メインコンテンツにスキップ
2014年9月9日に発表されたこのデバイスはAppleが進出した最初の身につけるスマートデバイスです。iFixitの修理マニュアルではApple Watch (スティール製)とApple Watch Sport (アルミニウム)どちらも対応しています。
20回答 すべてを表示
Why is my NFC (apple pay) not working?
Cracked my display recently, but changed it to the new one (that was pretty easy). Then I found I removed the force touch gasket, ordered a new one and installed it.
Now my display works fine, force touch works fine, but I cannot get my Apple Pay working. When I double press the power button it shows my credit card and message "Move closer...", but the payment terminal doesn't see my watch. (It was working fine before the screen/force touch replacement)
The question is am I right the force touch gasket is the NFC antenna? Am I missing something? Maybe some wire contact or some additional gasket
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Delete your ApplePay account info (all) and re-enter it. That should fix it.
To explain what happened here review the Apple Watch Series 2の分解 jump down to Step4 last image you'll see the NFC chip is on the back of the display! So when you swapped it out your encrypted info was lost.
So we need to reprogram it into the chip. The info you see within the screen is only the visual effects the action fires off. Two actions take place the visual and telling the chip the correct record (in case you have more than one card stored) to send.
Update (02/11/2018)
OK, Ive switched your device info to the correct one.
This model uses the antenna plate which is near the gasket as you can see here:
Below the yellow gasket you'll see two gold colored bars these are the antennas did you damage them in the process of removing the old gasket?
このアンサーは役に立ちましたか?
スコア 2
14 件のコメント:
Thanks for your response. I have Apple Watch series 1, does it also have the NFC chip built into display?
And what do you mean by re-entering my payment data? I tried removing the card from Apple Watch default app on my iPhone and entering it again - no success. Do I need to completely remove it from both devices and enter it again?
さんによる
Apple calls the original Series 1 gen 1 and when the Series 2 came out called the low end model Series 1 gen 2. We call them Original, Series 1 & Series 2 to express the differences from a parts perspective. The Original uses very different parts than the Series 1 and Series 2. The only differences between the S1 & S2 is the logic board.
Here the display is the same part between the S1 & S2. Hopefully that clarifies which watch you have and what parts fit which and yes the NFC chip is the same across all three (not that matters here)
You need to use the Watch app on your phone to clear them cleanly. If that fails the display unit is bad.
さんによる
My watch looks like the following inside: https://d3nevzfk7ii3be.cloudfront.net/ig...
And I don't see the NFC chip here on a display
さんによる
You have is an 'Original' Apple Watch (Series 1 gen 1). The NFC chip in this series is within the main logic board which you can see here: Logic board breakdown
さんによる
I see your update. What is the exact part you are talking about? After replacing my display to the new one I also replaced this part to the new one: [リンクされた製品が存在しない、もしくは無効: IF308-014-2]
さんによる
9件以上のコメントを表示
コメントを追加
The solution has already been found here, but you haven't heard another method that will help you not find yourself in this situation again in the future. I am now referring to the pay stub maker, which is very useful in this case. Have you tried it before? I don't think so if you are having problems with payment. Thanks to this tool, I'm able to deal with all the checks and tax receipts. That's why you should try this option, which is not only a positive experience in your situation but also has several advantages.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anton さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 36
今までの合計 18,921
