why it is easily connect this blue tooth to cellphone done connecting to computer. Well not connect any of my 3 laptop computer ??????????????
htosee3791 - 返信 共有
What battery is used for the speaker?
De'Eric Dortch - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 67
今までの合計 9,376
