メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
What is my password?
I bought a used SSD. After I installed it, I started the computer. The computer started nicely and went to the log-in page. This page showed an account named "Home" and asked for my password. As I say, this is a used SSD. How do I find the password?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Can you give us the last four digits of your serial number so we can correctly identify which model you have.
さんによる
The last four characters of the serial number are not digits, but letters: "DJYC."
さんによる
コメントを追加
3件の回答
ベストアンサー
I called iFixit. The clerk gave me an easier solution: start up while holding "Command R." That takes me to Disk Utility, where I erased the hard drive and restored from my backup.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Happy to hear that worked!
さんによる
コメントを追加
最も参考になった回答
You probably need to reformat the drive. Do this in Target Mode or use a universal adapter. Universal Drive Adapter
Turn your current hard drive into an external drive with this adapter.の画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Mayer, remember these drives are M.2 SSD's. I don't think the universal adapter will work here.
さんによる
Dan, yes and no. He didn't tell us which MBA he has, so it could even be using a ZIF drive. If an SSD drive goes in, then I would guess it has a 2.5".
さんによる
Good point Mayer! I keep forgetting the first version had a ZIF micro drive.
さんによる
Sadly it's a M.2 blade SSD. The other option here is to mount it in this case: Envoy USB case. I also like Mayer's idea of Target Mode if you have access to a second Mac.
さんによる
コメントを追加
Sounds like you'll need to return it.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Now that we know your exact machine, Dan's answer is correct. But in Target mode with another Mac, you can reformat the drive and install a new system.
さんによる
My understanding is that Target Mode works only with FireWire (https://support.apple.com/en-us/HT1661). The MBA does not have FireWire.
さんによる
No, you can also do it with Thunderbolt or even Ethernet connected macs
さんによる
コメントを追加
回答を追加する
fredderf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 170
